Old 04-22-2017, 05:44 PM   #71
MR 45TH
MR 45TH's Avatar
Drives: 2018 ZL1
It's a perfect match 😎
2018 ZL1…Many mods to come
MR 45TH is offline   Reply With Quote
Old 07-16-2017, 08:15 PM   #72
Garrett52
Garrett52's Avatar
Did you ever figure out the fan issue? Just installed mine and I'm getting the same and my aeroforce is showing 65000 degree intake temp.
Garrett52 is offline   Reply With Quote
Old 07-17-2017, 09:33 AM   #73
ProCharger
Drives: Many C7's
Check your connections on your MAF connector.
Make sure some of the pins didn't get bent.
If its really wrong, the fan will run all the time.
ProCharger is offline   Reply With Quote
Old 07-17-2017, 01:28 PM   #74
Garrett52
Garrett52's Avatar
The fan is running at max speed all the time. When I remove the wiring harness extension and plug the stock connection directly to the MAF sensor my gauge reads correctly.
Should there be an unused connection on the MAF extension harness provided in the kit?
Old 07-17-2017, 03:36 PM   #75
ProCharger
Drives: Many C7's
If the fan is on, then you have a major issue.
Please double check your connections, and the connector before driving car.
Otherwise you could damage the motor, since the car wouldn't know boost.
Old 07-17-2017, 03:54 PM   #76
Garrett52
Garrett52's Avatar
Is the MAF harness extension that comes with the kit just an extension or does it have a plug for a remote IAT sensor?
I trailered it to the tuner. They are going to check into the harness and get back to me. I think I may have received the wrong harness, as I purchased the kit used.
Old 07-17-2017, 03:59 PM   #77
ProCharger
Drives: Many C7's
No ours does not, since it is not needed to "break out" the harness.
(some people do that, per their tuners wants)
So yes, you are not running our harness. And you will need to buy the separate sensors needed to complete your install.
Old 07-17-2017, 04:01 PM   #78
Garrett52
Garrett52's Avatar
Is it possible to purchase the correct harness from Procharger?
Old 07-17-2017, 04:03 PM   #79
ProCharger
Drives: Many C7's
You may want to ask your tuner what he wants on these LT1's.
Some tuners will ONLY tune cars with the break out harness.
I haven't had an issue tuning them without it.
But as stated, everyone has their preferences.
Yes you can always call our main line and buy any part.
Old 07-17-2017, 04:05 PM   #80
Garrett52
Garrett52's Avatar
Awesome! Thank you for your help and quick response!! I really appreciate it and can't wait to get the car back
