Old 05-11-2022, 02:12 PM   #71
triggerjerk
Drives: 2023 Camaro ZL1
Originally Posted by Blackdevil77 View Post
Guess they know the tiny blower sucks
What is interesting is that for the CT5BW they kept smaller blower.
Also, it seems like the larger blower LT4 in the Escalade isn't getting supplemental port injection like the LT5.
triggerjerk is offline   Reply With Quote
Old 05-11-2022, 02:23 PM   #72
Blackdevil77
Blackdevil77's Avatar
Drives: 2008 Pontiac G8 GT, Shelby GT500
That is interesting. I'm just waiting to see if any of these improvements make it's way into the ZL1 before it's gone forever.
Blackdevil77 is offline   Reply With Quote
Old 05-11-2022, 02:25 PM   #73
triggerjerk
Yep. So GM will do a small run of Escalades with an upgraded LT4 but not a Camaro? Lame if it ends up that way.
Old 05-11-2022, 02:29 PM   #74
Blackdevil77
I agree, but they spent tons of money on the CT-6 turbo black wing engine and never used it in anything else, so I wouldn't be surprised.
Old 05-11-2022, 02:44 PM   #75
triggerjerk
That's right. What a bad precedent they set Although does the Z06 LT6 share anything with the original bw dohc V8?
Old 05-11-2022, 05:00 PM   #76
Idaho2018GTPremium
Idaho2018GTPremium's Avatar
Drives: 2021 Camaro ZL1 A10
Since the 2.65 L Escalade blower LT4 only makes 14 more hp than the CT5V BW LT4 and similar torque, I'm guessing they used the larger blower not necessarily for extra power, but for the tow capacity rating. The larger blower will have better intercooling of the charge air for those long WOT runs up hill towing a boat, RV, or whatever else people in $150k Escalades may tow.
Towing at capacity in a truck/SUV may require WOT for several minutes (or more) at a time, and the smaller intercoolers in the 1.74 L Eaton likely don't have the capacity for that to maintain reasonable charge air temps, thus, the larger blower w/ larger intercoolers.
As far as the intercoolers on the LT4: I've long theorized that the intercooling is slightly inadequate in the 1.74 L Eaton supercharger even in a stock LT4 for long WOT runs (>13 or 14 seconds). It works OK on a track because WOT is intermittent so they can keep up with an on boost/off boost duty cycle, as well as at a drag strip where it will be off throttle within about 12 seconds or so, or less.
Obviously, with a 2.65 L blower the LT4 could make quite a bit more power.
2021 Camaro ZL1 A10
2022 GR Supra 3.0
Past:
2018 Mustang GT Premium w/ PP1, MR, and A10
2007 MazdaSpeed3
1995 Pontiac Trans Am
1987 Camaro Z28
Idaho2018GTPremium is offline   Reply With Quote
Old 05-11-2022, 11:38 PM   #77
Schlok
Schlok's Avatar
Drives: 2015 Z/28 #397 2022 ZL1 #1799
Excellent point on the 2650 for the Escalade, they weren't trying to make much more power, but just deliver consistent power 'all the time.'
Schlok is offline   Reply With Quote
Old 05-12-2022, 08:10 AM   #78
Blackdevil77
What a concept. One that would be more than welcome for the ZL1, or any performance car for that matter.
Old 05-12-2022, 08:55 AM   #79
KamZL1
KamZL1's Avatar
Drives: Z06
man even just make a reasonably priced OEM 2650 conversion kit, they would make so much just from that
KamZL1 is offline   Reply With Quote
Old 05-12-2022, 12:49 PM   #80
Snowwolfe
Drives: CTV5 V Blackwing on order
Cadillac Escalade-V expands V-Series lineup;
Delivers 682 hp and 653 lb-ft of torque.
They upped the HP on the Escalade even higher than the CTV5 Blackwing.
Snowwolfe is offline   Reply With Quote
Old 05-12-2022, 12:57 PM   #81
Z OH 6
Drives: 2024 CT5-V Blackwing
The Escalade will likely be around longer than the Camaro. I don't see GM spending any more money on the Camaro because its end of life.
Old 05-12-2022, 12:58 PM   #82
Z OH 6
And lost torque with a bigger blower.
lt4, lt5, lt5 vs lt4, zl1, zr1
