Old 07-11-2024, 09:08 PM   #99
XXX ZL1
XXX ZL1's Avatar
Drives: 2024 ZL1 M6
I usually stop 55-60 ish and have cracked 900 with 30's. Not leaning on combo hard so never pushed more E to see where it ran out.
2024 Riverside Blue ZL1 M6
Magnuson 2650R, NW 103, Roto Fab Big Gulp
Kooks 2 inch LT's, Stainless Works Legend NPP
THP Billet Valve Covers, Mighty Mouse Wild CC
Signature Forged 20x10.5/20x11.5, BMR springs,
BMR Cradle lockout, AAD Billet arms
2023 Vivid Orange ZL1 M6 - sold
2019 Riverside Blue ZL1 A10 - sold
XXX ZL1 is offline   Reply With Quote
Old 07-12-2024, 08:26 AM   #100
JSH
JSH's Avatar
Drives: '20 ZLE
Originally Posted by Katech_Mike View Post
I have no doubt that the Goliath will support more power than the current pump offering on the market even with an OEM fuel lobe. On a stock cam lobe ~5% gain over competitors pumps is what I would expect. This comes at a better price point, built to OEM standards, high pressure capability and plenty of room to grown in the future.
If and when I decide to do anything more to mine I'll need your pump or one similar. Mine is almost tapped out. When will they be in stock?
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 07-12-2024, 08:27 AM   #101
JANNETTYRACING
JANNETTYRACING's Avatar
you can preorder now they will ship in the next few weeks, the first batch of 50 is almost sold out.
I have a couple ordered.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 07-23-2024, 02:48 PM   #102
Katech_Mike
Drives: 2015 Camaro ZL1
We now have bundles listed with XDI injectors.
You can save a few hundred dollars ordering the Goliath and XDI injectors together.
Goliath & +30% - https://katechengines.com/i-30498322...or-bundle.html
Goliath & +50% - https://katechengines.com/i-30498323...or-bundle.html
Goliath & +70% - https://katechengines.com/i-30498324...or-bundle.html
Katech_Mike is offline   Reply With Quote
Old 07-23-2024, 03:00 PM   #103
JANNETTYRACING
Curious;
Will you will be providing calibration data for these pumps?
Are all these injectors in stock?
Old 07-23-2024, 03:26 PM   #104
Katech_Mike
Originally Posted by JANNETTYRACING View Post
Curious;
There isn't really any calibration data that needs to be supplied with the Goliath. The pump will operate with OEM settings. There are obviously some things that can be played with to get it to do different things but that will be left up to the individual tuner.
We currently have 8 sets of +30's, 2 sets of +50's, and are backordered on the +70's.
Thanks!
Old 08-09-2024, 07:52 AM   #105
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
Just installed my Goliath pump and XDI 30's on my personal car. I'll be ramping up the E content to see what it can do on the stock fuel lobe. Car was on E35 before and the high side was giving up. First rip on the Goliath and XDI's and pressure is stable at 3000psi.
Just ramped that content up to E60 to do some more testing.
As for tuning the Goliath I did make some minor changes, but from what I am seeing so far, you don't HAVE to change anything compared to the stock LT4 pump.
GM Gen V Calibrator
Old 08-09-2024, 08:04 AM   #106
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
Mods being installed-
Old 08-09-2024, 08:22 AM   #107
JANNETTYRACING
Thanks!
As a calibrator, I feel it is extremely important to get this right.
It is imperative that the Pump control strategy is calibrated for the flow of the pump or it can under or overshoot target fuel delivery especially during load transitions.
Yes there are Short and long term adaptive, but that doesn't mean we should rely on them.
No different than sticking a big gulp on and not tuning for it, Yes it will run with the LTFT taking over but it's not right.
We do this for Cam lobes, changing from an LT1 to LT4 pump, or an XDI twin LT1 or LT4 system.
So I don't see why it would be any different, when moving from an LT4 pump to a Goliath pump.
I would think that Stanadyne or whomever would include this information when producing these pumps.
Like injector calibration is included with injectors.
I am sure they know full well what this pump flows at every inlet pressure, solenoid opening time, fuel temperature etc.
Ted.
Old 08-09-2024, 12:51 PM   #108
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
I made some small changes in the fuel pump area specifically for the Goliath and it seems to keep the commanded vs actual high side pressure very close. Not any different than the logic you're used to when you change fuel lobes.
I am seeing a little extra movement in fuel trims in some area's but I attribute that to the XDI 30's and the Injector Density table needs some work to iron this out. I'm still making some changes here.
GM Gen V Calibrator
Old 08-09-2024, 02:07 PM   #109
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Does anyone think this pump would work with a completely OEM tune (on the fueling side) and be able to run full E' on a bolt-on-only car with a low-side only? E.G. - with OEM injectors, OEM fuel pressure-settings-tune, and an aux'-pump for the low side? I'm talking from the perspective of being stealth, visually, and tune-wise. I want to run a Maggie 2650 tune with only this pump, as far as fueling for E' goes (and the aux' pump, which is in stealth mode already).
'20 ZL1 Black "Fury"
Old 08-09-2024, 02:20 PM   #110
JANNETTYRACING
The answer is no,
And, You would hit the low side limits and injector limits before ever hitting the stock high side pump limits.
No reason to upgrade the high side pump unless you are willing to upgrade the low side and injectors as well.
Old 08-09-2024, 03:10 PM   #111
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
Looks like he's already got a Katech low side, so it's just a question of injectors, right?
Old 08-09-2024, 04:24 PM   #112
JSH
JSH's Avatar
Drives: '20 ZLE
The answer is no,
What are the best PIDs to look at to determine how much room is left in your OEM high side with 30+?
2020 ZL1LE A10.
