#113 | |
603 Camaros
Drives: 2017 NGM I4 1LT Coupe Join Date: May 2012
MY 2017 I4 CAMARO BUILD JOURNAL | YOUTUBE | INSTAGRAM | 316RWHP - 385 RWTQ HPTUNERS DYNO TUNE | 12.693s @ 105MPH 1/4 Mile |
#114 | |
2016 2SS NPP MRC Glowtie
There is no replacement for displacement
#115 |
![]() Drives: 2018 Camaro SS Join Date: Mar 2018
So I have been reading through these today and my 2018 has this issue. Went to the dealership this morning and they confirmed it is the TC issue. I noticed there are no results when searching for this on a 2018 so thought I would add one.
They will be doing the fluid change Friday. I started really noticing it at around 10k miles (yes it is my daily driver with about 70 miles a day round trip and a trip to TX and back from NC). Hopefully it fixes it but the tech who rode with me seemed pretty sure it will need the TC replaced they just have to go through the process. His comment was that I probably got one of the older transmissions during the assembly. (I dont have my build date at hand and I am at work) I have had the car since March though I know that may not mean much lol.
2018 Camaro 1SS Artic Blue Metallic - mod ideas still cooking...
#116 |
![]() Drives: 2017 Camaro SS Join Date: May 2018
And here I was all believing that GM solved this problem over a year ago.....
#117 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: Wild Cherry LT1 Join Date: Dec 2016
Thanks for your input/update
#118 |
Have you looked at the sticker Under the carpet in the trunk that lists all the build codes. Just skip down to you get to the M's Mine says MXO ( 8 speed auto ) and M5U next
#119 |
![]() Drives: 2016 Camaro 2SS Join Date: Nov 2017
Brought my car in for shudder concern. 2016 with 18k miles. They sold me my CAI is the cause of the shudder and to remove it. How much bs is that?
#120 |
Sounds that way, but to confirm... does your car shudder under light throttle while going up inclines? Most specifically at highway speeds.... Does or did the shudder last for just seconds each? If so, they're clearly ignorant or incompetent ( the dealer techs)
#121 | |
![]() Drives: 17 Camaro 2SS 50th Anniversary Conv Join Date: May 2017
2017 2SS 50th Anniversary Convertible,A8,MRC,NPP,NAV,Black Bowties
#122 |
![]() Drives: 2SS, CT-R, LC500 Join Date: Jan 2018
So hire a lawyer if you have a case, or dump the car if you don't want to deal with it. I'm dumping mine once I get an A10. I'm too jaded from fighting GM dealers for the past 2 decades. Its only money.
#123 |
Drives: Camaro V6 Join Date: Oct 2016
How do you know the new A10 won't have the same or similar problems?
#124 | |
OR I might just dump GM altogether. |
#125 |
![]() Drives: 2017 2ss coupe Join Date: Jun 2017
Just took mine to the dealership in elizabethtown KY. Quite certain they are replacing the torque converter. i'm in a rental costing me about $25/day and this will probably be a 1.5 to 2 day procedure they said. mine is a 2017 2ss i purchased at this dealership in late may 2017. only has a little over 11,000 miles and the problem started at 10,000 miles.
#126 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
Based on all the information on the last couple of pages of the main thread and this one, is there an aftermarket solution should the issue crop up again?
I had the 3 x flush done, and no vibration issue after about 1000 miles so far, but I figured I'd ask for an alternative solution should the dealer not want to cooperate. I've had issues with Chevy honoring the warranty in the past, and I don't want to get into a tit for tat debate with them. The dealership I bought the car from has a pretty good reputation, as my family has bought from them for years in the past. I'm kind of hoping that reputation is well deserved. But, I still wanted other options or alternatives even if I have to go after market. |
