LT5 vs LT4 (differences and similarities)
Hey all, would you guys be so kind as to educate me in the differences and similarities between the LT5 (ZR1) and LT4 (ZL1/Z06).
And you guys can skip the fact that the blower is different lmao. I'm just wondering how different the motors really are aside from that. |
Bigger blower, better internals, port injection.
damn i didnt know it had port injection, imagine if they put this motor in zl1 (IMO they should have to really end this baddest muscle car debate)
Besides the larger and more efficient supercharger (2.65L 14 psi boost and 170 deg rotors vs 1.74L 9.4 psi and 160 deg rotors):
Improved intercoolers and higher temperature Delta (140 deg F temperature decrease vs. 130 deg F in the LT4) Direct + port injection (LT4 has direct only, but both direct systems run at 2,900 psi) Stronger crankshaft (LT4 crank is also stronger than LT1 crank) + improved bearings Bigger TB (95 mm vs 87 mm) Upgraded pushrod bearing coatings (but the pushrods themselves are LT4 carryovers) |
What's not to get? GM doesn't want to have their most expensive Corvette outperformed by the Camaro. Would you buy the most expensive Corvette if you knew the most expensive Camaro beats it around the track? |
Most notable difference I think is the LT5 uses port injection and direct injection, the LT4 uses only direct injection.
Has carbon build up on the intake valves been a problem for anyone with the LT4? Haven't heard any complaints about it and it's been around a while now. Quote:
Unfortunately, the LT5 engine has even been discontinued for aftermarket purchase too.
For a while you could buy a LT5 blower and PI setup through Crawford. Doesn't look like they sell it anymore.
