Old 11-30-2018, 01:03 PM   #10333
KyBoy
KyBoy's Avatar
Drives: '17 2SS H50
Originally Posted by HartfordRacingCaptain View Post
I also have the shudder. I hope that this new solution does not nullify the fluid update. I would like to update the fluid, then immediately apply the flash as well.
I recently had the flush done on the wife's ride. The dealership knew nothing of the Q1 Fix. Although I "enlightened" them. I tend to do that .
They told me that if the shudder comes back, to bring it back and they will replace the TC.
When the Q1 2019 fix is released, I'm gonna push for a TC and the reflash. I feel the current TC has to have some wear if not damage.
Heath
1100 - 5/26
0000 - Cancelled - 7/5
Contacted Becky - 7/1
2000 - 7/5
3000 - 7/6
3000 - 7/11 TPW 8/1
3100 - 7/18 TPW 8/1
3300 - 7/20
3400 - 7/21
4300 - 8/3
5000 - 8/5
6000 - 8/13
Old 11-30-2018, 01:04 PM   #10334
HartfordRacingCaptain's Avatar
Drives: 2017 Camaro 1SS, 2023 Colorado Z71
I personally feel the flush will still be a part of this. Flush then flash. But I could be wrong. As I get more details I will be sure to share. Still waiting to see if it’s a TSB or Recall. If TSB I can snag it quicker than Recall.
Sadly i’ll have to wait untill april/may to have it performed, she’s asleep for the winter. But that should mean it’s guaranteed to be ready to apply when i roll out again.
2017 1SS, Summit White, Black 2SS Interior, MRC, NPP
2023 Colorado Z71, Nitro Yellow
HartfordRacingCaptain is offline   Reply With Quote
Old 11-30-2018, 01:23 PM   #10335
kpgreenwell
kpgreenwell's Avatar
Drives: 2017 50th anniversary edition v6 A8
Originally Posted by Kaizer_911 View Post Some possible info about the dreaded TC Sh
Yes, I also have the Shudder problem. I will also wait till spring to get this taken care of.
kpgreenwell is offline   Reply With Quote
Old 11-30-2018, 01:23 PM   #10336
craigss50
craigss50's Avatar
Drives: 2017 Camaro SS Fifty
This is very good news. Every time I drive my car I fear the issue will return. Maybe they will also fix the 1 to 2 shift problem with the flash.
craigss50 is offline   Reply With Quote
Old 11-30-2018, 01:41 PM   #10337
Kaizer_911
Kaizer_911's Avatar
I think this is an LT1 issue. 1st to 2nd gear can be touchy in my M6 and I can confirm the same in the C7 stingray with a M7.
But probably will make it easier for the A8 when shifting.
6000 - 07/08/16 | Club F1FTY
Old 11-30-2018, 09:59 PM   #10338
Martinjlm
Retired fr GM + SP Global
Martinjlm's Avatar
I know it's off-topic but do you happen to know if the A8/TC is used by other manufacturers? Our Jeep GC has an A8 and I'm noticing a slight shake running through 2nd gear under moderate acceleration.
Just curious before I start a dealership discussion. Thanks.
They are specific to the GM A8. The Jeep A8 was designed and engineered by ZF and built either by ZF in their S. Carolina plant or by FCA under license from ZF at FCA’s Indiana plant.
GM designs, engineers, and manufactures their own transmissions and most of their torque converters. I’m not 100% certain, but I believe they make their own TC for the A8.
Old 11-30-2018, 10:09 PM   #10339
RicSimonis
RicSimonis's Avatar
Drives: '17 2SS H50 Vert
Appreciate the info. Wasn’t sure but I figured it was worth asking.
Thanks.
Old 12-01-2018, 09:04 AM   #10340
2ssANT
how i get the fifty badge
2ssANT is offline   Reply With Quote
Old 12-01-2018, 09:08 AM   #10341
KyBoy
KyBoy's Avatar
Drives: '17 2SS H50
Which "badge" are you referring to?
Heath
1100 - 5/26
2000 - 7/5
3000 - 7/6
3000 - 7/11 TPW 8/1
3100 - 7/18 TPW 8/1
3300 - 7/20
3400 - 7/21
4300 - 8/3
5000 - 8/5
6000 - 8/13
Old 12-01-2018, 09:11 AM   #10342
2ssANT
Heath
how they have fifty under there username
Old 12-01-2018, 10:05 AM   #10343
KyBoy
KyBoy's Avatar
Drives: '17 2SS H50
Oh, I can't help there.
Heath
1100 - 5/26
2000 - 7/5
3000 - 7/6
3000 - 7/11 TPW 8/1
3100 - 7/18 TPW 8/1
3300 - 7/20
3400 - 7/21
4300 - 8/3
5000 - 8/5
6000 - 8/13
Old 12-01-2018, 10:47 AM   #10344
RicSimonis
RicSimonis's Avatar
Are you referring to the graphic/etc on the left side? That’s called an Avatar. Go to the top of the page and click “User CP”. Down the left side of the page there will be several options, one will be “Edit Avatar”. It’s usually a pic/graphic. Same goes for the signature graphic/text below. Hope this helps.
Old 12-01-2018, 11:01 AM   #10345
2ssANT
lmao i thought it was a badge on for this site if you own the car
Old 12-01-2018, 11:26 AM   #10346
RicSimonis
RicSimonis's Avatar
Uhm, yeah. THAT’S what it is. Special permission will be needed.......
I’M KIDDING!!
Pretty much whatever you want, within reason of course. There are some size limitations. Most of use have something F1FTY related.
