#85 |
![]() Drives: 2017 Camaro 1LE SS Join Date: Oct 2016
Tracked my 1LE with stock pads and stock fluid one day at Nola and two days at Barber. No issues what so ever. I now have 9300 miles and I drive it REALLY hard on the street. By the looks of the pads I might be able to get another track day out of them but I'm changing fluid and probably front pads before my USCA event in Nola April 22-23. Think I'm going with Hawk DTC-60's.
#86 |
Did you bed your brakes per the GM recommendation before you tracked it? If you did it as stated by GM that grease should have been long gone. Just sayin.
#87 | |
![]() Drives: 2019 ZL1 1LE Join Date: Feb 2017
Just sayin.
Old: 2017 SS 1LE
Old: 2017 ZL1 Current: 2019 ZL1 1LE |
#88 | |
#89 | |
Old: 2017 SS 1LE
#90 |
![]() ![]() ![]() ![]() ![]() Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold) Join Date: Nov 2016
Here's a review about Power Stop Track pads and Carbotechs. Apparently, he had a similar experience with Carbotechs :
http://www.camaro6.com/forums/showthread.php?t=490018
#91 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
Does 1LE come with stainless steel brake lines?
#92 |
![]() Drives: 2017 Hyper Blue 1LE Join Date: Dec 2016
no
#93 | |
![]() Drives: 17 SS 1LE Join Date: Jun 2014
Definitely report back on the performance after the weekend. I've used Carbotechs in the past and just had too many problems with them. This could be a cheap alternative. |
#94 |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
Yup will do. I got the car back, had time to flush the brake fluid and put the PowerStop pads in and bed them in last night. With a bit of heat they have a higher mu than the stock Ferodo's. I'll give some detailed feedback after the weekend.
#95 |
those Power Stop pads might be good and cheap option for street use but I would not trust them for track days. I've read a few reviews and it seems like they start fading very quickly and the pad life (when tracked) is not that good.
#96 |
Hot Dog
Well if I don't reply on Monday then I probably died in a hellacious fireball of death and destruction.
#97 |
https://www.corvetteforum.com/forums...ds-review.html
Thor142 has been having great results using them also |
#98 | ||
