#85 |
Limitless Imagination
Drives: 2018 ZL1 & 2022 Hayabusa Join Date: Dec 2016
Thank you CRBWS6 for bumping me to update the thread on the ET lugs...
I did try the ET lugs. They do NOT fit through the openings on the MRR M017s. They DO fit in the lug openings on the OEM ZL1 wheels though. I'm not sure why the lug openings on the MMRs are smaller on them vs OEM. The part that sucks the most of this news is can't use the ET lug nuts to more than 5mm of offset safely, least without the effort of replacing rear studs.
2018 Camaro ZL1 - Black
- OEM Options: A10, Exposed Carbon, PVR, Nav, No Sunroof - Lightly Tinted GM Dark Tails, DD Side Markers, Morimoto 5000k, 100% LED - RotoFab Dry, Forgestar CF5V (ZLE Spec), Eibach Pro, AeroForce Interceptor, GT4 Tow Hook - Carbon Fiber (Satin): Radio, Shifter, Steering Wheel Controls, Shifter Top, AC Vents, Side Mirrors & Shark Fin 2022 Suzuki Hayabusa - Brilliant White Pearl & Shocker Yellow Wheels - +4 Arm, 240 OEM Wheel, Brock's CT (Ti) Exhaust, 1.25" drop, etc... |
#86 |
![]() Drives: 18 1SS 1LE SCCA FS, 99 WS-6, E46 M3 Join Date: Dec 2017
FYI - I fitted the ET lugs on my OEM wheels with an 8mm spacer. Got 8.5 turns. I can also verify these do not work for MRR 716's.
Overall, this is a nice solution.
#87 |
![]() ![]() ![]() ![]() ![]() Drives: 2018 1SS 1LE Join Date: Feb 2017
I had a non ARP extended front stud I installed back when the ARPs were unavailable break. This was while checking lug torque right before heading out on track at COTA. Ruined by very expensive weekend. I have the ARP installed now and will carry spares.
What I use to change front studs: 4lb sledge hammer Impact gun Impact socket spare lug nut to cover end of stud Torque wrench (150 ftlb min capable) Lisle Wheel Stud Installer 22800
Mods: MSD, Headers, 95mm TB, high flow cats, full 3" exhaust, SPL, MCS 2-way remotes, sway bars, rear diff lock outs, Sparco racing seats, 6 point harness, CMS roll bar, Nine lives wing, 6" splitter, ACS canards.
www.youtube.com/@Racer_Mike87 |
#88 |
Geoff
Drives: 2022 SS 1LE Join Date: May 2013
carguy, do you run ARP studs on the rear?
