Old 06-22-2021, 09:20 PM   #57
Vileintent
Drives: 2017 Camaro ZL1 A10
Yep, lifting the lock a bit like you said allowed me to get at the clips on the side of it, and boom it came out easy after that. Thanks a million.
2017 ZL1 Black, A10
Build: Magnuson 2650R, 103NW Throttle Body, Rotofab Big Gulp, Kooks 2" headers, Catless, AWE Touring exhaust, JRE Smooth Idle Cam, Katech Oil Pump, Elite Catch Can, JMS Fuel Booster
Vileintent is offline   Reply With Quote
Old 06-23-2021, 06:17 AM   #58
ZLE dude
Drives: '18 ZL1 1LE
I love it when a plan comes together! Great to hear. You're most certainly welcome.
2018 ZL1 1LE - Summit White, PDR, Rotofab CAI, 95mm TB, CSP 2" catless LT's, JMS Voltage Booster, AEM X-series WB, DSX flex fuel sensor, Banks Data Monster, Tuned by Ted Jannetty, 5% Tint, Blackvue DR900S-2CH, Diode Dynamics lighting, IGL Kenzo ceramic coating
ZLE dude is offline   Reply With Quote
Old 06-25-2021, 08:03 PM   #59
Vileintent
Quick update - when I went to put the white wire (pinned) back into the connector, it would only go in about half way, wouldn't click in, no matter how hard I pushed it, so I couldn't put the lock back in. The white wire is too thick as-is.
After fighting with it for a while, I cut the copper thickness down, repinned it, and it finally clicked in. It wasn't pretty and I probably could have added a slightly smaller wire in between but I didn't have one and things seem to be working fine.
2017 ZL1 Black, A10
Old 06-28-2021, 01:30 AM   #60
dbs1
Drives: 2017 ZL1
With the addition of the jms what general rule of thumb for rwhp can be supported?
dbs1 is offline   Reply With Quote
Old 06-28-2021, 06:09 AM   #61
ZLE dude
Drives: '18 ZL1 1LE
Yeah, that white wire is a fatty. I forgot to mention I had taken a very small file an made the white plastic part a little thinner for that one pin to get it to snap in. What you did should work fine though.
Old 06-28-2021, 06:12 AM   #62
ZLE dude
Drives: '18 ZL1 1LE
From discussing things with some tuners, on E60 you can get up to around 675 wheel without any issue. The high side is where you have problems (need a cam w/fuel lobe). If you decide to toss on a blower and cam, you can make around 850whp on 93 octane. Unless you are wanting to run E at higher horsepower levels, I'm not sure the low side really needs anything else, and at that point you likely need injectors as well for the added flow if wanting to run E over 700whp. Just my .02 cents.
Old 06-28-2021, 09:31 AM   #63
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
My low side has been easily keeping up with high side on 93 octane with around 200+ whp over stock. Based on injector timing and high/low fuel pressure I assume it could another 100 whp and still be ok, again on 93. Most of the time though when hitting 800+ whp I start to see meth/water get involved on stock fuel system on 93 octane.
Old 11-22-2021, 11:07 AM   #64
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
Originally Posted by 20Bluezl1 View Post
Nobody with a JMS knows if the green lights stays on all the time?
Mine is on all the time, that I've had the patience to look at anyway. I contacted JMS and sent them the model/date for my unit This was because the directions state that a "GM Specific" booster is required because the FSCM has power to it all the time (about 1/2 way down on pg 2 of instructions). My concern was that I may have gotten a non-GM specific booster and would run down the battery.
They responded quickly and said all models now have GM programming.
Old 11-22-2021, 11:51 AM   #65
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
OOO!!! Thanks for posting this updated information!!!
'20 ZL1 Black "Fury"
Old 11-22-2021, 12:16 PM   #66
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
Old 02-06-2023, 02:32 PM   #67
clg82
Drives: 2020 Camaro ZL1
Subscribed because I may be going down this road soon.
Old 02-06-2023, 03:20 PM   #68
ZLE dude
Drives: '18 ZL1 1LE
Well I'll chime in and say it's been over two years since I installed my JRE 125 flex package and it's been a fun 35,000 miles of daily driving. I've had zero issues out of this setup.
Old 02-06-2023, 03:31 PM   #69
clg82
Are you able to see the "E" content with your i dash? and how long did it take you to get used to what percent of E to use VS premium etc?
Old 02-06-2023, 04:21 PM   #70
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Yep, iDash shows E content.
tms, xxx zl1
