Old 05-03-2019, 03:58 PM   #99
YoungFamous
Amos6.2Jr
Drives: 21 A10 2SS 1LE
1LE’s Spec Fitments
Would the 1LE Spec Suspension fit with the ZL1 1LE Spec Handling Component Suspension Upgrade System together on a 2SS A8 Coupe, without the ZL1 1LE-Spec Multimatic DSSV® Lowering and Handling Suspension Upgrade System, or would those last two have to be combined?
Camaro Performance Upgrades (Suspension) https://www.chevrolet.com/performanc...aro/suspension
YoungFamous is offline   Reply With Quote
Old 08-13-2019, 08:12 PM   #100
Hyper1SS
Hyper1SS's Avatar
Drives: 2016 Hyper Blue Metallic 1SS M6 NPP
Originally Posted by vtirocz View Post
This is what I had for those strut/shock part #s, that come with the SS lowering kit (ie. spring/shock kit part # 84203549). I'd double check it though. These came from a GMPP marketing manager so should be accurate.
Front Right strut - 84004135
Front Left strut - 84004134
Rear Shock Absorber Both Sides – 84096556
One thing though: I'm pretty sure the 1LE springs and Lowering kit (84203549) springs are not the same, so be careful with mixing and matching parts.
Hello. I am looking for the break down of all parts in this kit for a 2016 1SS coupe.
2016 Hyper Blue Metallic 1SS M6 with body color hood vents, Silver broken 5 spoke wheels, NPP dual exhaust, Dark Night Interior Spectrum Lighting, Illuminated door sills plates.
Upgrades include: Roto-Fab intake, Mishimoto catch can, MBRP cat-back Race exhaust, TSP 1 7/8 headers, EFI E85 Flex Fuel, MRR M017 graphite wheels with Nitto N555 G2 tires, Goodridge stainless steel brake lines, Powder coated Brembo calipers, BMR suspension, Eibach sport springs, Emblempros fender badges
Order ID: TDHQMS
1100 on 01/07/2016 at Penske Chevrolet
6000 on 02/23/2016 Delivered to customer
Hyper1SS is offline   Reply With Quote
Old 11-28-2019, 05:39 PM   #101
wintertopdown
Drives: 22 Convertible V8 LT1
I am about to have my suspension inspected and possibly replaced. My ride is very bouncy over even small bumps.
wintertopdown is offline   Reply With Quote
Old 12-07-2019, 02:47 PM   #102
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
OP, Thx for this.
sub'd for reference
Old 12-08-2019, 06:12 PM   #103
Mountain
Mountain's Avatar
Originally Posted by ZLBlue View Post
For switching over from a FE4 setup on an 18' ZL1 to a FEA setup (ZL1 1LE suspension basically), do I need the ZL1 1LE Spec handling kit (84352119) alongside the DSSV kit?
Or just only go with the DSSV Multimatic that comes together as a kit (84352121), with the ZL1 1LE Rear Anti-sway Bar (84218218)?
Between FE4 and FEA, really just some bushings in the rear knuckles, the rear cradle bushings, the sway bars and DSSV dampers. So, no, just get the DSSV and, if you want, jump to the FEA rear knuckles or BMR joints.
Old 12-10-2019, 01:11 PM   #104
Alpha1BC
Alpha1BC's Avatar
Drives: 2017 1SS 1LE
Since I already have the 1LE rear cradles installed long ago (really stopped the weird rear flex when fully accelerating), I'll go with only the DSSV kit as you advised then. Thanks.
I might as go with the rear knuckles too to stop thinking about opening up the suspension again.
Though I'm confused with the formatting from what was mentioned of their part numbers on the first page of the thread, it's:
FE4 & FEA = 84258571 & 84258572 (So do I get both of these ones to put into my ZL1?
Assuming the FE4 and FEA info is accurate on the first page, that means that you already have the proper knuckle/bushing assemblies on your Camaro. The way the original post is written, those are the PNs for the LH and RH knuckles for both the FE4 and FEA suspension RPOs.
Edit: Just confirmed on a few different sites. GM has the same PN for the rear knuckle assemblies on 2018 SS 1LE (FE4), ZL1 (FE4), and ZL1 1LE (FEA). This means that the rear knuckle bushings should also be the same for all of those.
2017 SS 1LE.
Alpha1BC is offline   Reply With Quote
Old 12-19-2019, 01:31 AM   #105
YoungFamous
Amos6.2Jr
Zl1 to ZL11le suspension
What suspension parts from a Zl1 1LE are able to be put on a zl1? And all zl1s will work regardless of the year right? Cause 17 Zl1s aren’t compatible on Gmpartsdirect but 18s are for some reason
I’m trying to upgrade except for the DSSVs when I get my Z while keeping MRC
Old 02-27-2020, 02:05 AM   #106
MakCamaro
Makis
MakCamaro's Avatar
Drives: 2020 Red Hot ZL1 A10
Useful thread. Bumping it just to make it current.
Old 12-31-2020, 09:01 PM   #107
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
MODS This should be a pinned post
Old 01-08-2021, 07:08 PM   #108
mlee is online now   Reply With Quote
Old 01-08-2021, 09:04 PM   #109
carguy55
carguy55's Avatar
Thanks
Mods: MSD, Headers, 95mm TB, high flow cats, full 3" exhaust, SPL, MCS 2-way remotes, sway bars, rear diff lock outs, Sparco racing seats, 6 point harness, CMS roll bar, Nine lives wing, 6" splitter, ACS canards.
www.youtube.com/@Racer_Mike87
Old 01-15-2021, 06:59 AM   #110
carguy55
carguy55's Avatar
Interested in the differences between these parts FE4 vs FEA:
Front "Ride" Links. These are the diagonal lower front control arms
FE4 = 84051641 & 84051642
FEA = 84051643 & 84051644
Old 01-15-2021, 03:57 PM   #111
Mountain
Mountain's Avatar
Confused... you have a thread on these...
Maybe you mean between
FE2, FE3 = 84012305 & 84012306
and
Which would just be a difference in bushing durometer.
Old 02-12-2021, 03:02 PM   #112
foshjowler
foshjowler's Avatar
Drives: 2017 Camaro 2.0T, 91 Miata
FE2 to FE4 Sway Bars
Tried to read through the entire thread, and others, but there's a lot of info going every which way.
It looks like FE4 sway bars may be the stiffest of the bunch, and I have the tires to match, at least for autox. My daily Michelins won't be able to keep up but that's alright. My main question is if I order from GM parts direct does it include the mounting hardware too or do I have to order that separately? Also, will I run into problems with the plastic FE2 end links? I haven't been able to find a whole lot of info on them.
305 BFG Rivals FTW
Youtube Channel
foshjowler is offline   Reply With Quote
