Old 10-08-2019, 05:08 PM   #57
Trochoidal
Drives: 2017 Camaro 2SS A8
Originally Posted by Booher View Post
When the directions said to put the bumper on the ground, I assumed that meant take it off, my bad.
Get access to the area shown below by removing the top screws and wheel well screws of the bumper enough so that it can sit on the ground. Using a jack on the driver’s side is suggested since it helps the bumper sit lower.
Update: I emailed the guy, he confirmed, this is one of his only parts that you dont have to remove the bumper. Also, in the directions, I didnt see the crash bar re installed in the pics so asked about that as well. It goes back in, it just isnt in the final pics. I'm gonna order one tomorrow I think and give it a shot. They look pretty big in the ford cars, so they have alot of reviews. From what I can see, rain isnt a big deal, but you will suck up bugs into your airbox. Maybe that's what the plastic cover was originally for?
Yeah I was reading about this company on the Mustang forum. Like you stated this product is well received on that platform.
Did you notice these are 3D printed? Probably made to order.
Old 10-08-2019, 05:38 PM   #58
MackSteelPrivateEye
The directions show the bumper on the ground, but the person that made it says you can do it without taking it off. The verbage in the directions weren't exactly clear. That's why I posted a paragraph from it. It is only covering the heat exchanger a little, at least from what I can tell from the picture, and i dont think that little bit would effect much at all. I dont have it in my hands yet, I'm going to order it, probably friday and find out and get some hands on experience.
If it can be done with removing the bumper I will order.
Old 10-08-2019, 06:27 PM   #59
6spdhyperblue
Drives: 2SS 1LE
Originally Posted by Trochoidal View Post
Has anyone tried this approach? Before installing maybe address the possible water collection with a drain hole, barb fitting and a hose. For that matter, maybe just a drain hole.
https://www.velossatechdesign.com/pr...intake-snorkel
Install instructions:
https://cdn.shopify.com/s/files/1/00...Design.pdf?432
You’re the man
Old 10-08-2019, 07:01 PM   #60
Trochoidal
Originally Posted by 6spdhyperblue View Post
You’re the man
Thanks 6SHB! Time will tell. 5-9 business day lead time.
Old 10-10-2019, 07:38 AM   #61
appleman22
Drives: 2017 1ss 1le
in for results!
appleman22 is offline   Reply With Quote
Old 10-10-2019, 08:39 AM   #62
Booher
Booher's Avatar
Drives: 2019 zl1 6 speed
I ordered one as well yesterday, yes they are made to order. Here is part of the email I got.
Since your order is custom made exactly to your specifications, normal lead times are between 5 to 9 business days. We will notify you as soon as your order ships!
Doesnt seem to bad, comes out to $159.99 with shipping.
Old 10-14-2019, 06:39 PM   #63
driven2exceSS
driven2exceSS's Avatar
Drives: 2016 2SS BLK A8 Vert
Subscribed to hear the initial install/fitment and potential performance thoughts...
driven2exceSS is offline   Reply With Quote
Old 10-15-2019, 03:14 PM   #64
GooseSS
Drives: 2018 Camaro SS
In for results, looks like a cool idea!
GooseSS is offline   Reply With Quote
Old 11-01-2019, 07:11 PM   #65
6spdhyperblue
Drives: 2SS 1LE
Hey kids. It goes in with just removing the top plate and not the bumper. It takes some Tetris skills but possible.
A nice piece for the money
Old 11-01-2019, 07:59 PM   #66
Trochoidal
Well, it looks like quite the piece to ‘Tetris’. Hopefully I’ll get this in tomorrow. Do you have any special advice to share?
Old 11-01-2019, 08:42 PM   #67
6spdhyperblue
Drives: 2SS 1LE
Yeah it’s patience, pulling on the bumper, then seating it into the rubber around the headlight. You can reach in from the air filter and run your arm down behind the headlight to get the rubber seated to the outside of the scoop. Also unbolt the top of the bar so you can push it down while getting the scoop in. Once in you put it back. Then bolt the scoop to it
Old 11-01-2019, 09:56 PM   #68
Trochoidal
Again I want to say it now, thanks 6SHB!!
Old 11-02-2019, 04:17 PM   #69
2SSRedline
Drives: '18 Camaro SS Redline, '20 Bolt EV
Thanks for the info.
Have one ordered.
2SSRedline is offline   Reply With Quote
Old 11-02-2019, 04:57 PM   #70
driven2exceSS
Did you get your Tetris piece seated going through the top today as you had hoped, like 6SHB did? Additional thoughts??
