#57 | |
![]() Drives: 2017 ZL1 A10 Join Date: Feb 2018
I'd imagine that you're also an honest debt free self made multi-millionaire like myself so you should understand where I'm coming from, or possibly you're the equivalent to an acquaintance of mine multi-billionaire Bob Parsons? |
#58 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Challenger Hellcat, 2018 ZL1LE Join Date: Dec 2009
Greed will emprisson us all
2018 ZL1 1LE/Red hot 2019 Shellby GT 350R/ Oxford white/ Matte Black Stripes/ Carbon Fiber Dash/ Electronics Package #413 |
#59 |
#60 |
This thread turned into more talk about fuse pull and the NX lid but I was contemplating removing the baffle from the lid. For those of you that did it, what is your long term impression? Did it make a difference? Worth it? Any issues arise? Thanks!
#61 |
![]() Drives: 2017 ZL1 A10 Join Date: Jul 2014
I did it.. No issues have arrived but I've contemplated putting it back on though as I don't know that it makes a real noticeable difference. I only did it because I did a catch can at the same time so the lid was off.
Although having those tiny screws on the underside of the lid removed is somewhat piece of mind as there's no chance of going through the blower now. So I may just leave it, haven't fully decided. |
#62 |
![]() Drives: 2018 Camaro ZL1 (M6) Join Date: May 2016
I've had mine removed for around a month now. I hardly noticed a difference in SC whine, but that may be due to the corsa exhaust I have drowning it out. It's about a 30-45 minute job, so I'd still say it's worth it for the above mentioned reasons.
#63 |
![]() Drives: 2018 Zl1 Camaro Join Date: Feb 2018
I did it before I bought the NX Lid, it was worth it if you ask me.
#64 | |
![]() Drives: 2018 Red hot A10 ZL1 Join Date: Apr 2017
#65 |
So, I went ahead and did it last night. Weird thing was I got a check engine light afterward. Removed the negative battery cable in the trunk for about an hour and it went away. I actually feel like I hear less whine. Might be putting it back on just in case I have to go in for warranty work.
#66 | |
#67 |
Yes, I took the plate with the black backing off and installed everything correctly with the correct torque sequence/value. It may be possible the computer was “learning” or pulling power due to disconnecting the battery because the power seems to be back to normal and I do hear a bit more whine.
#68 |
![]() ![]() Drives: Red hot ZL1 A10 2017 Join Date: Nov 2016
Did remove it during my catch can install,
Noticed almost no difference after.... May be the rotofab is louder ... |
#69 |
![]() Drives: 2008 Evo X Join Date: Sep 2018
Anyone has pictures of what it looks like ?
#70 |
![]() ![]() Drives: 69 GTO, 05 GTO, 2018 Silver ZL1 Join Date: Jan 2012
The stock lid underside vs the NX lid.
