#57 |
![]() Drives: 2016 2SS, HBM, NPP, Sun Roof Join Date: Jun 2013
I have them no issues, castles setup, used msd wires, the passenger side harness was secured tightly and away from headers, its hooked up to the stock npp for now, ordered a borla stype axelback but it was stolen off my front door smh and I've been fighting for a solution to that.
#58 |
![]() Drives: 2018 Silverado Z71 TxEdition Join Date: Dec 2017
I wish i found this thread awhile ago!!! I have the TSP headers on mine. also have the rubbing issue only turning to the right!!! have had the rack n pinion replaced and now the steering column is being replaced as we speak. A buddy has also just installed the same headers on his camaro and had the same rubbing issue. He said he contacted TSP and they said you have to replace the column bolts. Not sure why my performance shop didnt do this. this has been going on since oct 17'. i have a 3" xpipe as well and is extremely loud. i've also pulled the fuse for the NPP to reduce the rattling feeling from under the car. will double check the column bolts again when i get back tomorrow.
#59 |
![]() Drives: 2018 Camaro SS 1LE Join Date: Oct 2017
I had TSP headers with catless xpipe installed in mine and a bolt is included in the box with the headers that replaces the column bolt. Although we found out that even with replacing the bolts I still had my motor deflection because of the hydraulic motor mounts having such a high amount of deflection when I turned to the right even after dinging the header a bit for more clearance on a hard right turn it would still hit against the steering column. So I replaced motor mounts with BMR motor mounts and with those and the bolt replacement no dinging of the header was needed with the motor deflection being gone. I honestly can not feel more vibration than I did with the hydraulic OEM mounts. Btw the motor mounts are a real bitch to get out, at least the driver side was. new ones go in so easy.
PS I might turn a bit harder at times with my 1LE
#60 |
I've had mines on for 3 weeks, no rubbing issues, used the bolt that came with the headers, finally installed the borla stype axelback and it sounds perfect, very very loud though, the borlas took a lot of the rasp the npp had and deepened the sound, I'm satisfied with the headers.
#61 |
![]() Drives: 2016 Hyper Blue 2SS Join Date: Feb 2016
I've been tempted to get these in 2" but seeing all these rubbing issues even with the bolt is pushing me to spend the extra money on the Kooks which I haven't seen anyone have that issue with.
2SS Hyper Blue Metallic | A8 | Jet Black Interior | NPP Exhaust
Current Mods: Catch Can | aFe Lowering Springs | GM 2nd Gen Splitter | Hotchkis Sway Bars | MRR FS02 Wheels | Flowmaster Exhaust | Dark Tail Lights | Diode Dynamics Sidemarkers | Roto Fab | Solar TB | PRAY Ported IM | BMR | PRAY Tune Upcoming Mods: |
#62 |
![]() Drives: 2017 Camaro SS 1LE - Krypton Green Join Date: Jul 2017
I'm in the same boat as you...everyday I change my mind between TSP and Kooks...
#63 |
![]() Drives: 17 camaro 2ss Join Date: Apr 2018
I have the tsp 2". Upgraded bolt no issue there. Only issue header rubs shaft towards the top. Has header wrap around steering shaft. I can feel it on a tight turn but its no tearing up the header wrap so im not really concerned. Seems all the headers do this from what ive read. I didnt do the install, credit goes to pray performance.
#64 |
![]() ![]() Drives: 2016 Hyper Blue Metallic 1SS M6 NPP Join Date: Jan 2016
I just installed mine but was not aware that the cats would not fit the MBRP race catback. So I have to get a shop to modify something to make them fit.
2016 Hyper Blue Metallic 1SS M6 with body color hood vents, Silver broken 5 spoke wheels, NPP dual exhaust, Dark Night Interior Spectrum Lighting, Illuminated door sills plates. Upgrades include: Roto-Fab intake, Mishimoto catch can, MBRP cat-back Race exhaust, TSP 1 7/8 headers, EFI E85 Flex Fuel, MRR M017 graphite wheels with Nitto N555 G2 tires, Goodridge stainless steel brake lines, Powder coated Brembo calipers, BMR suspension, Eibach sport springs, Emblempros fender badges Order ID: TDHQMS 1100 on 01/07/2016 at Penske Chevrolet 6000 on 02/23/2016 Delivered to customer Last edited by Hyper1SS; 04-29-2018 at 06:46 AM. |
#65 | |
![]() Drives: 2016 Summit White 2 SS Join Date: Jun 2016
#66 |
![]() Drives: 2017 M6 2ss, Sunroof, Silver Ice Join Date: Apr 2018
Check out Juiced Motorsports website. I bought mine from them and had free shipping. TSP no cats and STOCK npp sounds crazy. When you get on it is super loud. Try using code “Camaro6” sometimes juiced Motorsports gives a discount
2017 Camaro 2SS, M6, NPP, Sunroof
Cold Air Inductions Intake, Mishimoto Oil Catch Can, Texas Speed 1 7/8" Long Tubes, Cat Delete. Tuned By Tom Wong @ Wong Performance 431HP & 424TQ |
#67 |
Love mine. once the darn new replacement bolt came in that wasnt supplied to my installer. little lock tite and 2 min of my time and its golden. Next will be the Tsp cam kit along with the heads getting machined and another tune. Hoping to be 650+ rwhp. not to mention that sweet sweet cam lobe sound!!!
oh and i still do have my NPP but pulled the fuse. helped to reduce alot of droning and vibrating under my seat. sounds siiiiiick!!! |
#68 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 2SS Join Date: Jul 2016
