Old 07-07-2025, 09:12 PM   #113
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
NICE work! Coming out great. Super attention to detail.
Thanks, Josh! Just trying to keep up with you guys.
Plus, it's the mechanical engineer in me coming out. I don't get that at work anymore as my role doesn't really get into any technical details anymore, so all my OCD engineer mind gets poured into this stuff. I ultimately just hope it runs and doesn't leak.
Mods being installed-
Old 07-08-2025, 02:25 AM   #114
ZLRob
Super Stock
ZLRob's Avatar
Drives: Chevrolet Camaro ZL1
It's a huge time killer, for sure. There are many more painful cleaning portions than fun assembly. I knew the gaskets would be a time suck, but man, what a pain!
Yeah, you know, little issues. What is the plan? Are you going to upgrade the pump or go port?
The RTV stuff is not horrible at all brother. I actually like it. Just make sure you try to sand the mating surfaces so the RTV will stick nice and proper, lay a nice solid bead and work in a quick- ish motion trying to keep it all pretty fluid and moving it out of the tube as even pressured as you can. It definitely works worlds better than rubber gaskets, especially GM's because their stuff is prone to leakage. At least with RTV you can choose from several different MFR's if you know which one works best unlike the proprietary GM gaskets.
Well, I got inspections coming up and I'm trying to clear up monitors for now so I'm all good, but once I'm done with that I'm going to have to mess with my pressure settings and see if I would be capable of decreasing high pressure pump duty so it's not being taxed to the point of max out. I have two different tunes ready with different fuel pressure and map changes, but if they don't pan out enough to the point where the readings are still making me uncomfortable whether it be injector PW's, rail pressure or high side lobe duration I'll have no choice but to swing for a Goliath high pressure pump and that extra 10% headroom in fueling should be just enough to satisfy the current fuel demand that the engine has now.
758 HP/ 804 TQ
Old 07-08-2025, 06:29 AM   #115
clg82
Drives: 2020 Camaro ZL1
You gots nice knees
HAHAHAHAHA
I was gonna say, is he even wearing any pants?!? Nice build, love following stuff like this.
Old 07-08-2025, 06:55 AM   #116
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1 - Beast Build
Looks like good progress being made !!! Well Done !!!
PS: I still have no driveshaft
Katech Track Day CAM 38%•BTR Dual Valve Springs-Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Ported Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper & ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI Interchiller Stage 2•THPSI Port w/875cc Inj•Dual Drop In Fuel Pump•DSX Aux Pump•Stainless Works 2" w/Legend NPP Axle Back•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout/Bushings Kit•DSS Chromoly DS•RPM 8-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
Old 07-08-2025, 07:08 AM   #117
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
MANY MANY KUDOS TO ALL THE GREAT WORK!!! Thanks for the helpful tips, too!!! That's some professional-shop-work right there!!!
CHEERS!!!
'20 ZL1 Black "Fury"
Old 07-08-2025, 09:31 AM   #118
Curr
Probably doesn't like you
Curr's Avatar
Drives: 2022 WCT ZL1 M6
This is freakin awesome... way above my ability, but as an engineer, I love seeing the insides and well done assy pics.
كافر
ΜΟΛΩΝ ΛΑΒΕ
железобетонное очко
Quod gratis asseritur, gratis negatur.
There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly.
Curr is offline   Reply With Quote
Old 07-08-2025, 12:51 PM   #119
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
I'm just not a fan. I'm all done with it though. Everything is sealed up now. It's just the removal and cleaning that was painful; putting it back together was a breeze.
Good luck with the fuel headroom. Your "big fuel" cam has a 32% lobe on it, right?
With all of the fuel challenges you guys have had, I just went ahead and bit the bullet with the Goliath and XDI +70's. That should carry me to my goal on full pump E with maybe a little headroom to spare.
Old 07-08-2025, 12:56 PM   #120
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
CHEERS!!!
Many thanks, gentlemen! I appreciate the kind words. I know I'm probably going overkill on much of this stuff, but hey, that's what hobbies are for, right?
If I did this for a living I'd never make any profit doing it this way.
For the record, I was wearing shorts. The garage is hot in the summer, but not that hot.
Scott, from what I've heard about DSS customer service, you may be waiting on a response for some time, unfortunately.
Old 07-08-2025, 01:06 PM   #121
ZLRob
Super Stock
ZLRob's Avatar
Yeah but to be entirely transparent here a ported blower was never in the initial plans when doing the cam. It turned out that the power the big fuel cam made was so much more that it wound up making the injectors run to high on PW's so that led to me getting the 30 overs then after I got them I said to myself, "well if the blower has to come off again to do injectors, why not allow for maximum power and breathability of the setup?" which led to me doing the ported blower and now here I am maxed out again.
I think at the time, we took a compressor and wire wheel attachment to the gun and just wire wheeled every mating surface along with the work of a flat blade screwdriver and razor as well. It worked out good and made quick work of the clean up process but I agree. Dealing with RTV is annoying. Way more effective than gaskets though so I'll take the payoff for putting in a little more effort and work.
758 HP/ 804 TQ
Old 07-08-2025, 11:21 PM   #122
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
Well done Rob! Amazing job documenting with great photos and write ups for everyone else who may be intimidated by the job, to hopefully help get them through it!
Keep it up!
Old 07-09-2025, 05:06 PM   #123
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
Keep it up!
Thanks, Gabe!
Old 07-09-2025, 05:25 PM   #124
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
Question for all of you fuel system gurus:
What am I missing or what would you change in the low side components I'm proposing?
In order from tank to HPFP:
1) DSX Dual In-tank (with the 285 pumps that have the internal check valves)
2) -10AN line
3) Fuel filter
4) -10AN line
5) Ethanol sensor
6) -10AN line
7) HPFP
I guess I could hook the fuel filter and ethanol sensor together and put them on the same bracket under the car as an option to eliminate some complexity. Jury is still out on where I put the sensor. Under the car would be stealth: "nope, no good fuel here, just a simple LT4 on 93 with a 2650..."
I'd also like to hear thoughts on the 285 pumps vs the 295 pumps (295 is same pump without the internal check valve apparently). On the bucket itself I'd think the 285 pumps with the internal check valves would kind of be a necessity so as not to push the fuel back through the 2nd pump when it's not activated. Apparently I don't understand how the dual system works internally from a plumbing standpoint, as the DSX website says you can run the 295's with no problem. I'm not sure what the cons are (if any) for the extra small amount of flow.
Somewhat related, I'd prefer not to run a check valve in the main fuel line once I remove the dinky stock line with the check valve, since the Lingenfelter check valve is pretty expensive for what it is. Several people have said you can run without a check valve without issue.
Thanks in advance for thoughts and ideas on the topic!
Old 07-09-2025, 06:10 PM   #125
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
2) -10AN line
3) Fuel filter
4) -10AN line
5) Ethanol sensor
6) -10AN line
7) HPFP
Your ethanol sensor needs to be in a special “bypass fitting” or doing -10AN becomes pointless lol
Old 07-09-2025, 06:46 PM   #126
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
Oh yeah. Absolutely agree! On that note, do i even need -10 or is it overkill?
