Old 09-10-2022, 06:54 PM   #85
ZR1-OK
Drives: 22 ZL1 23 1SS Redline
“ seat lever housing on top of seat was loose ”
Mine became loose when loading dog in the back.
Needed a shot of epoxy and it’s been good since.
ZR1-OK is offline   Reply With Quote
Old 09-12-2022, 01:33 PM   #86
ZX-10R
ZX-10R's Avatar
Drives: 2019 ZL1 Riverside
Originally Posted by ZR1-OK View Post
Yes - I only have 1600 miles and I’ve checked the level at least 3 times.
Doesn’t use a drop even after a buck fifty in Mexico
...and you probably drive it like you stole it instead of an easy break in - how else can anyone explain why some motors seal up much better than others, it's not factory tolerances, we know those are good
Moderately aggressive break in works, the canned language in most owner manuals is out of date
ZX-10R is offline   Reply With Quote
Old 09-12-2022, 02:06 PM   #87
Good luck with that line of thinking here I did the proper, as you say, "moderately aggressive" break-in and had zero oil consumption. My new forged internals were broken in by the shop, but the engine still doesn't drink much if any oil as far as I can tell.
Old 09-12-2022, 02:16 PM   #88
ZX-10R
ZX-10R's Avatar
These OEMs always prescribe conservative break in procedures because they don't want owners going nuts, but it's well documented most break in is done after about 10 heat cycles. Abrupt throttle, cool off, repeat - early oil changes - it's worked for me with many engines
Worst thing you can is cruise down the freeway at 70 in top gear - but I see it all the time
Old 09-12-2022, 05:57 PM   #89
minn19
minn19's Avatar
Drives: 22 ZL1, 20 Taco, 20 Cayenne S
Sorry for those that have this problem, I dealt with it on my both of my GT350s, one had its engine replaced because of it (was using a quart about every 80 miles at the end). A real pain in the rear end. Broke it in properly to.
I feel fortunate my ZL1 doesn’t use any oil. Broke it in mostly by the book and changed the oil/diff fluid at 500 and 1500. I have about 4100 miles on it now and have been getting on it a lot the last 1000 miles. It is still at the top of the dipstick from the 1500 mile oil change.
minn19 is offline   Reply With Quote
Old 12-18-2024, 08:28 AM   #90
libis22
Drives: 2017 Camaro ZL!
Originally Posted by NG329 View Post
I've dealt with this with two ZL1s.
The car isn't actually burning oil. The condition is oil 'blow-by' where it's seeping past the piston rings. Running the car hard resolves this to some extent as the piston rings mate with the cylinder walls over time.
In my 2019, I burned 2-3 quarts every 1,000 miles. After riding it very hard for about 7k miles I got it down to 1 quart every 1,000 miles.
Running it hard creates pressure in the combustion chamber that forces the piston rings into the cylinder walls and eventually filling all of the microscopic gaps in the mating surfaces. (hope I explained that correctly).
I am trying to fix it this way, either I will fix it or I will have a new engine.. which is caused by engine blow bye
libis22 is offline   Reply With Quote
Old 12-18-2024, 04:47 PM   #91
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
Run it like you stole it! When it gets thirsty give it a drink.
Old 12-20-2024, 09:44 PM   #92
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2021 zl1 a-10 WildCherry
WOW read this because I am just looking at Posts for a rare change, a PCV bypass may find its way into making your Camaro not blow so much Oil also, I run a elite E2x Ultra catch can, did not read all the post here....But I built a couple Fifth gens always used catch cans, and the LT 4 could use this.... https://www.mightymousesolutions.com...t4-pcv-adapter it may help alot for usage of oil, I may use a quart per change ; Direct injection engines are known for using oil BTW. Have my car now Having a BTR stage 2 cam and new 2650 installed with Katech Chain, oil pump , Long tubes and cats, DSX LID , boostapump, LME cover , Tunnions, NW 103 , Biggulp, etc etc Old timer here Just newer to the LT4
2021 Wild Cherry ZL1 A10, Sunroof, Data,Red Carbon Interior, Nav, RotoFab Big Gulp , Elite x2ultra, Borla ATAK, Driveshaft shop, BMR susp, Speed covers, intercoolers, ATI , 2650 MAG, DSX lid, 103 NW, TSP Longtubes & cats, LPE, 1le mods, ,LME cover, Katech pump and chain, Trunnions, BTR stage 2, LPE boostapump, Gforce, Speed eng , Granetteli, etc etc
christianchevell is offline   Reply With Quote
Old 01-26-2025, 06:19 PM   #93
libis22
I have a new to me 2017 Camaro ZL1 6MT which used 6.5 quarts (10W40 Mobil1 Supercar) of oil for 3319 miles I drove it- that's a quart for every 510 miles.. Car has 17552 miles now and I bought it from Carmax and I bought maxcare as well. I took it to Carmax under their 90 day warranty and both time they were like it is normal. I really didn't calculate the amount until recently and now I know it's an issue and may why the previous owner sold it to Carmax. I drive it most of the time around 2 to 4k RPM and haven't taken it to track, drag strip etc. So a mix of city plus spirited in 50% sport 20% track and 30% Touring... Car is 100% stock what I can see.. no clue about internals but I highly doubt it is touched..
