04-09-2018, 08:51 AM | #1247 |
Drives: 2018 1SS 1LE, 2015 RAM Ecodiesel Join Date: Oct 2017
For comparison:
04-09-2018, 08:53 AM | #1248 |
Drives: 2018 Hyper Blue 1SS 1LE Join Date: Sep 2014
Not as bad as it could be. I want the factory line lock!
04-09-2018, 08:55 AM | #1249 |
Drives: 22 1SS 1LE Summit White Join Date: Sep 2016
good news for those of us with 16-18 camaros... our value just went up!!!
Really.. thats what they did with the refresh? maybe it will grow on us... maybe. The front end is terrible just terrible. I dont mind the back though. The turbo 1LE will be interesting but still igly.
#53 F Street
2022 Sponsor autocrossdigits.com Autocrossing Videos https://www.youtube.com/channel/UCm-...3tiMt0KOg_2Aag Instagram: apexit_53 2022 Rapid Blue 1SS 1LE 2019 D Street national champion (2019 civic Type R) |
04-09-2018, 08:59 AM | #1250 |
Drives: 2013 ZL1 Join Date: Dec 2012
Unlikely.
'13 ZL1
'06 TBSS '98 TJ '87 GN |
04-09-2018, 09:01 AM | #1251 |
Sure, why not?
Drives: 2016 Camaro 2SS, Jeep JKU Rubicon Join Date: Mar 2015
Hmm.
I see no big deal here. Just kind of tweaked a little. RS front: Sort of looks like it is smiling. Not bad, but not a look that I particularly like all that much. SS front: Kind of like it, but am not wild about it. I like it more than the RS front. I like my '16 SS front more than either of the '19 fronts. I would like to see what both new fronts look like with a black car. Rear Tail light changes: They look ok to me. Neither better nor worse. Although, if I had to pick, I think I like the more angular look of the 2016 tail lights. But, not by a whole lot. I give this update a solid "meh". Perhaps the Market will speak and sales will increase, who knows?
04-09-2018, 09:01 AM | #1252 |
I used to be Dragoneye...
It's beginning to grow on me. I am okay with everything except the new character line along the bottom of the rear fascia at this point....
04-09-2018, 09:04 AM | #1253 |
Drives: 2017 Hyper Blue SS 1LE Join Date: May 2017
04-09-2018, 09:05 AM | #1254 |
agreed, its a joke but based off looks... it could happen
#53 F Street
04-09-2018, 09:08 AM | #1255 |
Drives: '17 ZL1 Join Date: Jul 2016
I thought I did too until I tried to use it. The menu system is terribly clunky for it. The brake pressure cannot be varried like a real line lock(it forces you to use 100% brake pressure). There's a significant delay on the rollout which makes a short burnout nearly impossible. It forces you into launch control mode after you use it, and it takes several seconds to get set back up with nannies and launch control off.
In short..It's clearly designed by people who have never drag raced anywhere but private tracks. It's managable if you don't care about holding up the show at the drag strip while you fumble through menus, but I just gave up on it. A physical line-lock button with functionality similar to what real drag racers use would have worked 1000x better. Hopefully the '19s are better, but I doubt they move too far from their existing design.
04-09-2018, 09:11 AM | #1256 | |
If you press the Cruise control and menu center buttons at the same time it'll let you out early, too. But I've only done this 3 or 4 times because these tires are....well....I don't have the wallet to sustain this feature. |
04-09-2018, 09:32 AM | #1257 | ||
The issue I have with Chevrolet's line-lock, is they over complicated the crap out of it, and their design is far less functional than what's been in use for decades by drag racers. I get having a software-backed system with safety measures etc., but there is no reason they couldn't still do that with a single physical button design that works more like a regular line-lock.
04-09-2018, 09:47 AM | #1258 |
Drives: 2021 LT1 10 speed auto Join Date: May 2013
Come on, the front facia is better, the hood is better, The SS gets the 10 speed, the rear cover has more body lines. Not impressed with the tail lamps, no HP bump, no price changes and no less content cars. I guess the 1LE 4 banger might interest some, but Camaro needed the 10 speed auto across the board, need the SS HP bump and needed less content across the board to lower the prices of each and every Camaro from the 2.0, to the ZL1 and shake up mustang with mass interest/appeal. Look at how much Mustang did on there 2018 refresh that affected the entire line up that had widespread appeal. Ford added performance thru the engine, trans, tires, suspension, mechanical and electronic technology. Mustang needed all of it to equal the Camaro performance, but why let Mustang get so close when Camaro had a chance to pull away again. Camaro isn't selling, you can do better Chevy. Last edited by lt4camaro; 04-09-2018 at 10:04 AM. |
04-09-2018, 10:01 AM | #1259 | |
A10, meh, I like to shift. I bet the 1LE will still be manual only. Would have been cool to see a u speed manual, but I dont even use 6 that much. Now we wait for the 2020 model... lol |
04-09-2018, 10:07 AM | #1260 |
