| View Poll Results: Have you experienced partial or full oil pump failure in your LT4 powered vehicle? | |||
| Yes, chevrolet serviced it and warranted the work |
7 | 11.11% |
| Yes, chevrolet denied warranty service |
3 | 4.76% |
| Yes, I had it fixed but not by chevrolet |
5 | 7.94% |
| No |
48 | 76.19% |
| Voters: 63. You may not vote on this poll | |||
Thread Tools |
#71 |
Sarcasm loading --------
Chevrolet screwed me repeatedly and I was left with a bad taste in my mouth.
We all spent 60-80k for these cars. probably more than half of the early years will grenade if the pump isnt changed. some of the newer ones will also. I know of a 22' ZL1 with a failed pump. Fact is, its a shit design. GM knew about it and its also mentioned repeatedly across all camaro forums I've seen, which probably only accounts for maybe 15-20%? of the ZL1 vehicles sold. They should be hammered. But, we are the ones who will pay through the nose to fix thier f*ck up then line up for the next raping.
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE 2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD 2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD |
#72 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
#73 | |
The engine in my $75k car needed rebuilt at 15k miles due to factory defect.
#74 |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
What is this oil pump failure you speak of? I'm unfamiliar. Unrelated, check out this picture I took a few weeks ago.
Mods being installed- oil pump, cam, ported heads, dual in-tank, Goliath and XDI, corn, etc., etc. |
#75 |
That is it. it will slowly break away all the pump vanes.
#76 |
#77 |
![]() ![]() ![]() ![]() Drives: 2018 ZLE Join Date: Feb 2018
In my opinion I don’t care what year it is I would change the oil pump to a katech. I just read about a 2023 that failed. They are essentially the same pump with updated materials. They are still prone to failure. Regardless of this poll most owners are not on this forum. For around 4K you can make your car bulletproof with a upgraded pump or end up like this poor guy that will have to spend thousands of dollars to repair.
#78 | |
#79 | |
#80 |
![]() Drives: 2017 ZL1 HBM, M6 Join Date: Oct 2016
If this issue ever goes to a class action lawsuit, I'm in!
#81 |
It's hard for me to imagine that GM is liable for a part failure in an eight-year-old auto.
2020 ZL1LE A10.
LME LT4 390 short block, CID Heads, Kong E2650, FBO. 15" conversion, Nitto 555Rii or MT ET Street R or Toyo Proxes RR. 100 octane: 1045hp/1055tq. 100 octane + Alky MAF Meth (1) 10+: |
#82 |
Long first post says the pump failed while under warranty but they said drive the shit out of it. Then when the motor blows up they say f-you
#83 |
fo'shizZL1
Where did you land? Did you build it with a new motor on your own dime?
#84 | |
dealership said they would not touch it unless they were swapping in a crate motor. chevy said they could pay 20% of it. I was like Fu, you need to pay for all of it. they said but you tracked the car. I contacted a huge amoutn of legal firms, and not a single one would do anything. at that poijnt I gave up. I had wrath rebuild it with a cam. All in it ended up costing me about 20k, so I have a camaro that cost me over 100k before 20k miles.
