#113 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
I am calling them tomorrow to check on this. I'm a dealer and someone is asking me for this 6.43 BS and it's not in the catalog.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
#114 |
![]() Drives: 2017 1SS A8 Nightfall Gray Join Date: Feb 2017
92-795252DP-30
#115 |
Writer
Yeah I talked to head of sales and also the head of tech, the "-30" notes custom milling which adds an additional charge of $50 and takes a week to get done.
From talking to Mike K the head of tech, when folks order the "-30" he said that gets tight, and that "-25" would be his preferred unless folks take measurements. I get why he's being a big cautious, if the wheels are milled and make even a little contact they get stuck with them.
PROJECT HEAVY CHEVY
#116 |
![]() ![]() Drives: '17 Red hot 2ss, 16 Focus RS Join Date: Aug 2015
So will my 6"bs work for a hoosier 28x10 as long as I don't lower the car? Mine is mrc. I was thinking about eibach pro kit which looks like an inch or less. I'm not dead set on having the springs, but would like to run the Hoosier slick
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance Last edited by Dubchitts; 03-12-2018 at 05:54 PM. |
#117 |
Actually let's do it this way. My racestars are 17x9.5 6"BS. Car is m6, mrc with harness relocation already, stock height.
What bias plys will fit if I stay stock suspension? I see a Hoosier 28x10 and a MT 28x11.5 and a M&H 26x8.5. Are there more options out there?
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance |
#118 |
I think laynlo has the 28x10 hoosier slicks but he has the 6.43bs he is also like 1.5" lower maybe he can give you an idea if they will fit with your 6bs
#119 | |
But from a tire calculator, the MTs I have are 27.8"tall x12 wide. In theory the hoosier should be fine then, right? I know it's 2 different brands and two different constructions, but 2 inches narrower on a .3"taller tire
"Spitfire" 427ci
#120 |
I know on my 6.43bs the hoosier slicks would fit fine because my M&H Drag radials have all kinda room sorry I cant help ya any better
#121 |
No problem man. I appreciate the help. I think I'm going to try them. With them being, (in theory) narrower and only. 3"taller I think it should be fine
"Spitfire" 427ci
#122 |
Mine were the first ones done by Mike at Racestar and that's how the 6.43 came about because I wanted to make sure they would clear a lowered Camaro like mine. Before there was only 6" and 6.85" or something like that. I actually met Mike in KC and picked them up. They fit perfectly.
#123 |
![]() Drives: 2017 1SS camaro ,2SS a 68 + 08 C6 Join Date: Dec 2017
You guys do know that lowering a car and running it at the track will kill the weight transfer and your Et in the process.
With that being said a lowered 6th gen does looks badass. |
#124 | |
![]() Drives: 2016 2SS A8 Join Date: Feb 2016
Anyone else running the 17X10.5 with 7.00 BS? Those are the wheels I was looking at getting, but wasn't sure if they'd be too wide for a 10" Hoosier slick, as the website says recommended widest rim is 10". By the looks of all the tires available, is it better to go with the 9.5" wheels?
16 Summit White 2SS-MRC-NPP-A8 :: PrayPorted IM - LT5 TB - Mishimoto Catch Can - RotorFab - E85 - TSP 2" LongTubes - Speed Engineering X/Mid Pipe
DIY Hpt Tune - DR - 1.75-60' - 7.47@95 - 11.56@120 with +2676DA |
#125 |
Anyone know how much a Mickey et street r 305/45/17 weighs? For shipping purposes
"Spitfire" 427ci
#126 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 14 Silverado LTZ Z71, 16 Camaro SS Join Date: Nov 2009
according to mt they are 31 lbs each
