Old 08-29-2022, 02:08 AM   #85
Mac7504
Mac7504's Avatar
Drives: 2003 Monte Carlo SS SLP, 2022 ZL1
I love this site for all its knowledgeable members and community, but shit if you guys don't give me anxiety about stuff I didn't know were problems on these cars. Oil pump, carbon fiber insert clear failing, and now this. Lol.
I'm doing my best to control my ocd and not look for problems because I know I will find them but this doesn't help but at the same time does.
Mac7504 is offline   Reply With Quote
Old 09-07-2022, 06:34 AM   #86
dormeas
Drives: 2023 Camaro SS 1le
Thought I would share my experience with my 2023 1ss car so maybe it will help someone else.
Picked up my car and noticed that the passenger side rear corner of the lower rear bumper facia was not flush to the fender. This was the corner right below the tail light. I found this thread and thought maybe it was just heat but had a feeling something more was going on because I couldn't physically just push the bumper into place.
So I ended up taking the bumper cover off last night and found that the rear most plastic tab on the passenger side of the bumper cover was underneath the hook on the body, instead of on top where it should be. It appeared the factory just didn't see it was in the wrong place and pushed all the other tabs in leaving that part sticking out because the tab couldn't go in any further.
Just in case anyone else has this issue, the bumper still fit with just about 1/8 inch gap so it was hard to see what was going on.
dormeas is offline   Reply With Quote
Old 09-07-2022, 06:49 AM   #87
Booher
Booher's Avatar
Drives: 2019 zl1 6 speed
My 17 ss a tab was under and not connected as well under the tailight. Can't get to it on the 19 to see tho
Old 09-07-2022, 04:33 PM   #88
rlarsen462
Sell Low, Buy High
Drives: 2022 ZLE, 2023 ZLE (Inbound)
On a 23 (or a 22 ZLE in my case), you have to remove the entire bumper to even get to the point where you can see if this is the issue or not, right? There's no way to even see in there and see if you have this problem because the taillights can't be removed without taking the bumper off?
rlarsen462 is offline   Reply With Quote
Old 09-07-2022, 08:10 PM   #89
dormeas
Yeah sorry, I wasn’t very clear. So the issue was the rear most tab on the side of the car, not the rear of the car. When I said below the tail light I meant just in front of and below the quarter panel.
I was able to just remove the screws and pull passenger side of the bumper cover loose, move the tab up, a push it back in place.
Old 09-07-2022, 08:27 PM   #90
SATINSTEEL1LE
Drives: 21 ZL1
When it heats up in the sun it’s going to back out again and you’ll be doing this all over.
SATINSTEEL1LE is offline   Reply With Quote
Old 09-07-2022, 08:55 PM   #91
The Maverick
Somewhere in the Kalahari
The Maverick's Avatar
Results of the zip-tie fix will vary. My car was parked outside in the sun all day and it got up to 110 degrees here. Trunk opened and closed just fine.
Old 09-11-2022, 08:37 PM   #92
HoodCheck
HoodCheck's Avatar
Drives: 2018 ZLE (M6/hyper blue)
I ended up doing this fix as well. Bought some 250lb zip ties, only to discover they were just *barely* too wide for the openings. I did the driver side first, no issues aligning it and getting it set into place (I ended up using 2 45 lb zip ties on 2 tabs, and 1 on another tab)....although the passenger side ended up popping out even further after fixing the drivers side, so with that one, I had to press in while pulling a couple of pre-prepped zip ties with pliers to get it to *mostly* align. Its not bad, but its not perfect.
In hindsight, I think it mightve gone smoother in my case if I had 1 person pressing in on the other side too at the same time when doing the first side (so the pressure is already on the bumper). I might go back and redo it at some point, but its still far better than it was, so maybe not.
Current: 2018 ZLE (M6/hyper blue)
Former: 2014 Z/28 (red hot); 2017 ZL1 (auto/white); 2015 Z/28 (black); 2016 2SS (auto/hyper blue); 2012 2SS (45th anniversary/auto); 1994 Firehawk (auto/dark green); 2005 GTO (M6/blue on blue); 1999 Camaro SS (M6/pewter); 1994 Z/28 (auto/blue); 1991 Firebird (auto/red); 1988 IROC (auto/copper metallic); 1983 Camaro (auto/blue); 1981 Firebird (auto/maroon/350 Olds swap)....the list goes on...
HoodCheck is offline   Reply With Quote
Old 09-11-2022, 09:31 PM   #93
My ziptie fix that I did back in 2018 is still holding up, the gaps have nearly been eliminated on both sides.
That said, the official fix for 2016-2018 cars is TSB 17-NA-336, see at https://static.nhtsa.gov/odi/tsbs/20...34617-9999.pdf (the only problem with this is that the bumper must come off, which is tricky as it's very easy to break off a flimsily attached plastic retainer plate in the center, under the trunk latch, ask me how I know).
Old 09-12-2022, 01:36 PM   #94
HoodCheck
HoodCheck's Avatar
Oh sweet, thanks!
Old 08-03-2023, 03:09 PM   #95
wintertopdown
Drives: 22 Convertible V8 LT1
Similar issue yet my camaro was rear ended and while it was repaired quite well, the rear bumper now squeaks while I drive and the gap has grown. I am still under my 36k warranty, what does anyone suggest I do?
I bought my first 6-Speed convertible Camaro in November 2018 and now drive a Hot Red V8 LT1 M6.
My Windows Sticker: https://cws.gm.com/vs-cws/vehshop/v2...FE3D78N0129849
wintertopdown is offline   Reply With Quote
Old 08-13-2023, 06:53 PM   #96
triggerjerk
Drives: 2023 Camaro ZL1
My 2023 is doing this as well. Is there any fix that works?
triggerjerk is offline   Reply With Quote
Old 08-26-2023, 10:05 PM   #97
Bangkok_ZL1
Flying around Thailand
Bangkok_ZL1's Avatar
Drives: 2019 Camaro ZL1
I have this issue also. I'm preparing to tear down my entire ride and put in Jannetty's 125, F1 interchiller, and lots of other stuff, plus some cosmetic things. I will definitely add this to my list while she's on the blocks. Thanks for posting this.
Bangkok_ZL1 is offline   Reply With Quote
Old 07-02-2025, 11:16 PM   #98
AllYourBaseRBelong2Us
Drives: Camaro Zl1
My 2023 has the same issue, however, both front and rear bumpers…and the rear view camera/fin isn’t attached properly. Per dealer there is missing adhesive from the factory (bumpers), which caused the panels to start separating. They said the problem will worsen with time. New bumpers are on order…which need painting and install. Headliner has to be removed to access screw attachment for camera fin. Looking for my brown pants…
AllYourBaseRBelong2Us is offline   Reply With Quote
