#71 |
![]() Drives: 2023 Camaro ZL1 Join Date: Jan 2023
Interesting information, that made me look up my renewal due 6/23/24. I have Progressive as well, comp went up $3 and collision up $24 for six months. Must be a regional adjustment?
2023 Camaro ZL1 6MT Summit White
#72 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
It's always rather unexplained, I don't think theft in Kansas City is like LA and elsewhere on ZL1's but who know's. Last I checked lexisnexis and verisk they had no data on my so OnStar wasn't spying that I could tell.
My Girls Jeep went up $1 LOL. |
#73 | |
![]() Drives: Chevy Camaro ZL1 1LE Join Date: Aug 2023
I'm Apple. We put an Air Tag in my teenager's car (our car, they are a minor) connected to my wife's phone. I get notifications on my phone that an Air Tag is near me when I drive it. Two words of caution, the accuracy and frequency the tag sends data is dependent on other mobile devices in proximity, so there may be gaps in data. Also, there is a delay, it can be a day or two before you get the notice. |
#74 | |
![]() Drives: 2018 NFG ZL1-1LE Join Date: Jun 2018
One thing to add. If you are using an air tag for theft prevention/theft tracking, remove the speaker out of the air tag. There are YouTube videos showing how. This will eliminate the ability for a thief to try and ping the air tag to make noise to find it's location. They will know there is one with them but will not be able to easily find it if you hide it well. |
#75 |
![]() ![]() ![]() ![]() Drives: 2023 ZL1 - Beast Build Join Date: Dec 2022
I received my locking bollard today and will start the install soon. I'll post a thread with photos when I do so. Although I don't think I will drive my car and leave it somewhere unattended (I haven't yet). I'm planning on implementing something like the below (not listing details). But key fob, reprogrammed key fob, scanned hacked fob or not. If the car isn't getting fuel, it can't be stolen and driven away! At that point, the only way the car will be stolen is by a tow truck !
https://www.camaro6.com/forums/showthread.php?t=624913
Katech Track Day CAM 38%•BTR Dual Valve Springs-Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Ported Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper & ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI Interchiller Stage 2•THPSI Port w/875cc Inj•Dual Drop In Fuel Pump•DSX Aux Pump•Stainless Works 2" w/Legend NPP Axle Back•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout/Bushings Kit•DSS Chromoly DS•RPM 8-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
#76 |
![]() Drives: 2015 Corvette Stingray Join Date: May 2019
For anyone coming to this thread to maybe see some theft deterrent ideas for their vehicle. The Bluetooth throttle controller by Soler Performance is great. Just plug it into your accelerator pedal and turn on the lock feature via the Bluetooth app. The car still turns on but the throttle is completely locked. Just another added layer to make someone think "What in the world" and hopefully move on to the next.
Here is the link to it if anyone is interested. Also use the discount code SALE5P, which is good until the end of the month. https://www.solerengineering.com/gen...tors/se0525-tc |
#77 | |
#78 | |
Probably doesn't like you
Drives: 2022 WCT ZL1 M6 Join Date: Jun 2015
That said, even at idle our cars have enough TQ to get moving without hitting the pedal, but every layer is helpful.
كافر ΜΟΛΩΝ ΛΑΒΕ железобетонное очко Quod gratis asseritur, gratis negatur. There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly. |
#79 | |
![]() Drives: chevrolet camaro Join Date: Aug 2019
Last edited by LORDOBERON; 06-29-2024 at 10:50 AM. Reason: added more information |
#80 | |
Somewhere in the Kalahari
Drives: 2021/18 (de-fresh) 3LT RS Join Date: Dec 2017
I think someone wanting to make a quick getaway would instead abandon the vehicle if they made it past the other countermeasures. And - for the jokers out there - the Lock setting might be good for a laugh when you offer to let someone "try out" your ZL1! "Make sure to take it real easy on the gas pedal!" |
#81 | |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
Mods being installed- oil pump, cam, ported heads, dual in-tank, Goliath and XDI, corn, etc., etc. |
#82 | |
How many places did you find suitable for the install? I took a long hard look at it, and was going to order when until I talked "my guy" (who's done 2 Audi's and an Infiniti for us). Looked completely doable.
#83 | |
fo'shizZL1
#84 |
“Just tear the interior apart” Yowwww!
