#57 | |
I have tested, logged, and tuned, 3 different superchargers on 1 car on the street. I have data logs and the tuning files on my laptop with the proof. You can choose to believe who you want...but remember I am not taking your money. I am offering free advice based on my independent testing on my own free time. Good Luck
#58 | |
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq |
#59 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
Is E85 readily available in your area? If so, you could drop your boost a pound or two, run E60 and make similar power with less heat and less overall stress on your motor.
I live in fear that E85 will go away at some point. If it does, I'll probably open my motor back up and install lower compression pistons.
Baby Blue
#60 |
![]() ![]() ![]() Drives: 2019 ZL1 Riverside Join Date: Apr 2020
Boosting an engine not originally designed for it (LT1) is always dangerous.
#61 |
If I had purchased an LT1, I would have maxed the design thru custom valve train, heads, Long tubes, Hi-flow cats, custom heat exchangers, and air inlet
2020 ZL1LE A10.
