#71 | |
![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com |
#72 |
![]() Drives: 2017 1SS A8 Nightfall Gray Join Date: Feb 2017
Ted will you have any of the breathers and catch cans at Camaro Fest?
#73 | |
Ted.
#74 |
You can only YOLO once.
Drives: '16 2SS & '15 Subaru Forester Join Date: Jan 2016
The LS3 seal is on and yeah the LT1 seal was all flappy and splooging oil.
The Metco cap goes on no problem to the oil cap but the ProCharger air filter elbow is in the way and you can't rotate it enough for everything to fit. Anyone have any ideas how to make it fit as Ted states it should?
2016 Camaro 2ss
-Summit White / Ceramic White -8A, NPP, MRC, Ceramic White package plus knee pads, black bowties. -1st Car to have the "full" SEMA High Performance Graphics kit from 6LEDesigns. -1st Car to have the 6LEDesigns Blade Spoiler. -Borla S-Type w/ custom H-Pipe -Procharger P-1X Stage 2 |
#75 | |
![]() ![]() Drives: 2017 50th Anniversary 2SS Join Date: Sep 2016
The only other option is to do what I did and pick up a spectre valve cover breather gromet which will fit the metco. 90 degree barbed 1in hose connector and trim to fit. https://shop.advanceautoparts.com/p/...B&gclsrc=aw.ds https://www.homedepot.com/p/SharkBit...60A5/206133164 Then just relocate the metco filter wherever you want. Post #57 in this thread of mine setup that way.
#76 | |
I will try rotating the filter tube first then go with your solution.
2016 Camaro 2ss
#77 |
Ted I'll take one of those at the Fest. See you in a couple weeks.
#78 | |
#79 |
SNSTRSS
Sorry to bring up an old thread but if I'm NA with forged internals and larger cam should I be at minimum using a metco breather? I already have a mishimoto catch can.
2016 Black Camaro 2SS A8 NP
#80 | |
You should be find since your intake is always on vacuum. The metco or vented catch can is more for the boosted folk.
#81 |
OK so I am thinking that I might try using the Mishimoto Catch Can that I have sitting on my shelf (that I haven't sold yet) as a catch can for my setup.
As an update, I have the Metco Check Valve Breather from JRE and the LS3 Front Crank Seal...I also have a ProCharger which has this long tube going from the PCV thingie on the top front passenger corner of the motor INTO the Air Filter. My question is, is that the tube that I should be putting the catch can between? It seems to send smokey air to the air filter and I guess through the supercharger to the intercooler and into the intake. I see a space that I could mount the Mishimoto Can that is right next to where this long tube runs so it "should" be easy enough to cut the tube and insert each end into the catch can. Am I thinking this through correctly?
2016 Camaro 2ss
#82 | |
You want to connect a real catch can between the intake and the PCV.
#83 | |
So I would, in essence, be using the same connection points that the catch can would normally be using? What is that metal bypass thingie that is installed with the ProCharger kit?
2016 Camaro 2ss
#84 |
I believe you are referring to the 1 way check valve that prevents boost from entering your crankcase.