I asked a local Chevy dealer and they told me they can do an oil consumption test. The person I talked said they would document the oil levels every 1000 miles. He also said to tow it to the dealership if oil light comes on and don't add oil as they want to document every additions.
Can someone shed some lights on their oil consumption tests and how it went? If they find it is not normal, do they fix it or replace the engine? Any experiences on dealing with Carmax Maxcare?
Old 01-28-2025, 12:23 AM   #94
Patriot Motorsports USA
Patriot Motorsports USA's Avatar
Drives: 2021 ZLE, C5 Z06 6.0L Procharged
Cool
A-Effing-MEN!!!! FINALLY. Someone who GETS IT!!!
When we break-in an aircraft piston engine... you run it at WIDE OPEN THROTTLE until the oil temp stabilizes... then change the oil.
When we break-in the F1 Tunnel boat Mercury Racing 2.0 & 2.5L V-6 Outboards that produce over 300hp NA... we do it at WOT!!!
When most people buy a ZLE... they pu$$y-foot around for 500 miles and then complain about spending more money on oil.
My first ZLE had 13,000 miles on it when I bought it... I changed the oil from the Mobil1 junk to Amsoil 15w-50 and let it eat!! First weekend trackday and it took 1.5 qts. Changed the oil the next day... next trackday weekend less than 1 qt consumed. Now she has just turned 30K miles and after removing the OEM oil cooler, fixing the over-fueling issue that was washing the cylinders with raw fuel that could be seen by my rear bumper GoPro every shift thru WOT... ZERO OIL CONSUMPTION in over 1500 miles of driving on the street and two trackdays. SHOCKER!!
So I just acquired a 2019 ZLE shop car that has 15K miles and had the engine and supercharger replaced 1888 miles ago under warranty. So essentially I have a virgin LT4. I plan an extensive amount of video updates on my YouTube channel to log all the data... Stay TUNED!!!
Patriot Motorsports USA is offline   Reply With Quote
Old 01-28-2025, 08:33 AM   #95
cdb95z28
cdb95z28's Avatar
I agree, the owner's manual break in is to satisfy the lawyers. Run it hard, but don't abuse. Don't decel from high RPM. Change oil that first time well before the "monitor" tells you. 500 miles. I bought both my Gen5 SS 1LE and my current '22 SS 1LE new. Broke them in hard. Both will go thru a full track day weekend without using any oil. Lots of street use too, no consumption. Catch cans only have about a tablespoon in them over many thousands of miles.
"KEEP THE FAITH"-Fbodfather
Old 02-03-2025, 09:41 AM   #96
Bangkok_ZL1
Flying around Thailand
Bangkok_ZL1's Avatar
Drives: 2019 Camaro ZL1
Originally Posted by OutlawV2 View Post
Ok so I have a 2018 ZL1 1LE. Currently has 21K miles. I purchased the car with 9k miles back in November of 2019.
When I left dealership car was fully serviced. Oil change light came on at 15,000 est miles.
Cause oil burning at this rate is motor death as far as i understand... And I want to know early if I'm going to need to get a free LT4...... thought's opinions???
Just cleared my MM Wild. 3000 miles (5K Kms) got close to 1/2 cup out of the catch can.
Mods - From JRE, the 125 RWHP Kit; From FI Interchillers, the Stage I Interchiller system, 5mm Supercharger/Head spacer plates, Heater blanket; From BMR Suspensions, Motor mounts, Cradle lockout Bushings; From Misc, Train horn in the Abandoned Heat Exchanger location using the exchanger bracket. From Banks, An I-Dash to read it all...
Bangkok_ZL1 is offline   Reply With Quote
