#1219 |
The driver in this highly modified ZLE called The Blue Dragon is Trans-Am Champ and IMSA Pro racer Cameron Lawrence. The video is by RSFR
#1220 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
#1221 | ||
![]() ![]() ![]() Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
Made the trip back out to NOLA last weekend with NASA! Unfortunately, I only got 4 dry sessions out of 8 scheduled due to a Mustang hitting the wall at the end of the out lap causing a red flag that ended one session and a wet track during all of the Sunday sessions except for the first one, but it was still a fun trip and I knocked just over a second off of my previous fastest lap time. Unfortunately, I forgot to start the PDR recording at the beginning of that session but thankfully I had a backup dashcam and Harry's Lap Timer with 10Hz GPS that was within 0.02 seconds of the PDR's lap times on the next session when they were set to approximately the same start/finish line. I have been getting more comfortable with catching slides this year and had several in turn 3 and on the exit of turn 14 that brings you towards pit in, plus this big one entering turn 4. I put some additional notes in the YouTube video descriptions.
Track (which config if applicable) = NOLA Motorsports Park - Avondale, LA (Standard 2.75 mile config) Elapsed Time = 1:56.98 Camaro Year / Model / Trim = 2017 1SS 1LE Date = 12/5/2020 Tires = OEM Goodyear Supercar 3 Mods = Track alignment (camber: -2.3° front, -1.4° rear, toe: 0° front, +0.05° rear per side [+0.10° total rear toe]), StopTech STR 600 DOT 4 brake fluid, StopTech Sport Brake Pads (309.14050 front, 309.17180 rear, very similar feel to stock pads but more pedal pressure is required for equivalent braking force which I am still getting used to), GM plastic track brake cooling deflectors. Traction/stability control fully disabled, track mode with touring steering mode. Brake pads note: I was already seeing about 2mm of taper top to bottom with a little over 50% pad material remaining on the fronts after about 5 hours of track driving (much worse than I ever saw with stock brake pads) so I swapped the pads inside to outside on each front caliper with no ill effects...hopefully that will even out the taper so they last longer. The 1:57.29 lap was at the end of the session right after I did the pad swap. Last edited by cdrptrks; 12-14-2020 at 01:53 AM. |
#1222 | |||
![]() ![]() Drives: The DSSV Twins: ZR2 and ZLE A10 Join Date: Oct 2019
#1223 |
![]() Drives: 2020 ZLE Rally Green A10 Join Date: Sep 2016
Track-Sebring International Raceway - Sebring, FL
Model-2020 Camaro ZL1 1LE Time- 2:29.38 Date- Dec 13, 2020 Tires-stock 305/325 GYS3R Mods- Giro-Disc rotors, DTC70 pads w/ Castrol SRF fluid, Garage Therapy 4pt Roll bar Video |
#1224 |
![]() Drives: 2018 2SS 1LE Join Date: Feb 2018
Track - Streets of Willow Springs - Socal
Model - 2018 2SS 1le time - 1:23.920 Date - 12/13/2020 Tires - stock 285/305 Supercar 3 Mods - Motul RBF 600, GM manual track alignment, OEM SS rotor deflectors Left my SD card for PDR at home so just have trackaddict data for the afternoon after borrowing an sd card in the am - morning runs were 1:25s on PDR with full fuel load and lower temps (upper 40s) vs. 50s and sunny in afternoon with a higher speed carried into back straight and turn 1 which cut down a good chunk of time -- impressive that Randy Pobst got 1:20 flat in this car stock. Don't think the corner by corner on Trackaddicts is that good but the start/finish times seemed to track overall
2018 1LE
2nd 6th gen SPL Toe Arms/Brembo HTC64t/Corsa NPP/Tremec MTF Fluid |
#1225 | |
Drives: Z06 Join Date: Aug 2010
SS 1le VIR
Track (which config if applicable) =VIR full
Elapsed Time (please include times to the hundredth if possible) =1:57.0 Year / Model / Trim =2018 SS 1LE Date =10/13/2020 Tires = 315 Hoosier A7 Mods = Boltons E85 465whp and DSC sport tractive coilovers |
#1226 |
![]() Drives: Camaro 1ss Join Date: Nov 2019
Coby is such a good driver.. been following his/yours gridlife career
Follow me on IG for build thread! https://www.instagram.com/tracked_1ss/
YouTube: https://www.youtube.com/@Tracked_1ss FortuneAuto Coilovers! https://shop-fortune-auto.com/produc...ries-coilovers |
#1227 | |
j1ss
Drives: '21 2SS 1LE Join Date: Dec 2019
Track - Palm Beach International Raceway
Elapsed Time - 1:29.9 Camaro ‘20 1SS Coupe 10spd Date = 12/15/2020 Tires = Eagle SuperCar SC3 (1LE spec 285f 305r) Mods = Track alignment, 1LE splitter, ZL1 skirts, ZL1 wing, DOT4 fluid, SS track brake air guides, SS 1LE/ZL1 spec rims, SS 1LE/ZL1 spec tires |
#1228 |
Driver for Hire
Ugh, I haven't received updates from this thread for a while... I will attempt to update everything over the next week or two. Lots of catching up to do!
Luan Zeqollari
2022 Camaro 2SS 1LE M6 - Wild Cherry Tintcoat 2018 Camaro 1SS 1LE - Hyper Blue Metallic - RIP 6/6/20 YouTube Channel |
#1229 |
Driver for Hire
Updated, including driver names where applicable. Joeyazzata29, can we get some data to backup the video, per the posting rules?
Luan Zeqollari
#1230 |
![]() Drives: 2019 ZLE Join Date: Jul 2020
Track-Motorsport Ranch Houston CCW
Model-2019 Camaro ZL1 1LE Time- 1:44:93 Date- Dec 12, 2020 Tires-stock 305/325 GYS3R Mods- None |
#1231 |
Track-Eagles Canyon Raceway - 2.7 CCW
Model-2019 Camaro ZL1 1LE Time- 2:03:96 Date- Dec 12, 2020 Tires-stock 305/325 GYS3R Mods- None |
#1232 |
Driver for Hire
Updated
Luan Zeqollari
