#1289 | |
Drives: 2017 Camaro ZL1 A10 Join Date: May 2012
I busted about 20 Mustang troll cherries since April of last year. |
#1290 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1SS NFG A8 Join Date: Aug 2017
Damn you all still in here arguing? Lel
2016 NFG 1SS A8
#1291 |
Thank you Al Oppenheiser!
Quiz time:
What’s the partial pressure of oxygen in a 150 shot? Higher or lower than without? What’s the partial pressure of oxygen in a 7psi boost? Higher or lower than without? Answer: Both are higher than NA. Both get more oxygen into the cylinder per stroke, resulting in more power. Whether you choose a belt or a bottle, the rest is symantics. |
#1292 |
Does nitrous pressurize the air that goes in the intake tract? Does nitrous make the widdle needle on the vacuum/pressure gauge go from vacuum to pressure? Does nitrous force air into the intake tract? Does it compress the air? Does it blow the air in?
No matter how you spin it, nitrous and all the widdle molecules are going into the engine under the engine's aspiration...vacuum...negative pressure. |
#1293 |
Drives: 2013 GB GT Join Date: Mar 2016
If you activate a plate or direct port system at idle I guarantee you will see positive pressure on a vacuum gauge and induction will be forced...briefly
#1294 |
#1295 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Love the one you're with Join Date: Sep 2009
Wow the DA in this thread is really off. Lol. Is nitrous forced induction? That question has been fought over long before car fourms existed. It depends on what you consider forced to mean as it can take on many different rolls. While is not forcing more air into the motor by way of compression thus raising the pleum pressure, it is forced in the sense that its bottling up as much as twice the oxygen as is contained in atmosphere. So in a sense it is still forcing more air and fuel into the engine over and above what can happen in a NA motor. I've always considered it another form of forced. Does it raise pleum pressure? While I never tested it. I think that would depend on how much spray you are shooting vs how much air the motor can naturally consume. I highly doubt in most situations that you would see much increase if any. For me that isnt how is makes it another form of forced induction anyways, so at least for me it doesnt matter if it does or doesnt.
#1296 |
![]() Drives: 13ZL1 Join Date: Dec 2017
I busted every mustang wannabe that’s ever pulled up beside me |
#1297 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Current Camaro-less Join Date: Jul 2014
#1298 |
Sarcasm Personified
Drives: 2017 Charger R/T Scat Pack Join Date: Dec 2015
#1299 |
#1300 |
That look like that
#1301 |
Why do all the mustangs I come across just a lot of noise?
Must be the mindset? |
#1302 | |
So for argument's sake, if the temp outside drops from 90 degrees to 15 degrees, is that considered "forced induction"? I mean, it's the same thing...more oxygen molecules due to colder air. What about a Killer Chiller system or meth injection? Those systems allow for a denser air charge. Should we consider all those to be "forced induction" as well? |
