#57 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
I still like my RX-8 a lot but sometimes it does a little bit tiring to have it rev high to keep up with some of the more powerful family cars. With the Camaro SS I just need to lightly tap the throttle in daily driving. That said, I still need to get used to the redline in the car. Have to realize that I can't rev to 7k+ RPM anymore. I kinda wish the Camaro has a centre tachometer, which makes reading it easier. The shift lights help in the more spirited drives.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
#58 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 22' Porsche PDK GT4 Join Date: Mar 2018
If the motor has a great mechanical sound (E90 M3, GT3, GT4), it's glorious. Now if the motor doesn't have a great mechanical sound and sounds like it is straining up top then I prefer a V8 or Turbo. But you combine a great mechanical sounding motor and high revs and its pure sex.
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers) Previous: 18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust) 16' F80 M3 (Ohlin R/T Coilovers) 13' Audi TTRS (APR Stage 1, MSS Springs) 09' C6 Z06 08' E90 M3 06' 335i (KW V2 Coilovers) 03' C5 Z06 |
#59 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Oct 2011
Well it does, on the HUD.
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD |
#60 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '18 1SS 1LE Join Date: Sep 2017
I also spent many years in a Turbo Buick (incognito GN) that revved to a whopping 5,400rpm.
'18 1SS 1LE Black, PDR
#61 |
google it : ENZO FERRARI ...Enzo Ferrari was once quoted as saying "Horsepower sells cars, torque wins races". Obviously Mr. Ferrari believed that torque was most important of the two provided that both were present in sufficient amounts.
#62 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
And what is this "google"? I don't speak baby-talk.
#63 |
Shifts under load
Drives: 2020 Camaro 1SS 1LE rally green Join Date: Apr 2017
Gotta say, I'm glad to have a 2020 SS 1LE in rally green. Dig that GT350, but I will never pay MSRP for anything with wheels. Obviously the GT350 and others command it and do have great resale though.
HPDE - southeast - JTI- solo, PCA- blue. 22 Suzuki GSX-S 1000GT blue |
#64 |
![]() Drives: 2020 SS1LE Shadow Gray Metallic Join Date: Feb 2018
They were selling brand new GT350’s for $5-7k off MSRP in the Northeast last year into this year. Sales slowed once the GT500 was announced.
#65 |
![]() Drives: 2020 Camaro ZL1 1LE Join Date: Mar 2020
If you want to track a car, and many of us do... you should be aware the GT350 and GT350R's have had a significant number of engine failures... by that I mean parts exiting the block violently and leaving holes you can put your fist in. Most all failures have been on rapid decel from a high speed where the rods break and.... you know what happens from there. The early cars are really bad for this... the 19's seem to be holding up. But Buyer beware on the early ones.
#66 |
![]() Drives: 2020 2SS 1LE Join Date: Jun 2011
Not to sir the pot but most Ferrari's don't really make that much torque...the only reason they make the power they do is because they turn the RPM they do. Take a 632 cid big block and turn it 10,000 RPM and it will make a shit load of HP and TQ....but that is a different subject all together.
As for the Shelby's destroying themselves I haven't had a single issue with mine other than a stuck open thermostat. I don't bounce it off the limiter nor try and turn 8200 RPM every time I leave the garage with it. It would seem most of the issues come from a failed oil pump, similar to the early LT stuff in cracking gears. Most of the guys are blower guys that do it and almost everyone says do billet gears if you want to turn more RPM and/or run a blower. The oil use issue...don't know on that. Could be rings, could be that plasma sprayed on liner...hard to say. Again I use more oil with the 1LE than I do the GT350. Power is power is power....RPM is just a part of it and geared correctly it doesn't really matter what kind of RPM it makes so much as it has to make a lot of average power over the course of that range the car is geared for. That being said...higher RPM doesn't really mean it will live any longer either. You can (and we have at work) made LS engines turn 7500, 8500, 9500 RPM but it isn't cheap to do it, and I wouldn't expect them to last 100,000 miles. So I'm happy either way. The 1LE is a bit more fun stop light to stop light but yeah I like blasting on track with the GT350 too....they both share a special place in my eyes. |
#67 |
Shifts under load
I used to work at a Ford dealer and have stayed in touch with one of my techs. He tells me all the time about 5.0 engine issues and I read about the Voodoo issues on the forums. We also have our share of LT1 engine issues as well, maybe not to the extent of the Coyotes though. They also have the garbage MT82 issues. I owned two, I know about those.
#68 | |
yeah that MT82 trans is horrid from what I understand. Thankfully they didn't use that in the 350 cars. I guess the same could be said for the LS7's as well. I daily drove my 08Z for 80k miles and tracked it, never had an issue. Read the Corvette forum and they die by the thousands weekly. |
#69 | |
Granted, I don't track, but I don't baby my car on the street either.
Current:
#70 | |
Current:
