Old 03-09-2022, 12:24 AM   #57
Tconn
Drives: Chevy Camaro 2016 2SS
Question, did you tune your car after installing the lt2 intake manifold? if so, what tuner did you go with?
Tconn is offline   Reply With Quote
Old 06-01-2022, 12:52 PM   #58
ApollosChevy
Drives: 2021 Camaro LT1 A10
Originally Posted by BlackbeastSS2 View Post
You might want to torque them down to the correct torque values.
1. First pass 44 lbs
2. Second pass 89 lbs
Even if your saying 75 to In./Lbs. (Nm) that’s 102 lbs.
hey do you know if this is the right sequence order? i atttached a pic right here -> https://ls1howto.com/howto/geniii/in...//IMAGE017.jpg
ApollosChevy is offline   Reply With Quote
Old 06-01-2022, 04:15 PM   #59
Booher
Booher's Avatar
Drives: 2019 zl1 6 speed
You can get the sequence order from msd intake install pdf.
Old 06-01-2022, 09:21 PM   #60
laynlo15
Drives: 2022 Lt1 A10
Inch lbs. not foot lbs. When I was with Magnuson I ran tech and a guy called me about broken bolts when he was torquing his 2300 Maggie to the heads. He was setting his torque wrench at 108 ft lbs instead of 108 inch lbs. He kept telling me the bolts must have cracks in them and wanted me to send him new bolts that weren't faulty. I explained he was over torquing them and he'd continue to break them unless he torqued them correctly. Once he figured out what he'd done he was pretty embarrassed to say the least. It was very clear in the instructions but he just messed up when he read them. I sent him new bolts and I never heard back from him again. All good
Old 06-02-2022, 07:04 AM   #61
Crushin_LT1
Crushin_LT1's Avatar
Drives: 2021 LT1 6spd
I did the same thing, we weren't paying attention to which torque wrench we were using. Embarassing.
Current: 2021 LT1 Camaro, 6spd, Crush, Corsa NPP, GMPP CAI, Soler Performance Throttle controller
Previous: 1997 V6 Camaro, 5spd, Black
Crushin_LT1 is offline   Reply With Quote
Old 06-02-2022, 12:05 PM   #62
ctrlz
Originally Posted by Timbo-1LE View Post
Think I solved the hose issue. Small 3/8 hose and buy this gm pcv hose with quick connect, lop off just after the bend down, and looks stock and functional. Amazon $12.
That's a nice fix! How does it connect to the existing hose stump? Is there a barbed fitting? Hose clamp? Are you just sliding the two together?
Old 06-02-2022, 12:28 PM   #63
laynlo15
Man it happens, I was just sharing some issues I saw while at Magnuson and not trying to shame anyone.
Old 06-03-2022, 12:33 PM   #64
Fraxum
Fraxum's Avatar
Originally Posted by LT4Greg View Post
Now you should get a Roto-Fab CAI for your LT1!
And make sure you get a longer connection tube from RF. Otherwise it is a stretch. The RF dry adds another 5 hp!
