#57 |
I knew Pray was big on them, but would not have guessed that it would add 50 hp. Prorata, that's like 35 to me. The change from 3.00 to 2.75 added 50.
What do you think about this turbo inlet filter? At least the late summer bugs won't pass through Eddie.
2020 ZL1LE A10.
LME LT4 390 short block, CID Heads, Kong E2650, FBO. 15" conversion, Nitto 555Rii or MT ET Street R or Toyo Proxes RR. 100 octane: 1045hp/1055tq. 100 octane + Alky MAF Meth (1) 10+: Last edited by JSH; 09-28-2023 at 06:08 PM. |
#58 |
![]() Drives: 19’ ZL1 A10 / 16’ C7Z M7 Join Date: Apr 2021
#59 |
We ran 50/50 Meth/water on my 16ss with 2650 Maggie, didn't really need it as we did on the 2300 before we switched. When I sold it the new owner he didn't want it, so we barely made any tune changes and the car actually ran almost a 10th quicker and 2mph faster just on change in the tune, turning the meth off and running C16.
#60 | |
2020 ZL1LE A10.
LME LT4 390 short block, CID Heads, Kong E2650, FBO. 15" conversion, Nitto 555Rii or MT ET Street R or Toyo Proxes RR. 100 octane: 1045hp/1055tq. 100 octane + Alky MAF Meth (1) 10+: |
#61 |
My other tuner, the other Joe, says no on spraying water, says he ruined his blower and it will ruin my blower, says I could do port injection but it's very expensive and time-consuming tuning DI and PI.
2020 ZL1LE A10.
LME LT4 390 short block, CID Heads, Kong E2650, FBO. 15" conversion, Nitto 555Rii or MT ET Street R or Toyo Proxes RR. 100 octane: 1045hp/1055tq. 100 octane + Alky MAF Meth (1) 10+: Last edited by JSH; 09-29-2023 at 11:36 AM. |
#62 |
Having FUN in the SUN...
![]() Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
Can anyone share photos on what they have done / used, to seal around the RF airbox?
#63 | |
The second pic shows the foam I used to close the RF and WW liner gap. You can also see one of the wrapped intercooler lines. The third pic shows the DEI heat reflective material on the engine side of the RF The 4th pic shows another piece of foam to close the other gap to the hood.
2020 ZL1LE A10.
#64 |
Very cool, thanks for sharing... I will be doing the same thing... debating on whether or not a BG will help my set.up, waiting to hear back from TED.
#65 |
![]() Drives: 2017 Chevrolet Camaro ZL1 Join Date: Jul 2018
Give it a shot. A little extra protection can’t hurt as long as it doesn’t hurt power. I’m at a point of “no risk no gain” and prefer it to be wide open, but I realize most don’t want to live like that. In both cases I would say track only.
2017 ZL1 - PB 7.85 @ 175 MPH @ 3682 lbs @ 1313 DA (work in progress)
Built by Vengeance Racing, tuned by Elite Tuned |
#66 |
I agree. All of this is aimed at going to sea level and letting her eat. You can see I'm not a guy that cares about engine compartment dress-up. She's a tool. Like a tractor used to plow a field. All that matters is HP and et. I'll put an LME in it if it blows.
2020 ZL1LE A10.
#67 |
Petro-sexual
Engine Masters has a good, new, episode on heat shielding that was quite surprising.
#68 |
I can't find a way to watch it that doesn't require a subscription.
2020 ZL1LE A10.
#69 |
The SS version of the Roto-Fab effectively has a closed box, because its top edge seals perfectly with the hood (I can tell from the indentations the rubber strip made on the hood liner).
If it had a larger diameter inlet pipe, I think it would be the absolute best for the ZL1, not sure why they went with the partially open box design for the ZL1 and BG variants... killer looks maybe?
#70 |
I hope not because when you actually look at it closely it's very unattractive. The closed one looks better.
2020 ZL1LE A10.
