Old 05-03-2017, 06:00 PM   #71
Chevy71
Drives: 2016 2SS
Originally Posted by brettman View Post
As some of you know, I "WAS" going to sandblast the lid (metal flake appearance)
But there is enough silver in the engine compartment. SO, Red car, red letters.
It looks awesome man!
Chevy71 is offline   Reply With Quote
Old 05-03-2017, 06:23 PM   #72
brettman
Drives: 2016 Camaro SS
Originally Posted by nick_casper View Post
Most people only heat it to 200f which is how hot the engine gets running. I also used antiseize inside the new hub. It was a bitch to get off and on but smooth sailing after that.
Hubs on, No heat, die grinder with a flappy wheel, polished the ID, anti sneeze.
Nice tight fit slid on smooth.
brettman is offline   Reply With Quote
Old 05-03-2017, 06:51 PM   #73
brettman
Thanks buddy.
SIDE NOTE: Whipple SC, before installing the SC, deal with the fuel lines on top of engine. (easy to get too) Bend lines pointing to driver side, or out of the way. It will look cleaner.
Old 05-04-2017, 06:46 PM   #74
TECHTURTLE
TECHTURTLE's Avatar
Just got a chance to check on your progress. Everything looks great!
2016 2SS 6-Speed Manual... Magnetic Ride Control, Dual Mode Exhaust, Sunroof, Adrenaline Red Interior, Mylink W/Navigation
Added
Edelbrock E-Force Supercharger, GM 1LE Sway Bars, BMR Upper/Lower Trailing Arms, BMR Upper Control Arms. BMR Front/Rear Chassis Braces, BMR Tunnel Brace. GM Red knee Pads, GM Black Front Splitter, GM SEMA Concept Grille, GM Dark Taillights, GM Ground Effects package... Savini Di Forza BM-14 Gloss Black Wheels 9's front, 10's rear.
TECHTURTLE is offline   Reply With Quote
Old 05-04-2017, 07:03 PM   #75
brettman
Thanks, slow going, cold, rainy and damp. No heated garage. I'm not going out there if I can't enjoy myself...lol. But I might bite the bullet and hit it tomorrow,
Old 05-05-2017, 05:10 AM   #76
80sMetalDude
80sMetalDude's Avatar
Drives: .
Looks great Brett thx for tips.
We start tonight and yep ur in the general region and Weather has been crap all week.
80sMetalDude is offline   Reply With Quote
Old 05-05-2017, 06:08 AM   #77
brettman
Thanks. Your welcome, check back I might have more tips today. I PM-ed you on the coil harness. Install tonight?? Great. I didn't follow the destructions in order. But there is a method to my madness.
Old 05-05-2017, 08:24 AM   #78
shinysun
Did you remove the foam insulator btw the engine and intake manifold? Or modified like one on the Magnuson manual? (6" cut to cover the pump..nosie)
Btw, I got 3 supplied bolts left after installation. How about you?
shinysun is offline   Reply With Quote
Old 05-05-2017, 08:46 AM   #79
brettman
I'm not done with install, so no idea about spare parts yet.
Old 05-05-2017, 11:03 AM   #80
nick_casper
nick_casper's Avatar
Drives: 16 2SS
I had some leftover large bolts and a hose ( sent two of same ). I removed the foam piece entirely.
2016 2SS, A8, Whipple 3.25 pulley, Mishimoto catch can, C7 Carbon fiber splitter and skirts, GM black brake and tail lights. PLX wideband O2/HP tuners. Apex VS-5RS in 19x11 and 19x12.
nick_casper is offline   Reply With Quote
Old 05-05-2017, 11:31 AM   #81
brettman
30 year mechanic, I always had spare parts....And ever hole was filled, every bolt was installed....lol. Ya, I deleted foam too, (cleaning, inspection,..cant do that with foam) Nick, any more noise with it removed??.....Hood closed, driving, or just sitting running??? I figure, if it's too noise I'll fix it. Top end is SO easy to pull.
But then again, I'm not building a BMW sedan. At all RPM ranges, I want to hear ABNORMAL noises before I have to shut it down.
Old 05-05-2017, 11:50 AM   #82
nick_casper
Drives: 16 2SS
With the hood open I can hear them clicking away. Once driving I can't hear them if I try. With the hood closed you can faintly hear injectors / pumps with window down but not at all with it up.
Edit to add: To motivate you to get that car buttoned up this weekend Brett. I just did some burnouts and launches. The Whipple is an absolute beast. It's only 60f out but I broke the tires loose at 80. Not just skittering but full on mushroom cloud of smoke behind me.
Old 05-05-2017, 12:46 PM   #83
brettman
THANK YOU NICK, The question of noise was for the others to install. (Is it needed) kinda thing. We have several that are watching... (cause the instructions suck a....) I am motived.....However my State is uncooperative...lol. Otherwise I would finish and re-write the.....DESTRUCTIONS. Many have done this with limited experience, (mechanical) Putting something together that is real outside their realm.
IF IT ISN'T FUN.... send it in, let someone else climb over your car...lol, just pay the bill, then tell your buddy's what YOU built...LMFAO.
Old 05-05-2017, 12:49 PM   #84
80sMetalDude
Drives: .
Dont worry they aren't important.
JK WTF? That would have me concerned. Did you use any bolts from factory that may have been included to replace factory OEM bolts maybe? I hope it's just that, or extras....
