Old 05-11-2021, 05:43 PM   #57
Timbo-1LE
Timbo-1LE's Avatar
Drives: 2017 SS 1LE
Thx. Told Katech what I use the car for and they spec,d it. Remember this keeps VVT, just limits at certain points... I'm sure they know what they are doing... And agree them keeping the same CR @11.5 is.key. Also NOT using the gm ported heads...
Timbo-1LE is offline   Reply With Quote
Old 05-13-2021, 12:57 PM   #58
Timbo-1LE
Timbo-1LE's Avatar
Drives: 2017 SS 1LE
Correction, I checked and they do lock out vvt. He said it is unreliable and hard to control with stronger springs.... so I was incorrect. I also asked about the gm port job and loss of compression ratio and the low end drop you saw. Appears they surface the heads to keep CR up... So appreciate your input on your results. Still going forward...
Old 05-13-2021, 02:41 PM   #59
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Originally Posted by Bomicino View Post
If you are going for tq with the hot cam you may be disappointed. I only have 456 lb ft with long tubes, E, PTB, rotofab and the LT2. Soggy below 3500, rips hard past that. Maybe the bump in CR will aid in TQ. Good luck
Compression is key to maintaining low-midrange torque.
Old 05-13-2021, 06:45 PM   #60
cmitchell17
Drives: 17 2SS, 8L90, Cam, Heads, E85
I think the GMPP test car they had with the cam/heads ran in the middle 10s. I can't find the exact number. I think it also had the GMPP 8L90 torque converter too.
cmitchell17 is offline   Reply With Quote
Old 05-13-2021, 07:46 PM   #61
Timbo-1LE
Timbo-1LE's Avatar
Drives: 2017 SS 1LE
Thanks. Mine is 1LE and really only road course, and with manual, just need to keep it spinning. One note, once I saw the size of the dod lifters, that alone should help it rev a bit faster..
Old 05-14-2021, 09:28 PM   #62
Bomicino
Drives: 2020 LT1
So Katech specced a cam, not the GM hot cam?
Bomicino is offline   Reply With Quote
Old 05-15-2021, 05:41 AM   #63
Timbo-1LE
Timbo-1LE's Avatar
Drives: 2017 SS 1LE
No, we are using the GM hot cam, the rest is their process and components. GM cam has less lift, but more duration than their Torquer 1 cam.
Old 07-14-2021, 05:41 PM   #64
Timbo-1LE
Timbo-1LE's Avatar
Drives: 2017 SS 1LE
Well it's finally up at Katech getting upgrades, should be a hoot when complete...
Old 07-14-2021, 10:55 PM   #65
Tim M
Tim M's Avatar
Drives: 2018 Camaro SS 1LE
We await your numbers and impressions!
Tim M is offline   Reply With Quote
Old 07-15-2021, 09:05 PM   #66
Bomicino
Drives: 2020 LT1
Nice, are you going E? I hope you get 20+ more than i did. Comparing numbers is far from accurate, but if it goes well, I may yank my heads off too.
Old 07-16-2021, 05:15 AM   #67
Timbo-1LE
Timbo-1LE's Avatar
Drives: 2017 SS 1LE
No E... They did a baseline dyno run, so we will know the difference.
Old 07-16-2021, 08:04 AM   #68
6spdhyperblue
Drives: 2SS 1LE
You’re in florida and not running E?
Old 07-16-2021, 04:07 PM   #69
Timbo-1LE
Timbo-1LE's Avatar
Drives: 2017 SS 1LE
Work in progress. thx for update Mike! Baseline run before tear down
Old 07-25-2021, 01:17 AM   #70
Motor Fast
Originally Posted by Timbo-1LE View Post
Sent a check to Katech, head porting, LT1 hot cam, new valve train, oil pump, a few other items. Focused on torque and reliability. Should be dropping it off in 8-10 weeks. Get a dyno'd so should have numbers...
Also one point of compression ratio, not CC... But they listed like five items they are doing to my heads.... He also said to keep the LT2 manifold.. He said they have had good luck with them, his view was 5 HP from MSD, 911 hunting
I'm debating on having Katech do some work on my 1LE. It's nice that they pulled your motor, doing a clean job. Was that yours are their recommendation to go with the GM camshaft over theirs? Who did you use for shipping your car?
2002 Camaro SS | 2003 Corvette Z06 | 2008 Corvette | 2012 Corvette ZR1 Inferno Orange with PDE | 2016 Corvette Z06 C7.R | 2018 Yenko Camaro
Motor Fast is offline   Reply With Quote
