11-23-2022, 06:12 PM | #99 |
That was me. Whipple emailed me and said port was on their radar but the 3.0 blower was not yet set up for it. That said, I’m sure you could just drill the runners like Crawford Racing did for the 2.9 Whipple.
11-24-2022, 06:23 AM | #100 |
Drives: 2016 Camaro SS Join Date: Jul 2016
11-24-2022, 06:24 AM | #101 | |
12-03-2022, 01:49 PM | #102 |
Drives: 2018 2SS Join Date: Sep 2018
I should have mine by the end of next week from Whipple. I reached out directly and they sold me on the upgrade from the 2.9. It uses the existing belt drive and what appears as the same radiator with new hoses and pump location etc. I was also told they are in the R&D stage on producing port injection plates similar to TooHighPSI
2018 Camaro, Whipple Charged, RotoFab Big Gulp, Katech 103mm, LT4 Fueling w/ JMS BAP, GPI Drop in Rods and Pistons, Custom Cam, Ported Heads, Kooks LTHs w/ Green Cats and Mid Pipes, Corsa Extreme Mufflers, DSS Driveshaft & CV Shafts, Might Mouse Catch Can, Circle D T.C. #Team GPI
12-03-2022, 03:39 PM | #103 | |
2016 NFG 1SS A8
12-03-2022, 05:11 PM | #104 |
Negative, I am hoping to sale it shortly after the new install. Only downside is that it won’t be a complete used kit due to reusing the existing belt drive. Not sure what the market will look like for just a head unit.
12-04-2022, 09:12 AM | #105 | |
12-04-2022, 09:35 AM | #106 |
I’m running a 3.25 upper with the 7 lower making just over 7 at the wheels on lt4 fueling with a voltage booster. No E or Meth. Plan on making a comparison with the same combo then hopefully get more out of it with more fuel and some E.
12-04-2022, 09:56 AM | #107 |
Good to see they are getting some orders and shipping them out.
12-04-2022, 10:06 AM | #108 |
I believe the Whipple 3.0 is going to make a bit more boost with the 3.25 pulley vs the 2.9 from what I researched. Did the guys over at Whipple mention anything about that?
2016 NFG 1SS A8
12-04-2022, 11:21 AM | #109 | |
I also plan on doing some other upgrades as well but I will try to get that comparison.
12-04-2022, 11:42 AM | #110 |
Drives: 21 ZL1 Join Date: Feb 2022
Not sure why you'd want this over the 2650. The hellcat guys are having tons of issues with quality and failures. These new gen whipples are far less reliable and quality than the earlier gens.
12-04-2022, 06:43 PM | #111 |
Old badass
Drives: 14GMC 2.9 16GMC Turbos 2020Silv.6.2 Join Date: Mar 2020
Yeah I'm thinking I'm just going 2650 on my new ride. My other though has been almost 9 yrs on the 2.9 with no issues except for a vacuum actuator. Still all the stories I've heard on here makes my decision. Reliability and warranty after the sale is #1. No time for bs.
I've had 7 Camaro's. All gone...for now.
Current build in progress 2016 GMC4x4 RCSB twin hair dryers ~1k whp fbe port inj 1/8 mi & stealth street terror |
12-04-2022, 07:29 PM | #112 |
From what I have read Most Failures on the Hellcats are from over spinning them. 18000 rpm is what they are rated for which should produce around 19-20psi. Above that guys are snapping the shafts especially on manuals with solid pulleys. I believe HC's have decoupler pulley system offerings? The Hellcat guys are also having issues with the 2650 but it's rear cog driven. Honestly there isn't really a reason for them to replace the 2.7 for 95% of the setups. The ones that do are pushing the 3.0 24-25psi.
2016 NFG 1SS A8
Options-2SS Leather/NPP Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA Last edited by KingLT1; 12-04-2022 at 07:47 PM. |
