Old 05-03-2017, 07:19 AM   #71
DapperDan
DapperDan's Avatar
Drives: 2017 1SS A8 Nightfall Gray
So you don't think my 60' would be any better with mickeys?
DapperDan is offline   Reply With Quote
Old 05-03-2017, 10:57 AM   #72
steelheadrob
Tactical Garage
steelheadrob's Avatar
Which racestars do you need if you want to run the MT 305/45/17? 17x9.5 big enough or do you need to go wider?
steelheadrob is offline   Reply With Quote
Old 05-03-2017, 08:52 PM   #73
SGDM
SGDM's Avatar
Drives: 2016 2SS
My set up is RS Recluse 4.0 x 17 for the front and 10.5 x 17 for the rear. Just ordered MT's for the front and rear today, they are on sale at JEGS. ET Front Runners, 27.5 x 4 x 17 and MT ET Street SS 305 x 45 x 17 for the back.
Who Dares...Wins
SGDM is offline   Reply With Quote
Old 05-04-2017, 09:14 PM   #74
steelheadrob
Tactical Garage
Thanks for the reply. I found a good deal on some 17x9.5 rims so was hoping I could use them. I ended up checking the MT website the they say rims 9.5-11 are ok. But I am concerned it is cutting it a little close.
Has anyone mounted these on the 17x9.5 rims?
Old 05-04-2017, 10:05 PM   #75
ULTRAZLS1
ULTRAZLS1's Avatar
That's what I use. I have the 305/45/17 et street R. Been to the track 4-5 times. Hour drive each way. 20+ passes
They are within spec according to the website like you said. I have had no problems what so ever
Old 05-04-2017, 11:01 PM   #76
steelheadrob
Tactical Garage
Great thanks. I am planning on the same set up as you.
Old 05-05-2017, 12:17 AM   #77
steelheadrob
Tactical Garage
One last question if you don't mind. Are you using the 6.00 or 6.43 back spacing wheels?
Old 05-05-2017, 01:18 AM   #78
ULTRAZLS1
ULTRAZLS1's Avatar
I have the standard I believe. 6.0. My tires sit about flush with the fenders. The look is fine with me for just at the track. If you want them tucked in more I think the 6.43 is what will accomplish that.
You also need install kit with lugs and rings. If you call race star they are great with customer service will hook you up with all part numbers you need. But I'd look elsewhere for the best price. If you order from them they are a bit high.
If you end up with my setup make sure you unlock the trans as well. You will gain an instant .2 from disabling the torque management in the trans. But I'd advise just running the no TM only at the track as I've found reports of decreased transmission life running no TM.
Old 05-05-2017, 04:15 PM   #79
steelheadrob
Tactical Garage
Thanks for all of the info. Do you think there is enough clearance on the inside to run 305s with the 6.43 without any rubbing issues. If i am thinking about it correctly the inside clearance would similar to someone running 325s with a 6.0 bs.
Is anyone running 305s with a 6.43 bs.
Old 05-05-2017, 05:07 PM   #80
ULTRAZLS1
ULTRAZLS1's Avatar
I don't know for sure but I would guess yes
Old 05-05-2017, 06:11 PM   #81
SGDM
SGDM's Avatar
Drives: 2016 2SS
Yes, you will have clearance. However, you will need to remove the driver side liner and re-route the cable to the inside, takes 15 minutes. Once you route the cable just pin the liner to the the wheel well with a GM fastener, the hole is there in the well.
Who Dares...Wins
Old 05-05-2017, 08:40 PM   #82
wnta1ss
Drives: 2017 Camaro 1SS
It's not the same wheel, but I use a Weld 17x10 with a 7.2 backspace and a 305/45-17 Mickey Thompson. I recently checked the driver's side liner for the wear problem that people have seen with 305/35-20 tires and no issue spotted on mine.
Old 05-05-2017, 10:14 PM   #83
steelheadrob
Tactical Garage
Thanks I heard something about this, I am guessing there is probably a youtube video on this, so I will check it out.
This is helpful. I am stilling learning all this but I would think even with the different wheel size you would running closer on the inside than I would and I would be fine. I think I am going to go with the 17x9.5 race stars 6.43bs with the 305/45-17 Mickey Thompson.
In checking around on pricing the best deal I have seen on Race Star is Summit and the best pricing on Mickey Thompson is Jegs. Although I think Jegs will price match Summit on the Race Star. Has anyone seen better pricing from anyone else on either of these?
Old 05-05-2017, 10:41 PM   #84
DapperDan
DapperDan's Avatar
When I ordered my dragpack I just called summit and they matched everything some of summits tires had a oversize shipping charge compared to being free from Jegs, Summit also matched that. Just call and ask
