Old 01-25-2017, 11:49 AM   #57
CAM-FIFTY
CAM-FIFTY's Avatar
Drives: 2016 Red Hot 2SS
Originally Posted by HDRDTD View Post
There was a long thread over on Camaro5.com about a person that lost oil pressure, shut it down immediately, dealer tore it apart, sent photos to GM for warranty approval and GM denied the warranty due to the fact he had a catch can installed, even though there was a known (by GM) issue with oil pump failures.
It was a very long thread, and I'm not sure if it ever got resolved to the customer satisfaction. IIRC, after GM denied the claim, the dealer ended up returning the engine still in pieces after the tear-down.
Can you post or PM the link to that thread? I would like to read the details...
If GM denied it because of the Catch Can then they must have had strong 'technical' reasons to back themselves in a court of law.
2017 Black Z06 2LZ M7
2016 Red Hot 2SS A8 - Sold
My Camaro journey here and here.
CAM-FIFTY is offline   Reply With Quote
Old 01-25-2017, 11:54 AM   #58
pinoyscorpion951
pinoyscorpion951's Avatar
Drives: 2016 Bright Yellow 2SS A8
http://www.camaro5.com/forums/showthread.php?t=451361
pinoyscorpion951 is offline   Reply With Quote
Old 01-25-2017, 11:55 AM   #59
BowtieRocket
BowtieRocket's Avatar
Drives: 2016 Camaro 2SS- M6
I agree, that could be very useful information. I can't seem to find it.
Another point of fact is the damages speculated are not proven at this point in my case. No oil analysis or any other means have been done to legitimize the diagnosis. They have requested feedback from GM to know who will be billed or responsible for the costs associated with repairs. If GM says yes they will warranty the repairs, the dealership said they will tear down the engine to find the cause. Also, it won't start. Not sure rod knock would be the sole culprit here...
2016 Camaro 2SS M6- Garage
BowtieRocket is offline   Reply With Quote
Old 01-25-2017, 11:57 AM   #60
CAM-FIFTY
CAM-FIFTY's Avatar
Originally Posted by pinoyscorpion951 View Post
Thanks!
Old 01-25-2017, 12:02 PM   #61
Marty McFlew
Drives: 17 SuperSport Camaro 6 on the Flo'
Originally Posted by BowtieRocket View Post
10k, but I bought it used with 6k
They probably dogged the hell out of it.
Marty McFlew is offline   Reply With Quote
Old 01-25-2017, 12:04 PM   #62
sub_ETCS_ret
sub_ETCS_ret's Avatar
Drives: 2019 Dodge Challenger Scat Pack
That would be my fear right there. Why did they trade it in after 6k.
"Submariners are a bunch of intelligent misfits that somehow seem to get along, understand each other and work well together." - overheard from a surface officer explaining to another sailor about Submariners
sub_ETCS_ret is offline   Reply With Quote
Old 01-25-2017, 12:15 PM   #63
Marty McFlew
Now I am worried that they won't warranty the work because of those modifications...
You just have a CAI mode ...right? They can't deny a warranty repair just because of that. They are probably playing you to see if you will fight back. And also even if it was beat to death by the previous owner as long as it has oil it should hold up unless it was a bad build to begin with. Keep on them and make them justify why warranty won't cover their product with just $10k miles.
Old 01-25-2017, 12:17 PM   #64
Marty McFlew
Actually...I do believe that the only case they'll need to prove anything is if the customer takes the issue to court. Even then, I think it's the customer's burden to prove their modifications did not cause the damage.
It's their warranty, and they reserve the right to deny coverage as stated in their disclaimers and exclusions.
But hopefully it won't come to that...
That should be easy to prove with just a CAI.
Old 01-25-2017, 12:26 PM   #65
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
I've seen/heard the informal cases against it. I wouldn't be so sure.
GM engineers' case of "what ifs" and "it coulds" is technically intimidating. But it could go either way depending on the effort and/or interpretations. Without data-logging on the customers' side to prove any given condition did not occur...it would be hard to prove anything...
Which is why I opted (when the time came) to install GM's Z/28 CAI. At the very least...they designed and marketed it.
EDIT: For the record, I'm not taking any one side or another...just being realistic...
Old 01-25-2017, 12:26 PM   #66
Marty McFlew
And I bet that's the last Chevy or GM car he will ever buy. Its ashame Chevy/GM can't be forward thinking in knowing in fixing such issue that probably would 1)Have a customer for life. 2)Recommend a GM product to other people. Sad.
Old 01-25-2017, 12:37 PM   #67
wavsine
________/\_
wavsine's Avatar
Drives: Gen6 NGM RS
Send a message via Yahoo to wavsine
Actually, it is GM's burden to prove your modifications voided the warranty. I have experience with this coming from Ford. A lot of the Focus guys mod their cars with CAI and catch cans and have not had a problem.
The Magnuson–Moss Warranty Act protects consumers in this area:
"The dealer/vehicle manufacturer has the right to deny a warranty repair but they must demonstrate that the aftermarket part caused the problem. The warranty remains in effect for all other covered parts"
https://www.sema.org/sema-enews/2011...ermarket-parts
Where a problem arises is a tune. Modifications to the ECU have been known to void warranties. There is also anecdotal evidence that it can be detected if a tune has been previously installed and removed prior to requesting warranty coverage.
As long as the OP's Camaro does not have a tune, it is my opinion that this warranty claim should be honored.
wavsine is offline   Reply With Quote
Old 01-25-2017, 01:39 PM   #68
CAM-FIFTY
CAM-FIFTY's Avatar
Just finished reading that camaro5 thread, summary - GM doesn't give a flying f** about MMWA or FTC or BBB or anything like that....you mod it, you risk it all.
Old 01-25-2017, 01:54 PM   #69
BowtieRocket
Yeah, I read through as much of the thread as I had time for. Sounds to me like there may be a cause for a class action suit...
Old 01-25-2017, 01:59 PM   #70
Richard0nee
Richard0nee's Avatar
Drives: 2016 SS M6, NPP
Interesting point of view.
Any word from the dealer/GM?
Richard0nee is offline   Reply With Quote
