Old 11-17-2020, 04:03 PM   #1191
gcrusco
Drives: 2018 ZL1 1LE, 2014 ZL1
Originally Posted by FollowMyLine View Post
Updated.
My 2:24 got put in the 30s for COTA haha slight update needed
gcrusco is offline   Reply With Quote
Old 11-17-2020, 04:23 PM   #1192
FollowMyLine
Driver for Hire
FollowMyLine's Avatar
Drives: 22 Camaro 2SS 1LE M6
Fixed! Sorry about that.
Luan Zeqollari
2022 Camaro 2SS 1LE M6 - Wild Cherry Tintcoat
2018 Camaro 1SS 1LE - Hyper Blue Metallic - RIP 6/6/20
YouTube Channel
FollowMyLine is offline   Reply With Quote
Old 11-19-2020, 11:29 AM   #1193
namaral747
Drives: 2018 Chevy Camaro 1SS 1LE
Owner (ME)
Track = BARBER MSP
Elapsed Time = 1:42.66
Year / Model / Trim = '19 2SS 1LE
Date = 11/01/2020
Tires = OEM SC3
Mods = RBF 600 fluid, Hawk DTC-70 Pads, ROTOFAB CAI, MBRP Cat Back
Randy Pobst (Same car)
Track = BARBER MSP
Elapsed Time = 1:37.98
Date = 11/01/2020
Tires = OEM SC3
namaral747 is offline   Reply With Quote
Old 11-19-2020, 01:32 PM   #1194
FollowMyLine
Driver for Hire
Updated. So cool Randy hopped in your car!
Luan Zeqollari
YouTube Channel
Old 11-22-2020, 03:55 PM   #1195
CaliforniaKid
Drives: 2018 ZLE
Ran my 2018 ZLE at chuckwalla in the clockwise direction yesterday. I ran a best lap of 154.6 with a passenger, I had some issues with the volume on the video but here’s the lap. The car is on all stock components, brakes tires suspension etc. only parts that are not factory are the intake/Catback exhaust and flex fuel tune for up to e60.
CaliforniaKid is offline   Reply With Quote
Old 11-22-2020, 05:17 PM   #1196
Grandsport Speedway, Hicthcock TX
Time to add a new track to the list.
Track = Grandsport Speedway, Hitchcock TX (CW Configuration 1.4 mi)
Elapsed Time = 1:06.62 @ 3:23 video
Year / Model / Trim = 2019 Camaro ZLE
Date = 10/24/20 (video date title incorrect)
Tires = OE SC3R
Mods = RotoFab CAI, AWE Catback, Motul brake fluid
Old 11-22-2020, 05:55 PM   #1197
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
Track (which config if applicable) =Circuit of The Americas (Full Circuit)
Elapsed Time (please include times to the hundredth if possible) = 2.24.19
Year / Model / Trim = 2018 Camaro ZL1 1LE 6spd
Date =10/13/2020
Tires = Hoosier R6
Mods = Stock Weight, OEM Pads and Rotors, 18% Lower Pulley, ARH Headers/Midpipes, Corsa Extreme Axle Back, Weapon X HE's, SPL Lower Control Arms and Toe Rods, Hoosier R7 with 19inch BC Racing Wheels, RPM Rollbar and Harnesses
https://youtu.be/J73ZbQpkupQ
Great lap time!
Old 11-23-2020, 12:44 AM   #1198
ICTsccaCamaro
Hallett raceway CCW
18 ZL1 1LE on 9/15/20, Bridgestone RE-71R 305 front and 355/30R19 Kumho ACR's rear, All stock with track alignment
1:24:73
11/22/20
ICTsccaCamaro is offline   Reply With Quote
Old 11-23-2020, 10:14 AM   #1199
ZRacerLE
ZRacerLE's Avatar
Drives: The DSSV Twins: ZR2 and ZLE A10
11/22/20
MSR Houston CW
1:45.49
2019 ZLE A10
No mods, motul 660 brake fluid
ZRacerLE is offline   Reply With Quote
Old 11-23-2020, 05:44 PM   #1200
FollowMyLine
Driver for Hire
updated!
Luan Zeqollari
YouTube Channel
Old 11-24-2020, 06:47 AM   #1201
JaxSolo1LE
Drives: Chevy Camaro SS 1LE
Hey all, my first post on this forum and it's a lap time! Had my SS1LE for 3 and a half months, done plenty of autocross. This was my first track weekend with it. Only my 6th track day/weekend to date.
https://youtu.be/6-M0W-gCplc
Track= NOLA Motorsports Full course
Elapsed Time = 1:58.94
Year / Model / Trim = 2017 SS 1LE
Date = 11/8/2020
Tires = OEM Goodyear supercar 3's
Mods = Brembo HTC64 brake fluid, all stock everything else.
JaxSolo1LE is offline   Reply With Quote
Old 11-24-2020, 12:55 PM   #1202
Originally Posted by ZRacerLE View Post
11/22/20
MSR Houston CW
1:45.49
2019 ZLE A10
Solid time right there...
Old 11-24-2020, 01:43 PM   #1203
ZRacerLE
ZRacerLE's Avatar
Thanks man! I have video on the Garmin Catalyst of a would be 1:43:xx, but ran into a train a few seconds before my finish line. Made me sick. Couldn't get another clean run to try and make that time official. I know this car can do a 1:39:xx, but the driver is FAR from being able to talk it in to it, lol!
Old 11-24-2020, 08:15 PM   #1204
cdrptrks
cdrptrks's Avatar
Date = 11/8/2020
Great job for your first track weekend with the car! Thanks for sharing. What did you think of the track layout?
You can carry a few more mph of minimum apex speed through turn 5 and you can make the track a bit wider if you put the passenger side tires up on that right apex curb (maybe not advisable if there are puddles near the curb). For turn 6 you can carry about 10mph more speed through there. You can keep full throttle all of the way through turn 7 but you may nearly run out of track at the track out point. For turn 8 I would highly recommend keeping some maintenance throttle applied all of the way through instead of coasting because if you get oversteer at 110mph while coasting you may end up doing something like this or worse:
You beat me by about 8mph through turn 13 so I need to work on that! And I see PTM kicked in on the exit of turn 14 for you in the same spot where I almost spun even though you were in 3rd gear and I was in 2nd. I think 2nd may have helped me exit turn 16 slightly faster but you were also stuck behind another car there so maybe not and I know of another SS 1LE owner who uses 3rd there and has similar lap times to mine. And I had a few slides towards the wall there on a dry track so 2nd probably would have been a bad idea for you anyways with the some of the puddles I saw in your video. Also the car has no lift shift built in when you're in track mode which I personally like to use for the 3 to 4 shift (but not as often for the 2 to 3 shift) which probably improves lap times slightly but it takes practice to keep yourself from lifting slightly by instinct and causing the car to jerk and hit rev limiter momentarily instead of activating no lift shift.
If you want to send me a private message, I can send you my PDR file of the video below for lap comparison in Cosworth toolbox. I'm planning to do my second NOLA event in this car soon with NASA on 12/5-6! Looking forward to trying to string together a lap with less mistakes this year.
