Old 03-24-2023, 10:53 AM   #71
Mark R
Drives: 2018 ZL-1
Originally Posted by willzilla View Post
Man this reminds me I STILL have all of my BMR stuff sitting on my workbench waiting for me to install, LOL...
Wow. You have the whole package. I would like to hear your thoughts on how your car works after installing all that at once.
BMR recommended rubber boots for the toe rod ends. I got mine from Summit Racing. I can't remember the part #, but BMR knows.
Old 03-24-2023, 02:11 PM   #72
AZIROC
Drives: '86 IROC-Z '18 ZL1
I did a search and saw these recommended.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
https://www.summitracing.com/parts/sit-rers36pk
Also saw some people using this spray.
https://www.wd40.com/products/spray-gel/
Old 03-26-2023, 08:34 AM   #73
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
Got my kit in yesterday. The only issue i had was the front wouldn't drop quite enough to get the upper piece in there. Not too hard about an hour.
WhiteMale is online now   Reply With Quote
Old 03-27-2023, 10:08 AM   #74
clg82
Drives: 2020 Camaro ZL1
Originally Posted by WhiteMale View Post
Got my kit in yesterday. The only issue i had was the front woukdnt drop quite enough to get the upper piece in there. Not too hard about an hour.
Were you able to do one side at a time, or did you do the front first and than the rear?
Old 03-27-2023, 10:17 AM   #75
WhiteMale
I did the fronts and then the rear. I had to use a pry bar in there to push down the cradle about a 1/8" to get that front upper in there.
Needed a punch and hammer to get the "bullets" in that other bushing. Greased them up and they'd go about half way, had to hammer them in with a 10" socket extension.
So far the kit feels great. I also put in the BMR non-adj rear sway bar, adj end links, and topped it off by putting on my summer wheels and tires.
Old 07-06-2023, 05:40 PM   #76
Spaceme1117
Spaceme1117's Avatar
Drives: 2017 Camaro SS, 2011 Corvette GS
So I am a bit late in discovering this kit. Will very likely order this soon for my 2017 SS.
I don't track my car; it is mainly a DD and weekend cruiser.
But I had a bit of a surprise when I changed lanes on the interstate. Rear of the car just felt weird. The road surface has grooves and I think the rear of the car tried to follow the grooves and the movement in the cradle allowed it to try to do that for just a moment.
Question: I know that the cradle bolts are torque to yield. Anyone just re-use the original bolts and use a torque spec of "gud'n'tite"?
Okay, watched the install video that was linked in a previous page and they re-used the bolts. I will do the same.
Spaceme1117 is offline   Reply With Quote
Old 07-06-2023, 06:48 PM   #77
Mark R
Drives: 2018 ZL-1
Don't reuse the bolts. They are cheap and the old ones are stretched past their yield point.
Old 07-06-2023, 08:07 PM   #78
I'm with Mark on this one. These bolts are cheap, last time I checked they weren't on backorder, and you can rest well at night knowing you didn't compromise your rear suspension.
Old 07-07-2023, 07:02 AM   #79
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Just order the OEM replacements
'20 ZL1 Black "Fury"
Old 07-07-2023, 11:34 AM   #80
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
My lock out kit is in mail and new bolts are ordered, they only cost $24 Canadian so almost free in American dollars! I’ve heard people say some are hearing squeaking noises after install, so I’m going to use dielectric grease on everything because that stuff doesn’t dry up like regular petroleum grease and it will not affect the original rubber parts on the cradle
Old 07-15-2025, 11:48 AM   #81
Akura
Akura's Avatar
Drives: ´18 ZL1 A10 Red Hot 😍
Just installed, very noticeable!
First ZL1 in Spain (Madrid)! Red Hot, A10, PDR, carbon fiber hood & grounds effects...
Akura is offline   Reply With Quote
