#71 |
![]() Drives: 2017 Chevrolet Camaro ZL1 Join Date: Jul 2018
2017 ZL1 - PB 7.85 @ 175 MPH @ 3682 lbs @ 1313 DA (work in progress)
Built by Vengeance Racing, tuned by Elite Tuned |
#72 |
Drives: 2017 Camaro ZL1 A10 Join Date: May 2012
Did you get your 2650 yet? I remember myself and a few others making that suggestion to you several times a few months ago. I'm glad to see you finally ordered one. I'm just curious tho, why not stick with your ported stock blower?
#73 |
What is your setup?
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq |
#74 |
It was just stock HX's with a Stewart EMP pump (bypassed OEM) from a 6 gallon tank. Getting a little more wild now and removing the HX's since I don't care about how fast I run 60-130 after 30 minutes of being on the road.
#75 |
Is your tank ambient or iced
2020 ZL1LE A10.
#76 |
![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL1 Join Date: Mar 2019
He has an ice tank JSH, no heat exchangers. Fully built 427. He runs 8.48 @ 162. 1150whp. New new build is 1400+ rwhp and hes trying for 7's. But you know how it is cause you car ran 6's. Look here: https://instagram.com/zl1atlanta?igshid=YmMyMTA2M2Y=
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
#77 | |
#78 |
Camaro1973"But you know how it is cause your car ran 6's." For at least the 10th time, I'll bet you any amount you chose over $1k that my car ran 6's. But you won't do it because you know you'll lose. Is there a "chicken" emoji here? It's true that I do know how it is to runs 6's, but of course you don't! ![]() ![]() ![]() CW3SF posted last week that he's verified what I'm saying. That's not good enough for you ![]() You're obviously just feeling insignificant.
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq Last edited by JSH; 05-09-2022 at 08:37 PM. |
#79 | ||
2020 ZL1LE A10.
#80 |
Flying around Thailand
Drives: 2019 Camaro ZL1 Join Date: Oct 2020
This message is for Camaro1973 and BlaqWhole…. So you’re both advocating an Interchiller on your DD, Correct? Because I live in Thailand, it’s midnight now and it’s usually 80 degrees with 90% humidity. And it’s pretty much like this 8 months a year. So an Interchiller does make sense to me, but I’ve heard others say it could cause issues with the compressor. Being here in Bangkok, I have no support from Chevy. I just can’t go buy a compressor. On the other hand, if it’s working well for a decent period of time. I’m all in. My car is a DD that will shortly be converted to E50ish. I do plan to track it in time. Now it’s just my toy street machine. My biggest question, if I decide to add this to my overall build. Should I have the car tuned without the Interchiller and then add it (so the car would be tuned to the heat and then timing could just be added as the computer realizes colder air is available). Or should I bolt it all in and then have it tuned with the stable cold air.
#81 | |
You are using your AC anyway, so why not just use an interchiller also? You can turn off the AC on the dyno to see if there is any difference in how much timing you can run. That's the nice part about it, get it cold see what it does then turn the ac off and see what it does. This way your safe when hot.
#82 | |
#83 | |
What you want to do is have it installed when the weather is hot. That way they can add/charge the refrigerant accurately. And then have it tuned. I don't think it matters what temp it gets tuned in. But my suggestion would be that when outside temps get colder, you might want to have some datalogs looked over to make sure all is well with it. It isn't necessary but it won't hurt. As far as issues with the compressor, I don't think you will have any. These units wouldn't sell if they were known for causing issues with the AC components. So you should be fine. But if you are worried, then maybe buy a used compressor from someone and have it shipped to you and then you'll have a spare if you need it. I haven't had mine installed yet. I'm planning to have it done soon tho. I'm just still debating on whether or not to go with a 416 and have the chiller installed at the same time or to do it as a stand alone install or to hold off and do some mods on my other cars first. But my goal is to have it installed either way by the end of the year. |
#84 |
![]() Drives: 14 Camaro SS 1LE Join Date: Feb 2019
Without getting into crazy detail, and giving my feedback based on data we have from customer cars (chiller only, ice tank only, chiller and ice tank, stock, etc)...
Regardless of method, it all comes down to simple thermodynamics. What you are looking to do is increase the cooling capacity of the system. For the sake of simplicity, lets call our cooling agent 100% pure water. It requires 8.33 BTU of heat energy to raise one gallon of water 1 deg F. This is linear, so if you double the amount of water (2 gallons), it will either take twice the amount of heat energy to heat water 1 deg in the same time, or it will take twice the amount of time with the same fixed amount of energy. When you add water capacity (expansion tank, ice tank, etc).... You are not changing the rate that your cooling system can remove heat from the water. What you are doing is increasing the amount of time it takes for that water to heat up. When you change a heat exchanger, or add an interchiller, you are changing the rate that the system can remove heat from the water. There are benefits to both. Being able to remove heat more effectively is great, and having less heat to remove is also just as great. It is absolutely pointless arguing that one is better than the other, because you are changing two completely different parts of the system. Both have very good benefits. The only gripe I have about the interchiller, is you are not technically allowed to run your AC at any track (drag strip or road course). The condensation/moisture build up will drip on the track, and cause a hazard. |
