#1163 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
Did DSC end up being FS-legal?
If so learning it will be an advantage. It's way too complicated for the resources I have to test it, and combined with not being all that impressed with the oem DSC shock tunes I decided not to go down that rabbit hole. Where I've found time is adjusting for a bumpy venue, which most are to some degree... tuning rebound to maintain contact with the ground without bouncing and compression to take the bumps without unsettling the car.
#1164 | ||
![]() Drives: broken Join Date: Aug 2009
![]() Quote:
clyde
Team WTF?! what are you gonna do? :dunno: |
#1165 | |
![]() ![]() ![]() ![]() Drives: 22 1SS 1LE Summit White Join Date: Sep 2016
its hard to make changes and it being nationals pressure and only 3 runs... i keept telling myself drive better you dont need much.
#53 F Street
2025 FS National Champion 2025 Sponsor autocrossdigits.com Autocrossing Videos https://www.youtube.com/channel/UCm-...3tiMt0KOg_2Aag Instagram: apexit_53 |
#1166 |
![]() Drives: 2017 Camaro SS Join Date: Sep 2017
Got a new to me daily driver ZL1 1LE that is going to be a "fun" lite prepped CAM C car. Vehicle currently has an axle back exhaust, coilovers, sway bars and intake
Future mod 1. Supercharger expansion tank 2. E50 tune Ran it against our Corvette that is basically a SSP car on Bridgestone's (Lite CAM S) and would have been .5 faster pax wise in the Camaro. However in all fairness the tires (first heat cycle) and execution definitely did not favor the Corvette. Definitely a fun car and shifting makes it challenging to execute right. Corvette - https://youtu.be/5mevjxEsejs?si=OUnQsam2UmrT57QK Camaro - https://youtu.be/C2xvTJbPp2Y?si=et57VOsZDwYRsg5C
Jeff Wong
ESP Camaro |
#1167 |
ZL1 1LE A10
E60 tune from New Era performance on a dynocom dyno with an AFE intake and axle back exhaust in 6th gear. 7th is 1:1 609 whp 666 wtq
Jeff Wong
ESP Camaro |
#1168 |
![]() Drives: SS 1LE Join Date: Aug 2024
#1169 |
Didn't get a baseline because we arrived with e60 but when texting him originally about what to expect baseline versus e60 tune with current mods, he said the following "Stock we see 500-520 on Eblend 580-600"
Jeff Wong
ESP Camaro |
#1170 |
![]() Drives: 2016 Camaro V6 A8 Join Date: Dec 2025
I ran a V6 (non-1LE) last year and am looking at tire options for next year. I currently have 20" wheels with some mediocre drift tires, but am looking to replace them with stock 18's to lower my costs. Since I'm not competitively classed in FS, I don't mind going to a non-stock tire size for CAM-C. I was looking at 235/40r18 V730s - I think all in I could be under $1k. Anyone else do something similar? Happy to hear people's thoughts.
#1171 | |
![]() ![]() ![]() ![]() ![]() Drives: Chevrolet SS 1LE Join Date: Oct 2019
I don't know much about the V730, except that nobody competes on it at the national level and yet it's not on the exclusion list for Street classes. So I'm assuming that means it isn't quite as fast as the best 200-treadwear tires. That may or may not be a big deal for you. They are really cheap though, and they are said to have long wear in comparison to the best. If you are serious about going to CAM, you'll want at least 18x11 wheels and 315/30/18 rubber. It will cost a lot, lot more, but without that you won't be in the hunt at all. You also will need a lot of suspension upgrades. OTOH, in the FS classing for Camaros, it looks to me like you could add the dealer-installed "Suspension Lowering Kit, 1LE Spec Supspension Package..." Either of those are probably a cheap way to bump up your autocross performance while remaining in F Street.
Matt Miller
2020 SS 1LE |
#1172 | |
Mostly echo Matt's comments about the V730 generally. They're not pointy end, but seem to be a really solid choice for someone that's looking to maximize value and fun over competitiveness by having reasonably decent grip and good wear. It sounds like your goal is to maximize the value side of the fun vs performance vs cost equation by having the most fun at the lowest cost possible and willing to give up the last little bits of performance on the far side of diminishing returns, but still want a TW200 class tire. If that's the case, I'll probably split with Matt there. I think the best value is probably going to be in buying a set of 18x10 or 19x10 wheels and running the 275s. The 235s on 8.5" wide wheels should be sharp and responsive, but will run out of grip very fast...and that's not fun. With a 10" wide wheel and 275s, you should get sharper, more responsive, and a lot more grip....and I think that will be a lot more enjoyable. It'll cost a little, but not huge, amount more.
clyde
#1173 |
Wider is always going to be faster for sure. It's just a question of whether to cough up the cash for another set of wheels or not, and whether to jump down the rabbit hole of CAM. I can see both sides of the argument, and it obviously depends on the OP's financial means too.
Matt Miller
2020 SS 1LE |
#1174 | |
Clyde hello! Yes I think we did talk. That's great advice that I'll consider. I definitely find myself running out of grip a lot with the 245s currently. I need to make a cost-benefit analysis if the extra approx $1k on wheel/tire is worth it vs extra seat time. I'll keep an eye out for cheap wheels on Marketplace. |
#1175 | |
Yeah I added up how much I spent on car stuff/AX last year and I'm trying to be much more disciplined this year. |
#1176 |
Went to a coilover setup in the rear and it's hard for me to distinguish if the coilovers or the tune on e60 has created wheel spin in 3rd gear out of corners . Whatever it is, the car last traction. I will say I used to have bad days in the Camaro with certain course designs but now with the power, it is like the corvette and you can't have a bad day in the Camaro
https://youtu.be/kb4VtRa-l_8?si=3RddPMQNzzmn7bsA
Jeff Wong
ESP Camaro |
