Old 08-25-2021, 09:52 AM   #113
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
I would of expected a bit more gains then that....at least 90whp from even a very mild setup. If you baselined 418, then a mild H/C/H setup should put you over 500 pretty easy on 93 octane.
Old 08-25-2021, 10:23 AM   #114
Timbo-1LE
Timbo-1LE's Avatar
Drives: 2017 SS 1LE
Well two things. I did not use their cam, my choice. Second, their dyno per them is very spot on.. Remember they build for professional teams, no inflated numbers. This is well into the 530-540 at the crank... I'm happy
Timbo-1LE is offline   Reply With Quote
Old 08-25-2021, 10:52 AM   #115
KingLT1
KingLT1's Avatar
I am specifically referring to delta gains from the mods not peak numbers...so dyno used doesn't matter. A mild h/c setup should gain around 90whp. I said over 500 because your base line was 418. If your base line number was 390 then the gains would look right. You can gain 50whp on these engines with just bolt-ons without getting into the motor. I think there is some missing power in your setup is all.
Either way glad you are happy...that is all that matters!!
Old 08-25-2021, 01:21 PM   #116
Tim M
Tim M's Avatar
Drives: 2018 Camaro SS 1LE
Tim - salute you for posting the numbers.
Katech is likely conservative from their reliable track background along with the cam being easy enough on the valve train to be rated for OEM valve springs - so with your uprated valvetrain will likely last a GM durability cycle...unlike probably all the other 'big' cams available.
Got to do a video of it at 7000 rpm - the soundtrack of these cars (with the OEM exhaust) is just one more impressive attribute to Chevy's package.
Tim M is offline   Reply With Quote
Old 08-25-2021, 03:51 PM   #117
Timbo-1LE
Timbo-1LE's Avatar
Drives: 2017 SS 1LE
Thx Tim M. Will post videos
Old 08-27-2021, 07:42 AM   #118
Katech_Zach
Katech_Zach's Avatar
Drives: 14 Camaro SS 1LE
Our standard head and cam package makes about 530rwhp with a full exhaust. Not sure why exactly this made so little power, but there was nothing left on the table with this camshaft. For a cam of it's size (terms of duration), the lift/duration area under the curve was low (we cam-doctored the camshaft).
Katech_Zach is offline   Reply With Quote
Old 09-08-2021, 04:59 PM   #119
Timbo-1LE
Timbo-1LE's Avatar
Drives: 2017 SS 1LE
Yea, it goes.....
https://youtu.be/Rw-LRPHZetY
Old 09-12-2021, 08:06 PM   #120
Motor Fast
Originally Posted by Timbo-1LE View Post
Sounds good. I'm hoping to catch a track day at Daytona.
2002 Camaro SS | 2003 Corvette Z06 | 2008 Corvette | 2012 Corvette ZR1 Inferno Orange with PDE | 2016 Corvette Z06 C7.R | 2018 Yenko Camaro
Motor Fast is offline   Reply With Quote
