Old 06-28-2025, 11:33 PM   #113
AZIROC
Drives: '86 IROC-Z '18 ZL1
I have to hit the fob and then still hit the stert button for it to start.
Old 06-29-2025, 11:47 AM   #114
Deacon Blues
Drives: 2024 Camaro 1SS M6
Originally Posted by AZIROC View Post
I threw in an airtag (well..Samsung version) the day after I bought the car years ago. Once these spikes in 6th gen thefts got started I threw on the mobilistics kit. For $100 I was really debating it or not but glad I did the crappy part is it can't count how many times I've tried starting my car abd it won't cause I didn't click the fob first
I've found there is a bit of timing involved, I have to hit the mobilistic fob about a second before I push the start button or else it doesn't engage. Found that out the hard way after panicking in a parking lot literally the second time I took the car out after installing the mobilistics relay, I was either pushing the relay fob too early or too late and couldn't get it started (finally did). Not sure if that is just my unit or what.
Deacon Blues is offline   Reply With Quote
Old 06-29-2025, 08:03 PM   #115
The Maverick
Somewhere in the Kalahari
The Maverick's Avatar
Originally Posted by Pcormier66 View Post
It’s really pretty simple. Take a higher res picture, download it to your computer, open the file and print on your regular printer. All you need is some bumper sticker paper, which every office supply store sells for cheap.
I bought a second OEM relay thinking I could swap the plastic shells, but unfortunately that didn't pan out (size differences between the two, as I recall). Mentioning this approach in case someone has figured out the swap...
Old 07-29-2025, 11:40 PM   #116
DFVZL1 22
Drives: 22 Chey Cam ZL1 6spd
I have and use the following: obd metal cover, faraday pouch, mobilistic fuse, and steering wheel club
DFVZL1 22 is offline   Reply With Quote
