Old 10-08-2015, 06:54 AM   #85
laborsmith
Drives: 1969 Corvair, 2018 Camaro T4 RS
Several benefits which may cross over to the Camaro, including above. As Chevy does it, the highly restrictive intake is replaced by a much less restrictive filter, which allows the sound of the intake to be heard. It also encloses the system in a heat shield box to reduce the impact of engine temperature. The reason a calibration is included is the ecu is designed for the restrictive intake and will dumb down unless told to do otherwise.
Laborsmith
laborsmith is offline   Reply With Quote
Old 10-08-2015, 07:52 AM   #86
SpeedIsLife
Drives: Current Camaro-less
Will the intake get a CARB certificate?
I know open top elements generally do not gain their approval.
Old 10-08-2015, 08:09 AM   #87
laborsmith
GM will be 50-state compliant.
Laborsmith
Old 10-08-2015, 09:01 AM   #88
jessicaavail
jessicaavail's Avatar
Drives: Black 2014 Camaro 2SS
I ordered the 6 pistons...ya'll really think they would send red calipers and leave the back ones grey? Asked my dealer before I even checked them on my order and he said he din't think they would have red ones on the front and grey on the back but I'm concerned now. Don't care if the slotted rotters are only on the front but I do care if my front and back calipers are different colors.
Ordered: 2016 2SS A8 Red Hot w/ Adrenaline Red Interior;
NPP, MRC, 6 Piston Upgrade, Black Split Spoke, Black Bowties
3800 Status - 10/14
jessicaavail is offline   Reply With Quote
Old 10-08-2015, 11:09 AM   #89
newb
newb's Avatar
Drives: 2013 1LE
If I'm not mistaken, the 6 pots are dealer installed. Meaning, the rear will be original factory grey, and the fronts will get changed to the 6 pots at the dealer.
It's a Dingledarm. It's there to dampen side fumbling. If your marzelvanes fumble too much they can cause total protonic reversal. It gets ugly from there. This is really the biggest problem with the new Camaro. That and the tri-pronged blivot.
Delivered 21 Jan 2013
newb is offline   Reply With Quote
Old 10-08-2015, 11:19 AM   #90
SpeedIsLife
Correct, the 6 pots are a LPO and are dealer installed
Old 10-08-2015, 01:14 PM   #91
Memphis43
Memphis43's Avatar
Drives: Chevy
Sucks don't it. Looks like someone will need to change their order or make use of some spray paint
Memphis43 is offline   Reply With Quote
Old 10-08-2015, 08:56 PM   #92
02v8ta
Drives: LS based beauties
I want a Video of the performance exhaust.
Even though no matter what I'll probably end up with one of the big name aftermarket ones.
Planned order; Summit White 2SS, NPP Exhaust, Adrenaline Red Interior, Auto 8, 20" 5 Split spoke black, darkened fish tail lamps.
02v8ta is offline   Reply With Quote
Old 10-08-2015, 09:33 PM   #93
GTIanZ28
Drives: 2016 V6 RS Camaro 6MT
One thing I don't get. They were so worried about the weight of the car but, that suitcase muffler looks very heavy.
Anyone want to venture a guess at cost?
Figures that right after I added the NPP exhaust they announce this. Granted I like the idea of dual mode so I have no intentions of switching my order.
Anyone think a company will come out with aftermarket mufflers that will still work with the NPP exhaust?
Summit White 2LT RS V6 ZN2 NPP m6 khalihari interior. Order placed 9/26/15 - Picked up 12/17/15!
GTIanZ28 is offline   Reply With Quote
Old 10-08-2015, 09:54 PM   #94
joemosfet
joemosfet's Avatar
Drives: 2014 Camaro SS
The demand is there, but I worry that welding will be required, so there might be a core exchange on the actual solenoid.
I base this all on this picture, so my worries could be completely unfounded. But it certainly seems like the butterfly housing is welded in.
SOLD: 2014 Camaro Coupe 2SS/RS M6 Blue Ray Metallic, NPP, Nav
2014 Stingray Premiere Edition Coupe #142/500 Z51 3LT M7 Laguna Blue, Magride, NPP, Exposed Carbon Fiber Roof, Carbon Fiber Dash, Suede Wrapped Interior
Canceled: 2016 Camaro Coupe 1AK37 2SS Coupe, G7E Garnet Red, BRJ Adrenaline Red Trim, F55 Magnetic Ride, NPP Exhaust, CF5 Sunroof, 56R Gray Split spoke w/ machined face, RN2 LPO Illuminated Bowtie, VYW Premium Floor Mats, W2D LPO Cargo Net
joemosfet is offline   Reply With Quote
Old 10-08-2015, 10:01 PM   #95
ilirg
ilirg's Avatar
Drives: 2011 Camaro 2ss
I'm betting it isnt nearly heavy as it looks
ilirg is offline   Reply With Quote
Old 10-08-2015, 10:24 PM   #96
GTIanZ28
I had looked at pictures previously but I didn't notice that the solonoids were on the 2 extra exhaust tips. Makes sense that they would have to be once I stop and think about it even a little bit.
For some reason I was thinking it was before the muffler. (Which makes no sense at all.)
Yeah.... Developing an aftermarket system to work with NPP that improves on the existing system is going to be extremely difficult. Think most systems will eliminate or exclude NPP functionality.
Old 10-08-2015, 10:43 PM   #97
joemosfet
joemosfet's Avatar
You might have been thinking of these guys:
Which, I believe, are light spring-loaded butterflies which close when the engine switches down to 4-cyl mode, to provide a bit of backpressure and perhaps to eliminate some drone due to AFM. I think all of the V8 exhaust systems have these, not just NPP.
Old 10-09-2015, 11:39 AM   #98
02v8ta
I Believe Borla made one for the C7, while corsa said nahh.
Wonder if anyone could confirm if they have plans on doing so with the Gen 6 or not. I Loved my Borla cat back on my 2002 Trans am
