Old 05-09-2017, 12:50 PM   #57
Start The Machine
Start The Machine's Avatar
Drives: 2016 M6 2.0T
Originally Posted by ChicagoTommy View Post
I have many questions! 4.6 is amazing! Congrats on the amazing numbers! Can you post the whole dyno graph? The right side is cut off where it details the amount of smoothing and the correction factor. What mods did you have that made 299hp on the stock tune? That is insanely high! Did you monitor the air/fuel ratio during the runs?
I'm very curious as well. If I could get to 300+ without voiding the warranty that would be amazing. That would keep me satisfied until the warranty expires then it's game on.
Start The Machine is offline   Reply With Quote
Old 05-09-2017, 01:29 PM   #58
Gutling
Drives: 2017 Chevrolet Camaro 2.0 LT
2017 A8
Sport, traction off
18"s
5.2
Felt like a great run, just a whisper of spin and toke off.
Gutling is offline   Reply With Quote
Old 05-09-2017, 01:33 PM   #59
Michigan1LTRS
Blessed ❤️
Michigan1LTRS's Avatar
Drives: 2017 1LT RS I4
Originally Posted by Gutling View Post
2017 A8
Sport, traction off
18"s
5.2
Great run. Did you build boost or just flat foot it? I know the 20's hurt my times, but i love the grey split spoke RS wheels.
Old 05-09-2017, 01:37 PM   #60
Gutling
Launched about 2500ish rpms. I tried a few from 2500 to 3000, and just go so muhc wheel spin above that i was getting 5.8s and slowers
Old 05-09-2017, 07:28 PM   #61
ChicagoTommy
Drives: 2017 Camaro; 2017 Acadia Denali
You need a pair of these.....
http://www.jegs.com/i/Nitto/726/40586/10002/-1
ChicagoTommy is offline   Reply With Quote
Old 05-09-2017, 07:47 PM   #62
Cgc15
Drives: 2017 1lt 2.0t white
Mods: zzp catless down pipe, enjen Evo, and custom catback exhaust.
I'm not sure if the about the AFR
Cgc15 is offline   Reply With Quote
Old 05-09-2017, 08:48 PM   #63
Evil-Bee-NH
603 Camaros
Evil-Bee-NH's Avatar
Drives: 2017 NGM I4 1LT Coupe
Looks like the numbers are right there with what we've seen across the board your making a bit more torque then me but you don't have the TCM bending you over.
Old 05-09-2017, 08:50 PM   #64
Evil-Bee-NH
603 Camaros
Nice run Gutling added you to the list finally another A8 time. Cgc15 has been tearing up the M6 list.
Old 05-10-2017, 01:57 PM   #65
Michigan1LTRS
Blessed ❤️
Ok, ran some 0 to 60 runs with the RPM charge pipe and ZZP intake tube. Every run was 5.8, same as my stock runs. BUT, conditions were very different. Today is 20 degrees warmer and humid compared to my stock runs. Also today I had 3/4 tank of gas vs about 1/8 of tank previously and I still ran 5.8. I will take it. I may have to go out at like 3AM to get some cool air.
Old 05-10-2017, 02:11 PM   #66
whiskeyfed
Pat
whiskeyfed's Avatar
Drives: 2017 Camaro 1LT I4 Turbo A8
Bump to update my time to make Jason work a little harder
Follow me on Instagram @whiskeyfed
Subscribe on YouTube Whiskeyfed Camaro
Follow my Build Thread The WhiskeyFed Camaro
Current Modifications: JacFab Boost-O-Lator, Injen Evolution CAI, ZZP Catless Downpipe, RPM 3" Charge Pipe, Mishimoto Oil Filtration/Coolant Systems, R1 Concepts Brakes Package, Eibach Pro-Kit Lowering Springs, PTP Lava Exhaust Wrap & Turbo Blanket
DYNO SHEET: 297whp / 374wtq
Tuned by #danytechtuning
whiskeyfed is offline   Reply With Quote
Old 05-10-2017, 03:20 PM   #67
ChicagoTommy
Take it to a track!
The best way to get the best numbers is to toss on a pair of drag radials, and launch on a prepped surface! These 0-60 numbers will come down a good bit on a track!
Old 05-10-2017, 03:26 PM   #68
Michigan1LTRS
Blessed ❤️
Take it to a track!
I know, I know you are right.
Old 05-10-2017, 03:34 PM   #69
Corner carver
Corner carver's Avatar
Drives: 2017 Camaro 2.0T RS
That's almost like cheating! Lol
As Delivered: 2017 Mosaic Black 1LT RS 2.0T | M6 | HD brake and cooling | Bose & 8"screen | Front lip extension | Blade spolier | Black bowties | Painted splash guards
Installed Mods: 25% Window tint | Headlight, side marker and third brake light Phastek tint kit | GM black taillights with Gen5diy LED harness and bulbs | LED license plate bulbs | Gorilla lug nuts, black | GM 'performance' center caps | RS and sheild badges removed
Old 05-10-2017, 03:39 PM   #70
Michigan1LTRS
Blessed ❤️
Yeah, I would be a cheater. I'll just stick to the back roads.
