Old 04-01-2018, 04:21 AM   #8219
Soleil
Soleil's Avatar
Originally Posted by Mrfixxit7 View Post
Hey guys I have been doing some mods over the winter and hopefully will have everything done in by the end of April.
This is what I have done so far:
-installed the ZL1 taillights and third brake light.
-replaced the sidemarkers
-set of 1LE wheels with MPSS 295/30-20 up front and 335/30-20 on rear
-50th anniversary hotwheels edition steering wheel and shifter
What is next:
-installing ZL1 front brakes and rotors (having the calipers powder coated to match the rears, should be back in a week or so
-ZL1addon rock guards
-ZL1 sides rockers
-ZL1 (FE4) suspension components
Lighting sucks not much room to get good angles while it is in the garage. Hope to get it out of the garage in a couple of weeks
That looks nice. Do you get 335 on the OEM 20x11“ rims? I checked with Michelin and they said max 325 are allowed here in the EU.
Soleil
Old 04-01-2018, 07:37 AM   #8220
Mrfixxit7
Mrfixxit7's Avatar
Drives: FIFTY 2SS Callaway
Yes they are the OEM 1LE wheels
Mrfixxit7 is offline   Reply With Quote
Old 04-01-2018, 10:09 AM   #8221
1hprush
2018 ZL1 1LE
1hprush's Avatar
Drives: 2018 ZL1 1LE
Car looks great! So...how did you get those tire sizes to fit. Does your car have MRC?
1hprush is offline   Reply With Quote
Old 04-01-2018, 11:03 AM   #8222
Mrfixxit7
Mrfixxit7's Avatar
Yes I have MRC. I rerouted the wiring harness on the driver side and I used a push type fastener to ensure no rubbing (there was an existing hole in the body so I did not have to drill). Next time i have the wheels off I will show a pic. I did not have to do anything to the passenger side but I might use the same push faster just to be safe.
Old 04-01-2018, 11:09 AM   #8223
Mrfixxit7
Mrfixxit7's Avatar
What is next:
-ZL1 sides rockers
I forgot to add, as I was test fitting the 6 piston calipers and rotors I tried to put the stock 50th anniversary wheels on and they will not fit. There is not enough offset and they rub on the back side of the wheel. The GMPP 6 piston upgrade is a little smaller than the ZL1 setup but I still doubt they will fit. Needless to say the 1LE rims had no issues.
Old 04-01-2018, 11:20 AM   #8224
KyBoy
KyBoy's Avatar
Drives: '17 2SS H50
Valuable info here.
Heath
1100 - 5/26
0000 - Cancelled - 7/5
Contacted Becky - 7/1
2000 - 7/5
3000 - 7/6
3000 - 7/11 TPW 8/1
3100 - 7/18 TPW 8/1
3300 - 7/20
3400 - 7/21
4300 - 8/3
5000 - 8/5
6000 - 8/13
Old 04-01-2018, 11:25 AM   #8225
Mrfixxit7
Mrfixxit7's Avatar
Valuable info here.
Heath
You could probably get a spacer and it would work. I am not sure what the difference in offset if between the 50th anniversary wheels and the 1LEs but that would be an option.
Old 04-01-2018, 11:29 AM   #8226
KyBoy
KyBoy's Avatar
Drives: '17 2SS H50
I'm sure that this could help someone in the future, I divorced my 50th wheels some time ago, remarried the M017s. I asked you for the part numbers of your OEM, I may have to get divorced and remarried a second time hahaha.
Heath
1100 - 5/26
2000 - 7/5
3000 - 7/6
3000 - 7/11 TPW 8/1
3100 - 7/18 TPW 8/1
3300 - 7/20
3400 - 7/21
4300 - 8/3
5000 - 8/5
6000 - 8/13
Old 04-01-2018, 05:44 PM   #8227
Soleil
Soleil's Avatar
Does someone have the # Number of the OEM 1LE rims? And maybe a price? Or should I go with the MRR? As they are cheaper? Maybe a project at fall 18.
Soleil
Old 04-02-2018, 04:10 AM   #8228
Soleil
Soleil's Avatar
Happy eastern
I wish all of you a happy eastern
Soleil
Old 04-02-2018, 10:43 AM   #8229
HartfordRacingCaptain
HartfordRacingCaptain's Avatar
Drives: 2017 Camaro 1SS, 2023 Colorado Z71
Well took the Camaro out last Tuesday and got a good week of use, then put on the GMPP CAI Thursday.
Today the white plague is back though...
2017 1SS, Summit White, Black 2SS Interior, MRC, NPP
2023 Colorado Z71, Nitro Yellow
HartfordRacingCaptain is offline   Reply With Quote
Old 04-02-2018, 10:46 AM   #8230
KyBoy
KyBoy's Avatar
Drives: '17 2SS H50
That sucks.
Heath
1100 - 5/26
2000 - 7/5
3000 - 7/6
3000 - 7/11 TPW 8/1
3100 - 7/18 TPW 8/1
3300 - 7/20
3400 - 7/21
4300 - 8/3
5000 - 8/5
6000 - 8/13
Old 04-02-2018, 11:00 AM   #8231
Kaizer_911
Kaizer_911's Avatar
Front - 23355791
Rear - 23355802
Not sure on price.
6000 - 07/08/16 | Club F1FTY
Old 04-02-2018, 11:02 AM   #8232
KyBoy
KyBoy's Avatar
Drives: '17 2SS H50
Front - 23355791
Rear - 23355802
Not sure on price.
Thanks Adam, I was gonna post them and forgot. I done a little research. I'll shoot Matt a message later and ask.
Heath
1100 - 5/26
2000 - 7/5
3000 - 7/6
3000 - 7/11 TPW 8/1
3100 - 7/18 TPW 8/1
3300 - 7/20
3400 - 7/21
4300 - 8/3
5000 - 8/5
6000 - 8/13
