#57 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 22' Porsche PDK GT4 Join Date: Mar 2018
I think it is because they want to preserve it for the ZLE, as it is the single biggest difference in handling over other models. Sure the DSSV's are more track focused over the MRC, but the single biggest difference in handling are those solid bushings.
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers) Previous: 18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust) 16' F80 M3 (Ohlin R/T Coilovers) 13' Audi TTRS (APR Stage 1, MSS Springs) 09' C6 Z06 08' E90 M3 06' 335i (KW V2 Coilovers) 03' C5 Z06 |
#58 |
Geoff
Drives: 2022 SS 1LE Join Date: May 2013
I think there is a downside, although slight. I've experienced more noise on some of the grooved roads around here. It seems to be a trend for new concrete to groove them in the same direction as the roadway. With the G3F1 tires it is quite loud, it is louder now on some, but not all of the tollways. I don't know why it is on some roads and not all......must be a frequency thing.
#59 |
![]() Drives: '17 Summit White ZL1 Join Date: Jul 2017
If I go with the GM 1LE solid rear cradle bushings and am not equipped to install myself, should I look to Chevy Performance Dealer for install or private shop. I'm in SoCal if anyone has suggestions.
Gregory -2017 Camaro ZL1
#60 |
Geoff
IMO a dealer, because if they mess up, they'll fix it and the rate will be fixed no matter how long it really takes them
#61 | ||
![]() ![]() ![]() Drives: 2020 Zl1 A10 Riverside Blue Join Date: Mar 2020
I used the same method to remove rubber bushings but the front bushing didn't want to come out without heat. The rear came out with no heat. |
#62 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 Porsche 911 Turbo S Join Date: Jan 2017
If you find any SoCal recommendations let me know. I have mine and was going to do it myself... I just don't know if I feel like it.
IG: 2fast2nick
-- Current -- 2012 Porsche Turbo S - PDK - Basalt Black Metallic -- Past -- 2017 Camaro ZL1 Coupe - Red Hot - A10, PDR - HRE P101 2015 Mustang GT PP - Whipple Supercharger |
#63 |
All I can say is GM dealby me wanted between $1500 - $1800 for labor to install. I sent them to hell and started doing it myself.
#64 |
oof.. yeah I'll do it myself for that price.
IG: 2fast2nick
#65 |
![]() ![]() Drives: SW 1SS 1LE / Jeep XJ Join Date: Mar 2016
It's not a 2hr install, and at 120-150 an hour can easily get up there.
You can definitely DIY it's not that difficult but if you just started doing oil changes yourself it's a little bit of the deep end. |
#66 |
#67 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1ss camaro Join Date: Feb 2016
yea i got a price on the kit and the labor at my buddys shop he said 3-4 i believe so the install is almost as much as the parts haha
#68 | |
![]() Drives: 2019 ZL1 1LE Join Date: Feb 2017
Old: 2017 SS 1LE
Old: 2017 ZL1 Current: 2019 ZL1 1LE |
#69 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
I plan on getting my 1LE kit in by AutoX season, recently got the eLSD AutoX flash, I figure the solid bushings + eLSD tune ought to be a lot of fun. Still undecided on wheels/tires, tbh seems like a ton of cash for a 315/18 square setup and I should just stick to using OEM... I'm just not that competitive, lol.
#70 |
Agree, MRC is amazing but spring rates are low for track damper settings, it's a compromise for sure.
