Old 10-04-2022, 01:42 PM   #71
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
When I pulled my OG green cats because I was concerned about them failing, I went with offroad pipes and immediately disliked the additional volume and tone, so I added the Magnaflow muffler in the center as many have done which helped with the volume but the tone still wasn't as good as it was with the green cats, but then I got concerned about the flow of the double Y design so I pulled it out and installed a Jones X pipe muffler and the sound got worse, much sloppier and raspy. I had it on the car about a month and now I'm back to my original green cats again and it sounds great again. I bought a set of the Kooks HO green cats which I will swap out with the original green cats when they arrive.
Yeah those are the upgraded version of the original gen 1 cat and hold up
Better. It just sounds so much better with them on and I’m Still making 850rwhp through the gen 2 ultras so not really sure what kind of power I’m losing if I took them
Off.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Old 10-04-2022, 08:34 PM   #72
JSH
JSH's Avatar
Drives: '20 ZLE
First I've heard about Fabspeed cats (200 cells)
https://www.autoevolution.com/news/f...ss-148346.html
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 10-05-2022, 04:01 AM   #73
Z OH 6
Drives: 2024 CT5-V Blackwing
I knew about these last year when the C8 came out. They were one of the first companies with a high flow cat for the C8 but they're insanely expensive.
Old 10-09-2022, 02:19 PM   #74
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
Update to post #50
Post 50
https://www.camaro6.com/forums/showp...3&postcount=50
It's taken a while, short version........
Kooks blamed E85 for causing the cats to fail
I contacted Gesi and they stated that their products are designed for E mix
Kooks said that the tune was wrong, causing failure
Tuner jumped in (thx Ted!) and said no way
Kooks sent two Gesi GE-90147 for me to weld in
I sent back the original Gesi GE-90140 cats to Kooks
Kooks volunteered to send cats with the connection pipes. But since I had welded them in, eliminating the rear clamp that was not an option. I had to prepay for the new cats, they agreed to refund the charge this week. The welding is on me.
Kooks states on the replacement invoice they are 850hp cats, but their website says 425. Not real promising, but we'll see how these do.
Old 10-09-2022, 04:32 PM   #75
JSH
JSH's Avatar
Drives: '20 ZLE
What are your mods and hp?
Originally Posted by h018871 View Post
Post 50
2020 ZL1LE A10.
Old 10-09-2022, 08:16 PM   #76
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
They're the same? 2 * 425 = 850. Reading your other thread I presume the car is up at that level as well road-course use, so yeah you're probably going to break 'em if anyone is.
Old 10-09-2022, 08:56 PM   #77
Z OH 6
It looks they sent him the replacement for the older standard Green cats which are rated to 425hp per bank. The new Kooks Green HO cats are designed to hold up to 850hp per bank.
Old 10-09-2022, 09:01 PM   #78
Z OH 6
Post 50
That's 425hp per bank so 850hp is correct.
Old 10-10-2022, 07:46 AM   #79
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
Car hasn’t been on a dyno
Mild cam, ported blower, ported heads, occasional E and bolt ons
When this started it was only the bolt ons w/ E
I should now be close to the limit
Old 11-12-2022, 08:37 AM   #80
SHE'Z 18
SHE'Z 18's Avatar
Drives: 18 ZL1 - M6
Hey HO,
Any updates on how the replacement Kooks cats are holding up? Are we missing something, or are the replacements that they sent you also rated for 425/bank? It seems like Kooks just shipped you the same ones, just with a different part number. But, I may be missing something. Thanks everyone for all this outstanding feedback. I’m in the beginning stages of a build and suspect that I’ll end up in the 750-ish WHP range. That said, it seems like the GESI HO cats may be the best/only option
SHE'Z 18 is offline   Reply With Quote
Old 11-15-2022, 02:05 PM   #81
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
The construction of the medium is different. I neglected to take a picture ��*♂️
Anywho instead of a simple spiral from the center, it is a dual spiral. Looks like the ying/yang symbol.
Old 11-02-2023, 12:43 AM   #82
Marozl1LE
Drives: Camaro gen 6 zl1 1le
Hi guys i have now uho cats from gesi 85032 gen1 i hope this cat's doesn't gone bad too like the first green cat's
My HJS cats going bad after 6 months only bolt on my car
Kong ported blower with x port 16 psi ~ 22~ degrees timing
On pump gas fuel 97 octane no track use i think middle high 6xx whp
Is 1le package 60-130 times 6.1 ~ sec
Marozl1LE is offline   Reply With Quote
Old 11-02-2023, 07:05 AM   #83
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
That's a bummer...
'20 ZL1 Black "Fury"
Old 11-02-2023, 04:16 PM   #84
Marozl1LE
I hope gesi do it better i don't wanted melted cats again ****ing expensive too or I immigrate to the USA and drive without cats yessir American dream life.
In my greda fan country you can't do nothing so sad here ��
Also my afr was alwaYS at wot 0.79-81 ~ not leaner
