Old 10-08-2021, 01:04 PM   #57
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Originally Posted by IneedAZ View Post
Be nice if the gauge and software companies went to Lambda only which will force everyone to speak the same language...The 1st day of tuning i asked my tuner what Lambda he likes and he said he likes AFR...Just makes it more difficult for us novices. As far as the SOI tables..i know mine were adjusted, but since i am not familiar with them i dont know to what extent.
I tried to do a log last night, but with our temps still near 90 my DR heat up quickly and cant get a WOT more than second or two without having to back off. I started at 26Cold, but the time i got to the street to test it i was 28/29 psi. I put it at 26 thinking with cooler weather i will drop to 24ish cold. Might be another month before i see the cooler weather that will drop them. Guess for now i will drop them myself.
Were you trying from a dig or a roll? I can't go from a dig on the street. I have to roll into WOT from 4th-gear at about 2000-RPMs. If I try the same in 3rd, at the same RPMs, 9-times-out-of-10, the MTs just start spinning and I start to go all over the place and sometimes get some TMA. Maybe try from a higher gear, if possible. It's not safer, but unless you go to a track, you might not have much choice.
'20 ZL1 Black "Fury"
Old 10-08-2021, 04:34 PM   #58
IneedAZ
IneedAZ's Avatar
From a roll, probably 40mph range..
If weather holds tomorrow I will try my adjusted tune...I lowered the KR closer to stock and richned the MAF.
Old 10-08-2021, 06:13 PM   #59
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
I would try 555r2's...imo they are better for rolls then the MT's on the street. At the track MT's dominate but the street tears them up and they loose a lot of traction when the tread starts to ball up on them.
Old 10-08-2021, 06:35 PM   #60
IneedAZ
IneedAZ's Avatar
I am using the Nittos...I will drop them to 25 tomorrow and see how it does.
Old 10-09-2021, 07:02 AM   #61
JANNETTYRACING
JANNETTYRACING's Avatar
i agree and that is what i would prefer...just got complicated cause the dyno at Fasterproms displays in AFR and on top of that i read that it is based on 14.7 Stoich, not the 14.1 our car are based on.
There is really nothing complicated about it, you have a gauge in your car set it to lambda and tell us what is says at WOT.
I explained in the other thread all O2 sensors are really Lambda sensors, narrow or wide band.
The gauge converts it to an AFR based on the type of fuel entered.
Default for gauges on our US market are based on Gasoline but you can go in to the gauge and tell it what fuel you are burning.
But it's far to confusing which is what you've been battling for weeks now.
Higgs simplified it perfectly, % enrichment!
18% is Ideal for DI engines for Best Power/ piston/valve/exhaust component protection.
100-18=82 Get it?
People aske me all the time, how can you make 725 RWHP on 93 octane on a stock LT1 and have it Live?
One of clues are here.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 10-09-2021, 04:02 PM   #62
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Thanks for the input King’. I’m going to try those next. They have gotten tore-up pretty bad. The sway is the worst…
Old 10-09-2021, 04:09 PM   #63
IneedAZ
IneedAZ's Avatar
So much for my test today..my new aem sensor appears to crapped out only showing 2.0 Lambda with an occasional flicker of a regular reading. My Aeroforce wideband is having trouble as well. I was trying someone else's channel and chart list and when I tried to restore my previous one it doesn't like it. Of course no info on setting up Aeroforce wb in Lambda.
I found the tuning school offset spreadsheet for afr but nothing for Lambda. Aeroforce uses 0volts for 10afr and 5volts for 20afr. Anyone know how to convert it for the transform function in HPT?
Old 10-09-2021, 06:40 PM   #64
IneedAZ
IneedAZ's Avatar
Glad i bought a spare sensor a couple weeks ago...i changed out the AEM sensor and it now works again. I went out and tried another hit, but with the evening temps still over 80 i had to back out cause of wheel spin. For the short ride i did see encouragement. At e31 and after i richened it and reduced the KR sensors closer to stock my Inj pw was 5.7-5.9 at .85-.87 Lambda. I really need a clean pass to for a true evaluation. I am happy with those numbers. Fuel pressure held around 80psi low side and 3300+ on the high side. As far as i am concerned thus far, e30 is doable.
Old 10-09-2021, 07:50 PM   #65
JSH
JSH's Avatar
Drives: '20 ZLE
So you're saying you make 725 wheel on pump gas and a tune and no other mods?! Must be something of a world record!
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 10-09-2021, 07:57 PM   #66
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
I think he's saying it's a stock LT1 shortblock. The general consensus is once you get above 600-650 WHP you should change out the stock LT1 pistons & rods since they're a weak link. Ted is proving what many of us have seen firsthand: a good tune and solid fueling is the key to making your Gen V DI engine live.
Old 10-09-2021, 08:08 PM   #67
KingLT1
KingLT1's Avatar
Ted is simply saying that by targeting 18% rich(.82 lambda) @ WOT it allows him to push a stock long block LT1 much further then most say they will safely go. Is this stuff really that hard to figure out? Lol
Old 10-09-2021, 08:12 PM   #68
JSH
JSH's Avatar
Drives: '20 ZLE
I missed the "stock long block" part. It doesn't really read that way.
2020 ZL1LE A10.
Old 10-09-2021, 09:10 PM   #69
KingLT1
KingLT1's Avatar
Yea I know what you are saying...I was just ball busting. lol
Old 10-09-2021, 09:45 PM   #70
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
This is JSH we’re talking about here. Lately he’s huffing down some really good paint fumes, or that weed in Colorado has got some other good shit in it..
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
