04-11-2016, 01:32 PM | #113 |
Geoff
Drives: 2020 ZL1 Green Join Date: May 2013
more detail of trailer hitch
hope this helps hammer, i too got the idea from some Porche guys i track with
i modified a "hidden hitch" brand hitch. i used the existing front mount, cut just behind it and made an offset to raise the bar to hug the bottom of the trunk. i also used the rear mount as it was, but ran the bar above it and again added a spacer to provide the correct offset. to add some stability, i added an angle bracket that bolts to the rear crash bar my car is not lowered, so the flat bar is welded to the bottom of the square bar for the 1 7/8" ball. this sets it up so that the front of the trailer is just slightly higher than the rear.
04-12-2016, 11:16 AM | #114 |
Canadian
Drives: 2011 Camaro 2SS/RS Join Date: Dec 2013
Just read through your whole build thread, and love everything that you have done and appreciate the documentation you have accomplished and will be using some pointers from your build to further mine. THANKS
2011 Camaro SS/RS
--------------------------------------------------------- The cars we drive say a lot about us. |
04-12-2016, 02:43 PM | #115 |
Geoff
Thx cypress, it's a lot of fun!
Post what you do and how it turns out
05-30-2016, 05:59 PM | #116 |
Drives: 2011 ss Join Date: Sep 2015
Great build. Do you have a pic with the hitch from the rear?
07-20-2016, 03:12 PM | #117 |
Geoff
Just saw this chuckie, sorry for the delay
07-20-2016, 03:43 PM | #118 |
Geoff
Dummy Seat Belt
I was concerned about the airbag deployment when using the harnesses. I ended up getting seat belt extenders from GM and cutting the male ends off (thx to MRBZ28 for the suggestion). discussion here: http://www.camaro5.com/forums/showthread.php?t=459415
GM mistakenly sent me one rear seat extender, they quickly sent the correct one out & now all good.
08-15-2016, 12:53 PM | #119 |
Daily Driver 24/7 365
Drives: '15 CRT 2SS/RS/1LE Join Date: Jul 2015
Congrats on COTW!
NPP Fuse Pull, Z28 CAI =
Previous Rides: 2005 Magnum R/T A5 CAI, Cat-Back 2014 RRM Camaro 1LT/RS A6/NPP CAI Follow Me On Instagram! |
08-15-2016, 02:43 PM | #120 |
Drives: 2010 SS/RS Supercharged 427 Build Join Date: Nov 2010
We love the story of your 1LE build. Looks great and thanks for sharing!
08-15-2016, 04:35 PM | #121 |
Drives: 2013 HWSE Indy Festial #26 Join Date: Mar 2011
Congrats on COTW! MAD PROPS for pulling a trailer to track days!
There are only so many days in your lifetime. So get out and drive your Camaro...
Dan |
08-16-2016, 09:27 AM | #122 |
I love me some Chevy's!
Drives: 14 2SS/RS ,14 BMW X3 ,02LR Disco 2 Join Date: Nov 2014
Amazing!!!!!! Excellent job documenting and explaining every step of the process! Congrats on beautiful build!!!
Did i mention i love this car! ok good, just wanted to make sure....
08-17-2016, 06:16 PM | #123 |
Liv'n The Dream!
Congrats man! PM sent.
I was just talking about your car/trailer to a couple friends today. lol
Never be afraid to try something new. The Ark was built by amateurs and the Titanic was built by pros.
08-17-2016, 10:53 PM | #124 |
Geoff
COTW
Wow, cool........I'm speechless (a rare occurrence)
08-18-2016, 02:58 AM | #125 |
Too much is never enough!
Drives: AGP TT SS [COTW] 4/20/15 Join Date: Feb 2014
Congrats on COTW! Nice build man, time for some FI?
AGP TT kit, 54/57 Forged rotating assembly, Custom grind cam... Dual nozzle meth, ID850's, Livernois dual fuel pumps, ECS BAP, 25% UDP, 3 inch Magnaflow catback with X pipe, Mantic 9000 clutch, DSS 1000hp axles, DSS aluminum driveshaft, ZL1 rear end, solid subframe bushings, HE differential offset bushings, BMR Trailing arm, BMR toe rods, Lingenfelter LNC-2000,SJM Line Lock. 747 whp 714wtq
Build thread http://www.camaro5.com/forums/showth...55#post8107855 |
08-18-2016, 07:39 PM | #126 |
Geoff
Thx Killer
Nope, not with this car. NA works best for me on the track........hmmmmmm, maybe an early Chevelle though
Tags |
1le, 2ss, build, h018871 |
