Old 07-21-2023, 12:42 PM   #71
cdb95z28
cdb95z28's Avatar
Does the ABS module take suspension travel as an input? If so, how about the influence of a lowered car to the OE ABS cal? Did the car not have it's rubber suspension bushings timed to the new static ride heights? We gotta look at all these variables, whether small or large, and how they affect the entire package.
"KEEP THE FAITH"-Fbodfather
Old 07-21-2023, 04:01 PM   #72
GunMetalGrey
GunMetalGrey's Avatar
Drives: 2018 ZL1 (SOLD) 992 GT3 (current)
Yeah, I have no idea, my car is lowered slightly, but I did reset the sensors, but I have no idea how that all works together in concert
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
GunMetalGrey is offline   Reply With Quote
Old 08-15-2023, 02:50 PM   #73
GunMetalGrey
I thought I would post is here as well just some more people can see it and we’ll see it
My 2018 ZL1 accepted the brake module from the 2020 ZLE with no error messages or codes.
This should mean that if ZLE’s truly have no ice mode issues then my car should no longer either.
Most importantly, this should mean that everybody else can do this to their car as well instead of having to sell their car and buy a different model, or change the driving style severely or forgo modding and upgrading in their car to make it faster
I’ll be testing the car at the track this Friday, August 18 and will report back. So far every time I’ve been to the track it has only taken a half a day to have icemode, so if I have an entire day at the track with no ice mode, I will consider it a success.
(Note I already have a 2019 ZL1 brake module in my 2018 and it did not make a difference regarding ice mode)
Old 09-03-2023, 02:59 AM   #74
GunMetalGrey
Confirmed ZLE braking module does not fix the issue, it may reduce the severity of it, but it does not completely Get rid of it
Old 07-29-2025, 10:08 AM   #75
Baddawg53
Drives: 17 hyper blue 2SS M6
I've finally gotten my hands on a 2020 abs module that matches my car (hopefully). For those who have swapped these, were you able to just swap the controller in the car or did you have to remove the whole pump, bleed the brakes etc? Hoping to save myself some time and not open the brake lines
Baddawg53 is offline   Reply With Quote
Old 07-29-2025, 10:36 AM   #76
cdrptrks
cdrptrks's Avatar
I swapped just the controller module in the car but it is tight. I did a write up of the steps here: https://www.camaro6.com/forums/showt...0#post11248660
Old 07-29-2025, 10:43 AM   #77
DaveC113
DaveC113's Avatar
Drives: 2018 Camaro 1SS 1LE
I just exchanged the electronics, did not touch the brake lines at all. If you have the right tools it'll take you 20 min, it's a bit of a pita to get to.
My car required a reset after, dash lit up with warnings.. it just took a drive around the block. Another person who did it pulled the ABS fuse first and the car didn't reset, that might be the best bet, idk... My car seemed to reset to 2019 software too, settings for the rearview camera popped up and it wasn't even an option in '18, lol.
I will say my '19 EBCM has eliminated ice mode for me, even running a square setup no more hard pedal.
Old 07-29-2025, 10:47 AM   #78
Baddawg53
Thanks for the link, not sure how I missed that!!
Nice to hear some positive results from the swap!! Really hoping I see the same, be great to trust the brakes will be there!!
