Old 03-08-2018, 07:16 PM   #7827
KyBoy
KyBoy's Avatar
Drives: '17 2SS H50
The only intake needing a tune is the GM one.
And Matt is awesome. I got to meet him at CamaroFest last year. Talked with him for a bit, and spent some money too lol. Just ask Heath lol.
I can vouch for that!
I still need to mention about the Special Edition categories. BTW, they’ve changed their name.
That would be sweet.
Yeah I would love to see his new site have the categories.
And yeah saw the name change.
+1
Heath
1100 - 5/26
0000 - Cancelled - 7/5
Contacted Becky - 7/1
2000 - 7/5
3000 - 7/6
3000 - 7/11 TPW 8/1
3100 - 7/18 TPW 8/1
3300 - 7/20
3400 - 7/21
4300 - 8/3
5000 - 8/5
6000 - 8/13
Old 03-09-2018, 04:16 PM   #7828
Kaizer_911
Kaizer_911's Avatar
Club F1FTY
Just a heads up guys and gals. I’m starting to see others (F1FTY and non-F1FTY 6th gen Camaros) report HUD issues.
Did some digging and this is what I found....
It’s currently a TSB only. The fix (which we all can do ourselves) is pull the fuse. I’m having a hard time finding the exact fuse at the moment, so do this instead....unplug the battery in the trunk for 5 minutes. This will clear/have same affect. May have to reset some of your personalization settings but will bring HUD back.
Unless something drastically changes I don’t think this will turn into a recall. I feel, a second TSB will be released or they will issue a revision to this TSB with a software update to the HUD module, if they determine software will fix it.
6000 - 07/08/16 | Club F1FTY
Old 03-09-2018, 04:20 PM   #7829
KyBoy
KyBoy's Avatar
Drives: '17 2SS H50
Unless something drastically changes this probably won’t turn into a recall. But a second TSB will be released or they will issue a revision to this TSB with a software update to the HUD module, if they determine software will fix it.
Thanks for the heads up Adam. I'll add to the battery un-hook, to make sure you get a total reset.
If you pull the negative cable, hop in the seat and press your brake for a few seconds. That will drain the ECU's back-up power.
Heath
1100 - 5/26
2000 - 7/5
3000 - 7/6
3000 - 7/11 TPW 8/1
3100 - 7/18 TPW 8/1
3300 - 7/20
3400 - 7/21
4300 - 8/3
5000 - 8/5
6000 - 8/13
Old 03-09-2018, 04:22 PM   #7830
Kaizer_911
Kaizer_911's Avatar
Heath
Great call out Heath! I neglected to mention that.
Old 03-09-2018, 04:23 PM   #7831
KyBoy
KyBoy's Avatar
Drives: '17 2SS H50
Team work brother!
Heath
1100 - 5/26
2000 - 7/5
3000 - 7/6
3000 - 7/11 TPW 8/1
3100 - 7/18 TPW 8/1
3300 - 7/20
3400 - 7/21
4300 - 8/3
5000 - 8/5
6000 - 8/13
Old 03-09-2018, 04:28 PM   #7832
RicSimonis
RicSimonis's Avatar
Drives: '17 2SS H50 Vert
Team work brother!
Heath
I don’t have it handy with me right now but I was going to look thru the service manual to see if there’s a mention of the HUD fuse.
Obviously the method mentioned will work regardless. Gives me a reason to break it out again.
Old 03-09-2018, 06:24 PM   #7833
RicSimonis
RicSimonis's Avatar
Heath
Team work brother!
Heath
FWIW.....
From what I've been able to glean out of the SM, it would appear that F16 in the rear fuse block not only provides power for the HUD but also the instrument cluster. It's labeled as "Display" in the owner's manual page 290 (page 291 on my PDF).
BUT, I'd not put any money on it and I'd probably go with the battery method described previously.
Old 03-09-2018, 06:26 PM   #7834
KyBoy
KyBoy's Avatar
Drives: '17 2SS H50
FWIW.....
Thanks for the research Ric.
Heath
1100 - 5/26
2000 - 7/5
3000 - 7/6
3000 - 7/11 TPW 8/1
3100 - 7/18 TPW 8/1
3300 - 7/20
3400 - 7/21
4300 - 8/3
5000 - 8/5
6000 - 8/13
Old 03-09-2018, 07:30 PM   #7835
Strange Flavor
Strange Flavor's Avatar
Drives: 17 Fifty SS, 11 2SS, 91 LSX C1500
Hey guys, quick question. I saw the other day a picture of a certificate or something that came with a Fifty car indicating it was a special edition and whatnot. I bought mine used and didn't get anything like this. Was there something that came with the Fifty cars like this or was it something someone had made?
Strange Flavor is offline   Reply With Quote
Old 03-09-2018, 07:47 PM   #7836
Kaizer_911
Kaizer_911's Avatar
It doesn’t come with the car unfortunately. It was a kit that was sent by GM to the original owners of the car.
See a few pics below of mine. (I framed part of mine).
Old 03-09-2018, 07:48 PM   #7837
RicSimonis
RicSimonis's Avatar
I'm sure I won't be the only response....
The original purchasers were sent a package that contained larger (24"x18") prints of each generation of the Generational mural (shown along the top of the image below) along with a card showing production information and a "thank you" letter. I had my cards mounted with my window sticker and have framed some of the "posters" from the portfolio book (not pictured).
These packages started being mailed out around this time last year.
Unfortunately only the original owners in the US were recipients of this package.
Still wish they'd hook-up our northern friends.
Old 03-09-2018, 07:52 PM   #7838
RicSimonis
RicSimonis's Avatar
FWIW.....
Heath
I've found it noted in multiple locations that the trunk fuse block F16 has to be the one referred to in the TSB. It also provides power for the HVAC controls, Info Display Module and Instrument Cluster.
Old 03-09-2018, 07:53 PM   #7839
Camaro Wolf
Camaro Wolf's Avatar
Drives: 2018 Bright yellow Camaro 2ss
Anyone here have the F1FTY grille insert on their SS
Camaro Wolf is offline   Reply With Quote
Old 03-10-2018, 02:27 AM   #7840
Soleil
Soleil's Avatar
I don’t understand the question. We all have the 50th grille. It is the 50th anniversary edition.
Soleil
