06-01-2018, 09:39 PM | #57 | |
Drives: ZL1 1LE SUMMIT WHITE Join Date: Feb 2018
Where did you source the spacers? I've got the same rims coming but only for street use. Track camber settings will be with oem rims/tires. |
06-02-2018, 03:56 AM | #58 |
SABIO
Dont think you will need spacers as you have DSSV on your car. The regular ZL1 doesn't, hence the strut tab grinding and possibly the need for a small spacer.
06-02-2018, 10:36 AM | #59 |
Lets hope so but just in case I'd like to know where to get a good quality spacer kit. (spacer and extended lugs)
Similar to H&R Trak+ kits. Unfortunately they don't do them for Camaros. |
06-02-2018, 11:42 AM | #60 |
SABIO
I picked up a set of Dorman 610-490 studs.
Let you use up to a 15mm spacer. Available at better local parts outlets.
06-02-2018, 06:53 PM | #61 |
Thanks!
Studs *check* Spacer........... |
06-02-2018, 07:15 PM | #62 | |
Probably tired right now
Drives: 1Lap1LE | EV6 FE | 18 F150 Join Date: Sep 2010
However check my profile for threads but I ended up doing Gen5DIY/Moreno camber plates and ran 19X11 +11 fronts with NO SPACER (just some minor strut tab grinding) and -3.0* camber with the plates installed.
-Seven
'17 SS 1LE - 1LAP 1LE (Now with more 427!) '18 F150 Platinum Powerstroke diesel '22 Kia EV6 First Edition '18 RS3 (1 of 2) Cumulus Blue '24 911 T (ordered) Formers... '19 RS5 Sportback Sonoma Green | '07 Cayman S 6MT | '16 Audi S3 Prestige Viper Green (APR Stage 3+) | '19 Mustang Shelby GT350R | '17 SS 1LE MBM 575whp all-motor |
06-02-2018, 09:29 PM | #63 |
Again... will be using OEM street settings with the new wheels and there "may" be a need for spacers. For track I'll be using OEM wheels and tires so I can play around with camber etc with no worrys. (Until I feel the need for more! )
Regarding Amazon spacers, without looking myself, are there reputable items there? I've always been impressed with the H&R Trak+ quality and fit & finish but like I said... no Camaro fitment. |
06-02-2018, 11:22 PM | #64 | |
Used the same one previously up front - No issues.
-Seven
08-17-2019, 09:29 AM | #65 |
Drives: 2018 Camaro SS 1LE Join Date: Sep 2018
Please excuse me but I’m a little confused after reading through this thread. So if you can somehow get OEM ZL1 1LE wheels they will fit our SS 1LE as long as I am using no more then the factory track camber/alignment which I am on which is -2 front -1 rear.
Conversely if I get aftermarket wheels, Let’s say Forgestar, in 19x11 front and 19x12 rear what would the offset be to fit w/minimal poke or z06 guards? |
11-25-2019, 09:54 PM | #66 | |
Drives: 2018 Camaro 2SS 1LE - Hyper Blue Join Date: Aug 2018
11-26-2019, 06:48 AM | #67 |
Drives: 1LEs Join Date: May 2009
The fronts will rub without a spacer but the easy grinding on the struts / strut mod removes the need for a spacer. I am at -2.7 front with OEM ZL1 1LE wheels with no spacer but struts have been ground. Do a search for strut mod or whatever for pics.
11-26-2019, 07:56 AM | #68 |
Ok so Rears will just bolt up following the GM Track alignment, and the fronts will either need a 3-5mm spacer, or grind away. Time to dig out the ol grinder. Thanks!
12-03-2019, 08:20 AM | #69 |
If I am just running the Track Alignment per the manual, would i need to run a 3mm or a 5mm spacer up front? If I dont need 5, id rather just go with 3
12-12-2019, 02:01 PM | #70 |
Also, how many threads will I lose between 3mm-5mm spacers? Biggest concern is if the 3mm is enough for stock ride height with the ZL1 1LE wheels on a SS 1LE
