Old 06-17-2017, 02:40 PM   #57
Goertz
Goertz's Avatar
Drives: 2016 1SS Auto
quick concept work of catch can/radiator overflow solution
will mount over where factory airbox use to go.
Plan is to use all factory crank case vents (pcv, both valve covers and the oil drain back to factory plastic catch can) then use the turbos to pull a vac on the crank case at all times
this could be used on a centrifugal setup also that would like to get rid of the horrible ugly plastic water resivor and need a solid crank case evac plan
Main rad line to water pump you would put a inline filler neck in.... Much cleaner setup and very turbo friendly for a professional install solution
Goertz is offline   Reply With Quote
Old 06-17-2017, 03:07 PM   #58
ChrisCoffey
ChrisCoffey's Avatar
Drives: 2016 Camaro 1SS Hyper Blue Metallic
Great work brother. I am interested in this but something more along the lines of twin turbo near 700-750 rwhp. I would still like to retain some dd and sleeper status. This set up would scare me thinking that if i hit the gas too hard i would end up in another country before i got it settled back down. Great job and it might be something i do bigger later so i assume for less on the turbo part would be the same. Thanks again for your work.
"Ask not what the camaro can do for you but what you can do with your camaro."
ChrisCoffey is offline   Reply With Quote
Old 06-19-2017, 01:24 PM   #59
aka Reckless
aka Reckless's Avatar
Drives: 2016 2SS Camaro
Looks good. Guess I wasn't thinking you had the brick hidden in the intake
aka Reckless is offline   Reply With Quote
Old 06-24-2017, 08:20 PM   #60
Goertz
Goertz's Avatar
added the injectors and rails to the intake manifold today
zl1 pump was put in tank on friday
engine is at machine shop, should hopefully get it back soon
trq converter will be ready on the 7th
going to be buttoning up here pretty soon now!
Old 06-26-2017, 09:36 AM   #61
aka Reckless
Hood clearance?
Old 06-26-2017, 01:11 PM   #62
Goertz
Goertz's Avatar
Hood clearance is for the weak
Old 06-26-2017, 01:12 PM   #63
2K16SummitSS
Resident Land Surveyor
2K16SummitSS's Avatar
Drives: 2016 Camaro 1SS - Summit White M6
2016 Summit 1SS 49th Anniversary Commemorative Limited Plutonium Edition - M6, Solo Axleback & !RearCats, Ultra-Rare Cloth Seats, Forgestar CF5V 19x10-285/35 19x11-325/30
2001 NBM Trans Am WS6, Wifey's Grocery Getter - Torquer V2 cam, Racetronix Fuel Pump, Yank 3000 Stall, Transgo 1-2 kit, TSP LTs, Magnaflow, Strano Springs/Koni STR.T shocks, 17x9.5/17x11 TTIIs, Ed Wright tuned
2K16SummitSS is offline   Reply With Quote
Old 06-26-2017, 01:18 PM   #64
aka Reckless
LMAO We have a few customers that would agree
Old 06-26-2017, 01:44 PM   #65
Turbo_RORO
Turbo_RORO's Avatar
Drives: Camaro 17 SS
That just flat out bad ass.
Turbo_RORO is offline   Reply With Quote
Old 06-27-2017, 06:36 PM   #66
Goertz
Goertz's Avatar
fab work 10gal e85 cell and 5gal water tank will be finished tomorrow when the last few fittings come in.
Old 06-27-2017, 06:54 PM   #67
solobaric
solobaric's Avatar
Drives: 2002 Camaro SS
Shiny!! Lol. Looks great.
2017 1SS Hyper Blue M6
2001 Ford Lightning
solobaric is offline   Reply With Quote
