#57 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
TC doesnt use brakes to manage tire overslip on exits, but Stabilitrak sure does use them to manage over yaw situations to prevent excessive angles between a car's direction of travel and steering wheel. Camaro does not benefit from running staggered pad compounds F vs R. Its braking balance is designed for the same torque F and R. If you run higher torque up front this in effect with move brake bias to the F and hence will induce more understeer on entries. There is zero benefit in doing it and it will unnecessarily over work the F brakes as R will be doing less work. The fact the R wear faster is most likely due to Stabilitrak engaging too much, but could also be due to different pad ware rates between the two. Zero issue running nannies to learn and enjoy the car. Having said that, it does make a difference what mode one is running in. Id suggest PTM Sport 1 vs default at start up for example. If you havent had a chance to read it yet, take a look at the sticky above titled PTM Modes Demystifed. Read the very first post in that thread as it summarizes it all. Cheers and enjoy your car! |
#58 | |
If you decelerate an equal mass in a shorter distance you will produce more heat. Nobody here has any heat issues with lower torque stock pads. Virtually everyone that upgrades to a high torque pads ends up with cooked pistons, brown calipers and sometimes cooked brake fluid. But like i said before, a type of venue will play a role. Also how much somebody pushes the car and what lap times they get will play a role. Ive never said that late braking doesnt allow for trail braking. To the contrary. Trail braking is about moving the whole sequence of braking later and deeper on the entry. So very much part of effective "late braking" while maintaining proper balance and managing weight transfer for as quick a rotation as possible. That's why a *smooth* initial bite, excellent modulation capability and release is a preferred characteristic of any TRUE race pad. Let's not confuse what resellers market as "race pads" to a Joe Public vs what race teams use. Ditto caliper designs, rotors, cooling, etc. Cheers! |
#59 |
![]() Drives: 2019 ZLE Join Date: Jul 2020
Another example. Take a ZL1 with OEM pads and apply enough pedal force to activate abs at a defined speed. Now swap pads to race. With the same pedal force you will activate abs sooner. That’s what is creating more heat in that specific use case. And because it activates sooner, your stopping distance is shorter. Once into abs, both systems are performing the same. Take a ZL1 with oem and run consistent laps. Swap to race and try and replicate that lap. I guarantee you will blow the braking zone, slow the car more and have a lower entry speed.
Now I surrender |
#60 | |
Now I really surrender. |
#61 | |
#62 |
At its most basic, it doesn’t matter. It could be any pad that has a higher coefficient of friction at a given moment in the braking event, all else being equal. The higher torque pad will decelerate the car faster at the same pedal pressure, creating more heat and a shorter stopping distance. The natural compensation is to then brake later to execute the corner in the theoretical fastest line. That results in higher speeds before braking. Again, more heat. I can guarantee that when people switch to race pads, they are braking later because they can decelerate faster at a given pedal application, to achieve the optimum speed at turn in for the theoretical best line. With OEM pads they are, carrying less speed, braking earlier and decelerating at a slower rate. Thus less heat. Throw in any of the infinite number of variables and the results are different. But the basic principle is the same.
#63 | |
![]() ![]() ![]() ![]() Drives: 2018 ZL1 (SOLD) 992 GT3 (current) Join Date: Aug 2013
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
#64 | |
#65 | |
I have a feeling that the late braking I do is more because I know the track better than my competition and am willing to drive more aggressively. It’s not everything, but it’s something
#66 | |
#67 |
Put the SS1LE brake cooling deflectors on today and also took off the metal shields covering the bottom inside surface of the rotors
Next up will buy battery operated fans, titanium shims and Castrol SRF!
#68 |
![]() Drives: 2020 ZLE Rally Green A10 Join Date: Sep 2016
Boiled my brakes twice at Sebring, here for the learn.
#69 | |
#70 | |
Also, low/medium torque pads provide easier modulation of brakes during the entry phase, as a driver has a wider band of pressure available to them before locking up (or inducing ABS), or over slowing. And hence it is easier to vary pedal pressure and achieve better results balance and hence pace wise. What matters much more for lap times is not where threshold braking begins, but how much SPEED is carried from turn in to apex. Because, one will spend much more time in that phase vs the former. If one reads brake and brake pad descriptions by manufacturers who provide hardware to pro series (vs resellers focused on retail market), it is easily evident that: high torque pads apply only to full racing slicks and full aero cars (prototype, open wheel types) where tire grip is insane in comparison to any street track car, hence a lock up is unlikely. Smooth initial application (vs on/off switch offered by many high torque pads) is seen as a *must have* quality for any pro GT type cars, including those on harder spec skicks etc, basically cars with less grip vs full aero cars. PAGID has been providing pads to many pro GT level teams incl IMSA, LeMans, Porsche Cup, etc etc. Check their mu tables. PCF has also been providing pads (and whole braking assemblies) to top level series including IndyCar, Conti series, IndyLights, etc. Bottom line, they know brakes. This is how they describe a couple of their pads and their intended applications (shortened version to make a point): "08 Compound gained immediate favor in Endurance Sportscar and GT racing due to its performance in applications where smooth initial bite is a must" "11 Compound... The result is ultra-smooth braking with reduced wheel locking at the end of a stop. 11 can be used in a large spectrum of temperature ranges...It is ideal for use in medium- or low-grip situations such as hard spec tires or light cars with no downforce. Basically, all pro pad manufacturers recommend specific pads to pro teams based on: venue, tires, downforce, duration, heat management of related components, etc. You will never seen them pushing a highest mu pad as "the best". Because, based on the application it may be "the worst"! Unfortunately, it seems the current retail marketing has discovered that high mu = "race" marketing = sales. (And not only pads, but after market "race" BBK, enhanced "race" components, "race" cooling solutions, etc as now ppl have to deal with HIGHER HEAT. As such, i am sure some folks are spending thousands ONLY becase of a pad choice. Ridiculous proposition in my book anyway. Imo running extreme level torque pads on a non aero car with street (or R comp) tires on, with brake components not designed for, nor capable of dealing with high temp "sweet spots" of such pads is counterproductive on many levels. But, we live in a free world and this is supposed to be fun, so i will retire from this subject now. Let's just not confuse retail marketing of "race" vs real racing. Cheers! |
